Hi, I can confirm that the new IMS2011 will support multilingual translation, default is English, but it can be set with one translate file for any language.
Some information about DMD IMS 2011 can be found here:
http://www.iamm.cz/viewtopic.php?f=47&t=2758
- you can translate it with google :idea:
http://www.youtube.com/watch?v=lmuUvw8q3bc
Greetings derby00 DMD Team
Hi derby00, nice to hear from you in our forum.
I could help with the greek translation if you like, or any other things since I have some programming background, and I have done some research about the NTR also. Can you give us more info on that?
Also, I have used your alternate firmware and there is a problem with the greek channels. The scanning does not work (either automatic or manual). Has this been solved? Is there a way to fix it?
Thanx.
