Yulong Audio Sabre DA8 Reference DAC + AMP
pride4eagles
10 December 2009
55
Wherever the music takes me
http://www.yulongaudio.com/en/product_detail.asp?pid=30
Τιμή εκτός Ελλάδας: 1199$ (περίπου 875 euro) ---- http://www.ebay.com/itm/Yulong-SABR..._Audio_Amplifiers_Preamps&hash=item2c6f934f3b
Τιμή εντός Ελλάδας: 1190 euro ---- http://www.kosmasaudiovideo.gr/showprod.php?id=2928
Specifications :
  • Inputs: Optical, Coaxial and AES support 16-24bit 44.1-192kHz
  • USB input support PCM 16-32 bit, 44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz DSD64,DSD128 - On Windows DSD256,DSD512
  • USB input support Mac OSX, Linux with UAC2 compliant kernel
  • KS/Wasapi/WDM/ASIO Drivers for MS OS XP to Win8 32-64bit
  • SNR: -135dB.
  • Dynamic Range: 133dB.
  • THD+N: <0.0002%
  • Frequency Response: 20-30KHz - 0.2 dB
  • Output voltage: RCA 2V; XLR 4.2V
  • Left/right channel crosstalk: -135dB
  • Power Consumption: <30W.
  • Single ended heaphone output: 600 Ohm: 70mW; 300 Ohm 150mW, 150 Ohm: 280mW, 32 Ohm: 1W
  • Dimensions: 250*180*55mm (10" W x 7" D x 2 1/2" H)
  • Net Weight: 2.5kg / 5.5 lbs
  • Color option: silver or black
Technical Specifications :
  • USB Input format support: PCM 16-32bit 44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz DSD64,DSD128 - On Windows DSD256,DSD512
  • Operating system support Mac OSX Linux with UAC2 compliant kernel.
  • Inputs: Optical, Coaxial, AES/EBU:16-24Bit,44.1-192KHZ
  • SNR: -135dB.
  • Dynamic Range: >130dB.
  • THD+N: 0.0002%
  • Frequency Response: 20-30KHz-0.2dB
  • Crosstalk -135dB
  • balancedOutput level:4.2V
  • Headphone amplifier output power: 600Ω:70mw 300Ω:150mw 150Ω:280mw 32Ω:1W
  • Power consumption: <30W.
  • size: 250*180*60mm.
  • weight: 2.5Kg
PHOTOS
Reviews:
http://www.head-fi.org/t/673033/review-yulong-audio-sabre-da8-reference-dac
http://www.soundbsessive.com/room/?p=828
pride4eagles
10 December 2009
55
Οι κριτικές είναι διθυραμβικές. Θεωρούν ότι σαν compo είναι ότι καλύτερο σε αυτήν την κατηγορία τιμής.
Βέβαια το θέμα είναι και ποιοί γράφουν τα reviews :flipout:
Ίσως οι γκουρού του φόρουμ μπορούν να μας δώσουν τα φώτα τους :Banane0:
Chris1967
11 September 2010
4,222
Ok... ας συζητήσουμε για μια ακόμα φορά για ένα προϊόν που κανείς μας δεν έχεις ακούσει... :flipout:
Τα review μου φανήκανε κάπως... και η τροφοδοσία δεν με εντυπωσιάζει καθόλου...
Αν πάρουμε τον μέσο όρο τιμής στα 1000 ευρώ... προσωπικά δεν θα το ρισκάριζα, για ένα Κινέζικο προϊόν, με αμφίβολη ποιότητα κατασκευής, αμφίβολη ηχητική ποιότητα και σίγουρα αμφίβολη μεταπωλητική αξία...
Έχουν κυκλοφορήσει ήδη μερικά DAC με DSD και καλά χαρακτηριστικά και φτηνότερα...
Θέλει λίγο υπομονή το πράγμα... έχουμε πει ότι αυτή η χρονιά προβλέπετε να είναι η μάχη των DSD DACs...
Sonus Naturalis
12 July 2009
9,099
Αθήνα, Ηλιούπολη
Και η ειρωνεία του πράγματος είναι πως η DSD εγγραφή είναι πεθαμένη ως format παραγωγής!
leo1964
12 May 2010
10,381
Νησί των Φαιάκων
Απάντηση: Re: Yulong Audio Sabre DA8 Reference DAC + AMP
Ναι, και μένα...απλά ο head-fier έχει αρκετά μηχανάκια που έκανε συγκρίσεις (πράγμα που για μένα μετράει)
και ψιλογλίστρησα :ridinghorse:
Έτσι λέει....αν δεν ακούσω με τα ώτα μου,δεν πιστεύω.
