Re: Popcorn hour c-200(Το νέο προϊόν)
Beta Firmware Changelog
[NMJ] Firmware 02-04-101206-21-POP-408 RC4 Bugfix
1. Fixed PlayOn issue
2. NTFS driver update (Write Support as A/C-200)
3. Added support for mkv header compression for h264 tracks
4. Added Arabic and Romanian options for DVD audio and subtitle.
5. Extended unicode string support for Hebrew Right-To-Left.
6. Fixes for music "now playing" screen
- "cover art" image now is up to 2MB. Otherwise default image is shown
- Fixed issue with image containing EXIF
- Fixed shoutcast continue playing at the background when quit using home/eject button
- Fixed cannot access AppMarket after playing BDJ
- Fixed movie image get deleted problem, when the image name is the same as movie name
- Fixed nfs cannot create database due to newly created nmj_database folder cannot change access permission
- Fixed wireless network stop working after 30 minutes
- Fixed static IP not working problem
- Fixed read-only samba share folder have scanner hang at "verifying" state
- Added error message when fail to update read-only samba share with older database version
- Fixed autoscan always overwrite original database
- Fixed volume soft issue after triggering FR/FF/Time Seek
- Fixed mp3 seamless playback
- Fixed non-mp3 audio files can only support jpg format for embedded album art
- Fixed movie detail page last watched scene area, sometimes can see the old stop-time overlap with the new stop-time.
- Fixed filename inside movie detail page does not change when focus to different movie
- Fixed ISO file do not have resolution/format/total time
- Fixed Series with more than ten season sort incorrect order like 1,10,11,2,3...
- Pressing green key at audio candy page, will change to and remain at "now playlist" page.
- Fixed tv series with more than ten season sort incorrect order like 1,10,11,2,3...
- Fixed issue where customised wallpaper being changed to default image when doing movie "refresh" (from movie detail page)
- Fixed framework crash when using Youtube
