[Επίσημο] iPad Pro @2022
airb
25 May 2008
16,661
Λιβαδειά
The new iPad Pro features a next-level Apple Pencil hover experience, ProRes video capture, superfast Wi-Fi 6E, and powerful features in iPadOS 16
  • 11-inch (2388 x 1668 pixels) Liquid Retina LED-backlit display with P3 Color Gamut, 600 nits brightness, 264 PPI
  • 12.9-inch (2732 x 2048pixels) Liquid Retina XDR mini-LED backlit display with P3 Color Gamut, 600 nits brightness, 1000 nits max full-screen brightness; 1600 nits peak brightness (HDR), 264 PPI
  • Apple M2 chip 8-core CPU with 4 performance cores and 4 efficiency cores
    10-core GPU, 16-core Neural Engine
  • 8GB RAM with 128GB, 256GB or 512GB storage / 16GB RAM with 1TB or 2TB storage
  • iOS 16
  • 12MP wide camera with f/1.8 aperture, 10MP ultra-wide camera with f/2.4 aperture, 5P lens, 125° field of view, Sapphire crystal lens cover, Autofocus with Focus Pixels (Wide), Brighter True Tone flash
  • 12MP Ultra Wide TrueDepth front camera with 122° field of view, f/2.4 aperture, Portrait mode with advanced bokeh and Depth Control, Portrait Lighting, Retina Flash
  • Five microphones for calls, video recording, and audio recording, Four speaker audio
  • Sensors: Face ID, LiDAR Scanner, Three-axis gyro, Accelerometer, Barometer, Ambient light sensor
  • 5G (optional), Wi‑Fi 6E 802.11 ax (2.4GHz and 5GHz) 2×2 MIMO; simultaneous dual band (2.4GHz and 5GHz), Bluetooth 5.3, Built‑in GPS/GNSS, Thunderbolt 3 / USB 4 (up to 40 Gbps) / USB 3.1 Gen 2 (up to 10 Gbps)
  • Dimensions (11-inch): 247.6x 178.5x 5.9mm; Weight: 466/470g
  • Dimensions (12.9-inch): 280.6x 214.9 x 5.9mm; Weight: 682/685g
  • 28.65 (11-inch) / 40.88-watt-hour (12.9-inch) rechargeable lithium-polymer battery with Up to 10 hours of surfing the web on Wi-Fi, watching video, or listening to music
Επιτέλους hover στο πενάκι τους.
Φαντάζομαι ότι είναι ότι υπάρχει εδώ και χρόνια στα galaxy note/s22 ultra.
Λογικά έτσι θα λειτουργει . Αλλα αποκλειστικό στα νέα pro όμως και οχι σε όλες τις συσκευές με το pencil 2 . Αν το έπαιρνα στο air αυτό το χαρακτηριστικό ίσως άλλαζα την κακή άποψη που έχω για το pencil της apple .
Πάλι χωρίς mini led το 11αρι….☹️
ΟΚ, μάλλον καλύτερα έτσι, γλιτώσαμε φέτος ένα έξτρα έξοδο Apple…🤪
Reactions: esykas and jig
Το'γραψα στο άλλο θρεντ ακριβώς για τον ίδιο λόγο, πρέπει σιγά σιγά ν'αρχίσουμε AA (Apple-victims Anonymous)
Και να το κάνουμε, θα έχουμε σίγουρα 2 «απεργοσπάστες» από εδώ μέσα….😆
Ξέρουμε ποιοι είναι χαχα. Αυτοί που τα βλέπουν όλα τέλεια και με το κλασικό "στη beta το έχουν φτιάξει" 😆
Youtube videos δεν έχω δει ακόμη και ανησυχώ.
  • Haha
Reactions: karamela
Εγώ μια φορά, το ultra δεν το παράγγειλα πάντως…
Αν αναφέρεσαι σε εμένα, με την beta έχει πρακτικά λυθεί το battery drain του 14pro όπως ανέφερα.
Θα το διαπιστώσεις και εσυ όταν το περάσεις.. oh wait
Έχεις beta την έκδοση iOS 16.1;
Δεν τα βλέπουμε όλα τέλεια… ΕΙΝΑΙ τέλεια! :p
Sent from my iPhone using Tapatalk Pro
Εγώ την πάτησα.
Μου χτυπησε την πόρτα σήμερα ενας μάρτυρας του Ιωχαβαπλ και έκανα το λάθος να του ανοίξω.
Ως επιδέξιος πλασιέ μου «πούλησε« ένα iPad pro 12.9 και ένα MacBook 16αρι.
Ας πρόσεχα….
Εγώ την πάτησα.
Ας πρόσεχα….
Δεν είχα στοκαρει ακόμα και το ρολογακι ρε γμτ αλλιώς θα στο έσπρωχνα και αυτό…
