Re: Απάντηση: AZBox Elite/Premium, part II
Επιτέλους κάτι βγήκε σήμερα.....!!! :guitarist:
Για δώστε εσείς οι έμπειροι τα φώτα σας!
http://www.azbox-enigma.eu/e107/news.php
ειναι το πρωτο betta image του riper and company και συμφωνα με αυτο που λεει το team δουλευουν τα παντα εκτος απο τα card readers και τα εξτρα tuners δηλαδη το επιγειο και το καλωδιακο για την εγκατασταση του χρειαζεται το νεο ΑzUP v 1.2
AzUP v1.2
Code:
** Better safety while flashing Enigma 2 and new kernel versions
** Changed a way how Enigma 2 files are transferred to a AzBox HD device
** Possibility to install Enigma 2 on USB ( It install on same USB where patch.bin file is located, so there is no need to use 2 USB
), and HDD.
** Fixed problem with memory space on USB ( before approx. ~50MB was needed for extracting of Image, now is not problem )
** If You install on HDD, You can turn off Format of extended partition, and Your data on HDD will stay untouched !!!
** You can Turn OFF option copy kernel, if kernel in current version is not changed
** We suggest that KERNEL is always changed, and don't touch this when You are updating to the FIRST BETA version of Enigma 2 for AzBox.
** Added DHCP Server, which will lease IP address in same range where is IP address of Your PC, ofcourse if on Your network there is not existing DHCP Server, this will help that Your AzBox HD get valid IP Address when he is in Rescue mode.
** You can list all devices which You have on network and by that way to get which IP address is from AzBox HD.
** Find IP in LAN
** For AzBox HD Ultra, model without VFD , easiest way is to use crossover cable , so directly to connect Your PC/Laptop with AzBox Ultra HD without using LAN, and with that You will be sure that DHCP which is running with AzUP will lease IP address to Your device , and You can list it by clicking on DCHP IP ?
RTi core 1.0.0. BETA
Code:
What is new :
- Audio Fix - Fully fixed. by the_ripper
- HDMI Hotplug Fixed by the_ripper
- AzBox VFD Functionallity ( SETUP -> SYSTEM -> AZboxVFD for setup ). by DDamir
- Standby functionality FIXED by DDamir
- Multimedia Player Support ( Support for Various media formats ) by Sattomy
- SubtitlePlayer 3.0.2 ( Exclusivity, as SubtitlePlayer 3.02 is only accessible currently on AzBox HD ) by DDamir
- CrossEPG Plugin Integrated
- WebInterface AzBox HD ( Automatic selection of RCU on Web Interface Elite / Premium RCU ) by DDamir
- USB drivers support for Keyboard and Mouse by joseba
- Channel list by Daconi
WE WOULD LIKE TO SAY THANKS TO OPENSAT WHICH WAS INVOLVED TO PUT ALL EFFORTS TO SUPPORT AND COOPERATE ON THIS PROJECT
*** Please use AzUP v1.2 by telesat to Flash this new RTi core 1.0.0 BETA version of Enigma 2 in Your receiver including the KERNEL!!! , and read Release notes of AzUP v1.2 ***
*** KEEP IN MIND THAT THIS IS FULLY CLEAN CVS IMAGE, AND IT NOT CONTAIN ANY ILLEGAL FILES I
