dCS -η κορυφαία επιλογή, cd, sacd, Hi-rez audio...
Re: Απάντηση: dCS -η κορυφαία επιλογή, cd, sacd, Hi-rez audio...
μιλάμε γιά 80000 δολάρια...
δυστυχώς οι απολαβές των μηχανικών - μελετητών στην χώρα αυτή δεν μου επιτρέπει ούτε την πολυτέλεια της σκέψης....
Δημήτρη έχει κι άλλα μοντέλα η dCS και όπως είδες στις φωτό, η παγκόσμια high-end κοινότητα τα τιμά δεόντως....
Παρατηρήσεις του Michael Fremer, αυτούσιες χωρις μετάφραση, από τη δοκιμή του ψηφιακού σετ Scarlatti SACD της Αγγλικής εταιρείας dCS.
Stereophile August 2009, DCS SCARLATTI SACD PLAYBACK SYSTEM, page 68.
1. The real test of the Scarlatti then, given the profusion of software, is how well it plays CDs. The problem is, after comparing some 24-bit/96KHz digital downloads played from my Apple G4 laptop vs their 16/44.1 CD version played on the $32,900 Scarlatti transport, it was easy to conclude that while the Scarlatti system is a much better CD player than the Verdi-Elgar-Purcell, spending big dollars on CD playback in 2009 might not be such a good investment.
page 68-69.
2. The growing popularity of server based sources and other digital peripherals adds greater utility to a multi-input DAC and makes for a more worthwhile investment. The bigger change, though has been Internet access to high-resolution audio files. Most current digital recordings are made of higher-than-“Red Book” resolutions and some labels-Linn, 2L, AIX, Chesky’s HDTracks for example are making high resolution original files available.
3. Server-type devices like the Sooloos Music Server and those from some other companies are already doing this, or are close to. For now; however, the Sooloos can only rip CDs. (By the time you read this, the updated software required to do what I’ve just described may be available). But if you have bought one of the server-based systems and transferred your CDs to it, what you’re likely to hear is what I heard through the Scarlatti system (especially, in my opinion, when upsampled to 24/176 ), comparing them to native 24/96 versions of the same material fed via USB to the Scarlatti Upsampler will conclusively prove to you what I and others have been saying for decades: upsampled, upconverted, sprinkled with holy water , trimmed around the edges , Bedini-treated-whatever you do to them, CDs just squeak by as a high-performance audio format. Still, played through the dCS Scarlatti, the best ones sounded very good indeed.
Michael Fremer (Stereophile)
Και οπως παντα στριβουμε δια του αλλα λογια να αγαπιομαστε ... Αν ακουγαν ολοι απο DcS το καλοκαιρι θα ηταν πιο μουσικο γιατι βλεπω οτι οσοι ακουνε με bluesky εχουν απωθημενο που ακουνε με bluesky ασε που στην συναντηση με τα bluesky οταν μπηκε αλλο Player εκλαψαν μανουλες bluesky-adwn ...
άντε και ακούσαμε....
με 80000 μπορώ να κάνω και έναν κουβά να παίξει μουσική. (θα μπορούσα να γίνω και πιό αυθάδης)
απωθημένο δεν έχουμε.
80000 κοστίζει γιά πολλούς μισό ή ένα σπίτι.
μιλάμε γιά αναπαραγωγή μουσικής.
σίγουρα κάποιος τρελλός θα βρεθεί να το αγοράσει ή και δυό ή 10 από αυτά.
Αυτό δεν σημαίνει ότι είναι τεχνολογικό επίτευγμα.
Αν είναι να δώσουμε 80000 γιά να ακούσουμε μουσική καλύτερα να ακούσω από το ταπεινό bluesky.
που φυσικά παίζει εξαιρετικά και ως transport.
Να μην ακούσω γιά συγκρίσεις.
αναλογικά 30/80000 το bs παίζει καλύτερα.
Και φυσικά ποιός χρειάζεται πια transports....Φυσικά υπάρχει ακόμα τόσο υλικό γιά πούλημα εκεί έξω... Ας μην ταράζουμε τα νερά.
και pls κοψ...don't pm me.
αν θες να πεις κάτι, πες το εδώ.
Δεν αμφιβάλω για την αξία του dCs, fVD, gΒF κτλ.
Αλλά το blue sky απο που πετάχτηκε πάλι;
Ακούει κάποιος άλλος εκτός απο μένα με δαύτο;
ακούω εγώ...
τελικά παίζει καλά και από την spdif.
(αλλά ας μην πολυκυκλοφορήσει...)
Απάντηση: Re: dCS -η κορυφαία επιλογή, cd, sacd, Hi-rez audio...
Στο εξοχικό το χρησιμοποιώ σαν transport και παίζει απροβλημάτιστα και μουσική και ταινίες σε DVD. Του έχω και ένα εξωτερικο non-oversampling DAC της Audio Nemesis για παρέα.
Πολύ smooth oparator ...
Ο κ. Fremer, αν και πικαπάκιας, μια χαρά τα πήγε με το review του scarlatti. Μου αρέσει ο τρόπος που σκέφτεται, αλλά μας τα χάλασε εκεί προς το τέλος με το laptop. Που να το συνέδεε και με firewire !!! :damnyou:
Το νημα ξανανοιγει με καποιες..."ελαφρυνσεις" στα ποστς.
