Popcorn Hour C-200
tortish
18 October 2007
82
Re: Popcorn hour c-200(Το νέο προϊόν)
Beta Firmware Changelog
[NMJ] Firmware 02-04-101206-21-POP-408 RC4 Bugfix
1. Fixed PlayOn issue
2. NTFS driver update (Write Support as A/C-200)
3. Added support for mkv header compression for h264 tracks
4. Added Arabic and Romanian options for DVD audio and subtitle.
5. Extended unicode string support for Hebrew Right-To-Left.
6. Fixes for music "now playing" screen
- "cover art" image now is up to 2MB. Otherwise default image is shown
- Fixed issue with image containing EXIF
- Fixed shoutcast continue playing at the background when quit using home/eject button
- Fixed cannot access AppMarket after playing BDJ
- Fixed movie image get deleted problem, when the image name is the same as movie name
- Fixed nfs cannot create database due to newly created nmj_database folder cannot change access permission
- Fixed wireless network stop working after 30 minutes
- Fixed static IP not working problem
- Fixed read-only samba share folder have scanner hang at "verifying" state
- Added error message when fail to update read-only samba share with older database version
- Fixed autoscan always overwrite original database
- Fixed volume soft issue after triggering FR/FF/Time Seek
- Fixed mp3 seamless playback
- Fixed non-mp3 audio files can only support jpg format for embedded album art
- Fixed movie detail page last watched scene area, sometimes can see the old stop-time overlap with the new stop-time.
- Fixed filename inside movie detail page does not change when focus to different movie
- Fixed ISO file do not have resolution/format/total time
- Fixed Series with more than ten season sort incorrect order like 1,10,11,2,3...
- Pressing green key at audio candy page, will change to and remain at "now playlist" page.
- Fixed tv series with more than ten season sort incorrect order like 1,10,11,2,3...
- Fixed issue where customised wallpaper being changed to default image when doing movie "refresh" (from movie detail page)
- Fixed framework crash when using Youtube
NiKa
11 June 2008
2,487
Απάντηση: Popcorn hour c-200(Το νέο προϊόν)
Βγήκε και επίσημα...
1. Still same NMT apps 02-04-101104-21-POP-408
2. BD/AVCHD/DVD/CDDA
- Fixed BDJ sometimes cannot start playback
3. Video and Audio playback
- Fixed MP3 gapless playback
4. Networked Media JukeBox (NMJ)
- Fixed Movie Cover Art get deleted when the image filename is the same as movie filename
- Fixed database cannot be created over NFS due to newly created nmj_database
folder unable to change access permission
- Fixed read-only samba share folder will hang scanner at "verifying" state
- Added error message when fail to update read-only samba share from
- When database is created offline, subsequent Refresh at Movie Detail page
will fail even when online (Bug# 5001807)
- Fixed Episode name will sometime overlap with "episodes" button in Movie Detail page
- Fixed when switching between Video and Audio page using buttons in the Menu,
results in "No content found" error
- Periodic repeat "Shine" effect for Video and Music Wall
- Fixed "Insufficient Disk Space" error while scanning audio file
- Fixed ISO/BDMV/VOB file unable to be marked as watched
- Improve Up/Down navigation for Video Category Page
- Fixed Episode number showned as "null" when Episode number is unknown.
- Change Movie Cover Art help instruction
- Fixed when switching from NMJ UI to legacy UI will focused on the wrong file.
- Disable functions like delete, photo rotate, video editing, rescan...
when the filesystem is read-only
- Fixed capture fail for last watch scene of ISO file
- Fixed deleted movie still shown on recently watch page
- Fixed Autoscan always overwrite original database
- Added GIF/PNG/TIF/BMP support as embedded album art for non-MP3 audio files.
- Fixed in Movie Detail page, the old stop-time will sometimes overlap with
the new stop-time, in the Last Watched Scene box.
- Fixed filename inside Movie Detail Page does not change when
focus on next title.
- Added resolution/format/total time details for ISO file
- Fixed TV Series with more than ten season incorrectly sorted as 1,10,11,2,3...
- Fixed issue where customised Wallpaper will change to default image
when doing Refresh in Movie Detail page
5. System/Network
6. Apps/Apps Market
- Fixed Shoutcast continue playing when quitting using home/eject button
- Fixed unable to access AppMarket after playing BDJ
- Fixed YouTube crash when ended in RC3
7. Known issues
- Second bootup screen incorrect when boot up into SD mode
fotis63
21 January 2008
18
Μετά από πολλές ώρες διάβασμα στο forum, είμαι έτοιμος να παραγγείλω το C200.
Θα ήθελα να σας ρωτήσω αν κάποιος γνωρίζει το συγκεκριμένο multi-media bay.
http://www.addonics.com/products/mobile_rack/aemmby.asp
ή http://www.genesysrack.com.tw/HTML-English/mobilerack.htm
Με αυτό μπορείς να έχεις 3.5" δίσκο και slim BW drive.
Υπάρχει στην Ελλάδα?
Ευχαριστώ
PaLmoS
28 September 2009
30
Πολυ καλη ιδεα αυτη. Αν δεν το βρεις καπου ειχα βρει διαφορες πατεντες για αυτη τη λυση. Εγω το εχω με 2,5 δισκο που ειναι και αθορυβος.
thanoss
19 December 2010
9
Καλησπερα φιλοι ειμαι καινουργιο μελος εχω καποια ηλικια, και θα ηθελα μια βοηθεια απο εσας.
