http://www.yulongaudio.com/en/product_detail.asp?pid=30
Τιμή εκτός Ελλάδας: 1199$ (περίπου 875 euro) ---- http://www.ebay.com/itm/Yulong-SABR..._Audio_Amplifiers_Preamps&hash=item2c6f934f3b
Τιμή εντός Ελλάδας: 1190 euro ---- http://www.kosmasaudiovideo.gr/showprod.php?id=2928
Specifications :
- Inputs: Optical, Coaxial and AES support 16-24bit 44.1-192kHz
- USB input support PCM 16-32 bit, 44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz DSD64,DSD128 - On Windows DSD256,DSD512
- USB input support Mac OSX, Linux with UAC2 compliant kernel
- KS/Wasapi/WDM/ASIO Drivers for MS OS XP to Win8 32-64bit
- SNR: -135dB.
- Dynamic Range: 133dB.
- THD+N: <0.0002%
- Frequency Response: 20-30KHz - 0.2 dB
- Output voltage: RCA 2V; XLR 4.2V
- Left/right channel crosstalk: -135dB
- Power Consumption: <30W.
- Single ended heaphone output: 600 Ohm: 70mW; 300 Ohm 150mW, 150 Ohm: 280mW, 32 Ohm: 1W
- Dimensions: 250*180*55mm (10" W x 7" D x 2 1/2" H)
- Net Weight: 2.5kg / 5.5 lbs
- Color option: silver or black
- USB Input format support: PCM 16-32bit 44.1Khz 48Khz 88.2Khz 96Khz 176.4Khz 192Khz 352.8Khz 384Khz DSD64,DSD128 - On Windows DSD256,DSD512
- Operating system support Mac OSX Linux with UAC2 compliant kernel.
- Inputs: Optical, Coaxial, AES/EBU:16-24Bit,44.1-192KHZ
- SNR: -135dB.
- Dynamic Range: >130dB.
- THD+N: 0.0002%
- Frequency Response: 20-30KHz-0.2dB
- Crosstalk -135dB
- balancedOutput level:4.2V
- Headphone amplifier output power: 600Ω:70mw 300Ω:150mw 150Ω:280mw 32Ω:1W
- Power consumption: <30W.
- size: 250*180*60mm.
- weight: 2.5Kg
PHOTOS
Reviews:
http://www.head-fi.org/t/673033/review-yulong-audio-sabre-da8-reference-dac
http://www.soundbsessive.com/room/?p=828
