- 20 May 2009
- 5,856
Στο γραφείο μου...
Luxman DA-100 USB D/A Converter
[TABLE="class: lead, width: 520"]
[TR]
[TD]-[/TD]
[TD]Portable A5-sized 2 channel PCM D/A converter[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Adopts 32bit processing and equipped with the latest high quality Burr-Brown PCM5102 DAC[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Selectable Digital filters to switch it between FIR and IIR mode[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]B-type USB interface to connect USB digital audio input from PC or Mac[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Supports 32kHz~192kHz,16 bit,20 bit,24bit digital input (max 96kHz, 24bit for USB input) [/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Available D/D converter function while connecting digital inputs including USB input[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Built-in headphone AMP circuit ,similar to DA-200[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Low phase noise clock module to reduce the noise level of any digital signal[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]High-accuracy built-in DAIR crystal for the digital input to minimize the jitter of asynchronous processing.[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Indicates frequency features via high visibility 3 digit 7segament LED display.[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Implements LUXMAN traditional round pattern PCBs and Spiral Wrap•shielded wiring and special-made components.[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Gold plated RCA output terminal with a pitch of 18mm, allowing large type connector to be plugged in.[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Compatible with various standard OS driver from Windows XP/Mac OSX onwards[/TD]
[/TR]
[TR]
[TD]-[/TD]
[TD]Supplied optional feet are available to be attached at the sides of the case to allow it stand upright *display will not switch automatically.[/TD]
[/TR]
[/TABLE]
Το πρώτο πράγμα για το οποίο θα μιλήσω είναι η ποιότητα κατασκευής. Είναι άπαιχτο εργαλείο.
Στιβαρό, full metal jacket, βαρύ (για να είναι Χαϊ Εντ
)... πολύ πολύ καλοφτιαγμένο.
Ακροάσεις σε λίγο... οπότε αναμονή για πρώτες εντυπώσεις... :2thumb22sup:
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[TR]
[TD]-[/TD]
[/TR]
[/TABLE]