Εχω παρη εδω και πεντε μηνες ενα Popcorn hour c-200,το εχω συνδεσι με τον ενισχυτη και σε lcd τηλεοραση,ολα οκ τα παιζη ολα ,ειδικα ταινιες που βλεπω,σε ολα τα format ειναι αψογο,αλλα δεν μπορω να το συνδεσω με το pc, για να εχει μια συνεργασια με αυτο π.χ.θελω να περασω ενα movies jukeboxe και ενα musicjukebox ,εχω κανει συνδεσι με Ethernet ,και καποιες αλλες ψιλορυθμισεις,μου τα εκανε καποιος φιλος,αλλα δεν βλεπει με τιποτα το pc.
Υπαρχει καποιος να με βοηθηση, σε αυτο το θεμα,και εαν
μπορη να ερθη απο το σπιτι μου να τα τακτοποιηση,με το αζημιωτο.
Ευχαριστω
NiKa
11 June 2008
2,487
Για να τα πάρουμε από την αρχή...
είναι πολύ απλό για να συνδεθεί με το home network το c200...
α) στο c200 να έχεις βάλει Auto IP.. και 10/100 σύνδεση... ΟΧΙ AUTO...
β) κάνε share ένα φάκελο στο pc, τρέξε το Windows Share Manager (http://www.jankamp.com/) και βάλε σε όλα YES για το φάκελο που έκανες share
c) από το c200 πήγαινε network browser, workgroup και ψάξε να βρεις το φάκελο που έκανες share
Όλα καλά μέχρι εδώ?
Pilioritis
14 April 2010
82
Καλημέρα παιδιά και χρόνια πολλά.
Θέλω ν αγοράσω ένα popcorn hour c-200 και πριν προχωρήσω στην αγορά θέλω να κάνω μερικές ερωτήσεις.
1) Ποια είναι τα βασικά προβλήματα που αντιμετωπίζει τώρα το μηχάνημα (ασυμβατότητες κλπ) ??
2) Τι παίζει με ξεχωριστούς υπότιτλους sub and srt ??
3) Υπάρχει πρόβλημα να το προμηθευτώ από το ebay γιατί ίσως να υπάρχουν προβλήματα λόγω της χώρας από την οποία το προμηθεύομαι (διαφορετικός τύπος για διαφορετικές χώρες, άλλο μοντέλο κλπ) ???
Ευχαριστώ για τον χρόνο σας.
Pilioritis
14 April 2010
82
Και ίσως σε τελική ανάλυση μήπως είναι καλύτερα να πάρω το Α-200 ????
vadergr
17 August 2007
27,522
Μεταμορφωση
θες να μας πεις για τι χρηση το θες?Θα παιζει απο usb η απο δικτυο?Θες να παιζει και τα αυθεντικα μενου blu ray ή σε νοιαζει μονο η ταινια?
Pilioritis
14 April 2010
82
Θέλω να παίζει από τον δικό του δίσκο ή από τον εξωτερικό που έχω για αποθήκη ή από το pc όλα τις ριπαρισμένες τανίες που έχω. Φυσικά δεν θα με χάλαγε να μπορούσα να βάλω κι ένα δισκάκι Bluray επάνω. Όχι τα μενού ποτέ δεν μ ενδιέφεραν εφόσον μπορώ να κάνω κι αλλιώς επιλογή γλώσσας και υποτίτλου.
Βασικά αυτό που δεν έχω καταλάβει είναι ποιές είναι οι κύριες διαφορές μεταξυ Α200 - Α 210 - C 200.
Ευχαριστώ
thanoss
19 December 2010
9
Όλα καλά μέχρι εδώ?
Ευχαριστω πολυ solamnic7 θα το δοκιμασω
Pilioritis
14 April 2010
82
Κανείς για ομαδική αγορά μερικών κομματιών ???
266,39 στην πόρτα σας.
vadergr
17 August 2007
27,522
Μεταμορφωση
Aπο που φιλε μου?
Απλα προσεκτικα στις κινησεις σας και παρακαλω συννενοηθειτε με πμ και οχι εδω ή σε αλλα ανοιχτα θεματα.
vadergr
17 August 2007
27,522
Μεταμορφωση
Θελω να τονισω οτι σε περιπτωση ομαδικης αγορας , το φορουμ ΔΕΝ φερει ΚΑΜΜΙΑ ΕΥΘΥΝΗ αν οτιδηποτε παει στραβα.
Pilioritis
14 April 2010
82
Άντε καλορίζικο. Μόλις το παρήγγειλα από δω:
http://viewitem.eim.ebay.gr/Player_Popcorn_Hour_C200_no_HDD/260710583497/item
Αν και εκεί λέει 266,39 εμένα μου βγήκε 272 λόγω μιας διαφοράς στο δολάριο.
Πιστεύω ότι ακόμη κι αν πληρώσω τελωνείο είναι συμφέρουσα η τιμή.
NiKa
11 June 2008
2,487
Απάντηση: Re: Popcorn hour c-200(Το νέο προϊόν)
Ανάλογα με τι θα στο στείλουν.. αν έρθει με EMS έχεις μεγάλες πιθανότητες να μην πληρώσεις μία στο τελωνείο...
xrthammp
6 June 2008
495
Μην ξεχνάς ότι αν πληρώσεις τελωνείο 14% θα πληρώσεις και ΦΠΑ 23% στην τιμή μετά το τελωνείο.
