Cambridge Audio EXN100 streamer / dac δοκιμή
Οσο για το μουσικό ήχο ξεκινάει πάντα από το timing ( PRAT= pace, rhythm and timing)! 🇬🇧
Έτσι, κουβέντα να γίνεται...
The core connection between ADSR and PRaT lies in the accurate reproduction of a sound's transient response.
  • ADSR describes the intended shape of a sound's dynamics over time, especially the sharp, initial "Attack" (the transient).
  • PRaT is the perceived ability of an audio system to reproduce those attacks accurately, which translates to a sense of energy, pace, and timing in the music.
Here is how specific elements connect:
  • Attack and Timing: The "Attack" portion of the ADSR is the leading edge of a sound, the transient that helps define when a note starts. A speaker or amplifier with poor transient response (slow to start and stop the cone movement) can "smear" this attack, making the sound seem less immediate or less "snappy". This directly harms the perceived Timing and Rhythm (PRaT) of the music.
  • Decay/Release and Pace/Rhythm: The "Decay" and "Release" stages sculpt the tail of the sound, influencing the silence (or lack thereof) between notes. If an audio system adds unwanted "overhang" (e.g., a bass note that continues slightly after it should have stopped), the space between the notes is reduced. This can make the music feel cluttered or slow, negatively impacting the perceived Pace and Rhythm.
  • System Fidelity: An audio component with "spot-on ADSR" and "precise sound" is often described in subjective reviews as having good PRaT because it is reproducing the micro-dynamics and texture of the original recording accurately.
In essence, ADSR is a signal characteristic or a sound-design tool, while PRaT is a listening impression that results from an audio system's ability to faithfully reproduce those ADSR characteristics in their proper temporal relationships.
Το να ενοχλεί δεν είναι παράσημο . Μπορεί ο ήχος να είναι αποκαλυπτικός και ταυτόχρονα smooth . Αυτό είναι προϊόν χαμηλών παραμορφώσεων χαμηλού θορύβου και απουσία clipping . Μπορεί ο ήχος ταυτόχρονα να είναι διαφανής και γρήγορος χωρίς να ξυρίζει αυτιά .
Πολυ σωστα.
Αυτο , χρειαζεται χρονο , και τριβη για να γινει κατανοητο.
Τοτε , καποιοι θα καταλαβουν τη διαφορα του smooth απο το soft , της καθαροτητας απο την λανθασμενη φωτεινοτητα , της φυσικοτητας απο την κακως νοουμενη αναλυση και κλινικοτητα και αλλα πολλα .
Το γύρισες στο άλλο άκρο.Δεν έγραψα πως ο ήχος πρέπει να "ξυρίζει" αυτιά αν και μερικα αυτιά αρέσκονται στο "κόντρα ξύρισμα".Σ' αυτά,το πρέπει δεν χωρά.
Το να ενοχλεί δεν είναι παράσημο . Μπορεί ο ήχος να είναι αποκαλυπτικός και ταυτόχρονα smooth . Αυτό είναι προϊόν χαμηλών παραμορφώσεων χαμηλού θορύβου και απουσία clipping . Μπορεί ο ήχος ταυτόχρονα να είναι διαφανής και γρήγορος χωρίς να ξυρίζει αυτιά . Μια σωστή ακουστική χώρου , σωστή τοποθέτηση και σωστό gain staging για αποφυγή clipping και εντάσεις που μπορούν να υποστηριχτούν με χαμηλή παραμόρφωση θα αποκαλύψει μια φτωχή ηχογράφηση , ατέλειες ηχογράφησης , αλλά ποτέ δε θα πάρει αυτιά .
Επισης,στην περίπτωση μας κρίνονται οι συσκευές και όχι ο χώρος.
Ο αντίπαλος του Cambridge δεν είναι το a6 αλλά το a8.
Επειδή έδωσα ένα παράδειγμα εταιρίας,πιστεύεις οτι τα καταφέρνει στο PRAT;Εγώ λέω πως είναι παράδειγμα προς αποφυγήν.Παραμορφωση από την άλλη όχθη,χαρακτηρίζω τον ήχο του.
PRAT έχει η ATC η οποία ταυτόχρονα κατηγορείται πως δεν έχει μουσικότητα.