Να παρακαλεσω να περιοριστουμε στο θεμα του νηματος και να μην ξεφευγουμε με προσωπικες αντιπαραθεσεις.
Μιας και διαγράφηκαν τα απαντητικά ποστς στα ερωτήματα γιατί δεν μεταφέρεται το νήμα στην DIY κατηγορία να τελειώνουμε?
Μόνο για την αποκατάσταση της αλήθειας περί των τιμών της dCS,
το Scarlatti DAC έχει τιμή καταλόγου 17.500 ευρώ και με ένα σκληρό δίσκο και σωστή σύνδεση και HDaudio (Hi-rez files) είναι super!
Το dCS Puccini τιμή καταλόγου 13.900 ευρώ.
Όλες οι συσκευές της dCS μπορούν να αγοραστούν και μεμονωμένα και φυσικά δεν χρειάζεται το transport για να κάνεις συνδυασμό με computer audio.......άσχετα φυσικά που o Ατκινσον αναφέρει στις μετρήσεις ότι έχει το καλύτερο error correction που έχει μετρήσει ποτέ.
Αν θεωρείτε ότι είναι διαφημιστικό το post, μπορείτε να το διαγράψετε αλλά θα διαγράψετε παρακαλώ και την παραπληροφόρηση των 80.000....
Τέλος στην κατηγορία high-end, νομίζω δεν τίθεται ορίων τιμών ή έχει κάτι αλλάξει?
Και να είστε σίγουροι, οι πελάτες των πολύ ακριβών high-end συσκευών και flagship μοντέλων δεν δανείζονται ούτε στερούν την οικογένεια τους (αν το κάνει έστω κι ένας πρόκειται περί μεγίστης βλακείας),
ούτε έλεγχο μπορεί να κάνει ο οποιοσδήποτε στα Δημοκρατικά πολιτεύματα στην τσέπη των συμπολιτών του. [θεωρείται "προσυλητισμός" και απαγορεύεται]
Τέλος σε λίγες ημέρες θα κυκλοφορήσει και στα περίπτερα το τεύχος Αυγούστου και μπορείτε όλοι να διαβάσετε το σχετικό άρθρο αυτούσιο και όχι αποσπασματικά, όπως κάθε άρθρο στον έντυπο τύπο μόνο στην ολοκληρία του μπορεί να κριθεί.
Και εγώ δεν μπορώ να αγοράσω to Cayenne, ή την πισίνα του γείτονα, ή το cartier της γειτόνισσας, αλλά δεν κλαίω σαν τη γριά χήρα, τα θαυμάζω και πάω παρακάτω...[πράσινες φατσούλες εννοείται..]
Τι ψάχνεις κι εσύ τώρα? :flipout::flipout::flipout:
ΚΟΨ, δεν είναι διαφημιστικό να ΑΝΑΦΕΡΕΙΣ ΤΗΝ ΠΡΑΓΜΑΤΙΚΗ ΤΙΜΗ ενός προϊόντος.
Αντίθετα αποτελεί την πιο άθλια μορφή παραπληροφόρησης, η αναφορά τιμής μεγαλύτερης απ την κανονική.
Επίσης, φαίνεται ότι ενοχλεί μερικούς που γράφεις κανονικά εδώ μέσα και δεν μπαίνεις σαν φάντασμα και να στέλνεις ΠΜ από εδώ κι από εκεί.
@Δημήτρη Θ.
Τα DCS είναι Ευρωπαικά προιόντα και είναι εύκολα να μπερδευτεί (ή να παραπληροφορήσει) κάποιος με τις τιμές, ισοτιμίες, δασμούς κλπ κλπ, επίσης στο εν λόγω άρθρο παρουσιάστηκε ένα πλήρες σετ Scarlatti (που συνδέεται εσωτερικά με firewire), που συνήθως δεν διατίθεται έτσι....και δεν είναι υποχρεωτική αγορά (τουλάχιστον στην Ελλάδα) transport & dac.
Οι παραδοσιακοί μπορούν να ξεκινήσουν με transport & dac και στην πορεία να προσθέσουν master clock....
Οι "μοντέρνοι" που θα έχουν δισκοθήκη στο pc χρειάζονται μόνο το dac & upsampler ή για πιο οικονομική πρόσβαση-συνδυασμό το Scarlatti dac & το Puccini U-clock.....ή ακόμη και μόνο το dac με κάρτα ήχου στον υπολογιστή που να έχει σύνδεση AES/EBU, για 24/192 διπλή AES/EBU (όπως οι κάρτες της Lynx & RME....μεταξύ άλλων) ή και απλή spdif.
Όπως βλέπετε χρειάζεται περισσότερη ενημέρωση για το σύστημα Scarlatti όπως το αποκαλούν στα κεντρικά.
Σε κάθε περίπτωση το D/A το dac δηλαδή είναι το πιο σημαντικό και πιο value for money για dCS προιόντα το ολοκληρωμένο Puccini :
[cd/sacd/preamp/esoteric trasnport/dsd upsampler κατ'επιλογήν/HDaudio 24/96 ready/DAC σε 2 inputs/DSD upsampling στα 2 inputs/γεννήτρια θορύβων μετρήσεων-ελέγχου/έξοδος 2V ή 6V επιλεγόμενη/στιβαρό αντιμαγνητικό σασσί αλουμινίου.....κλπ]
