Panasonic Plasma PX80 / ΡΧ8 : Reviews - Εντυπώσεις - Σχόλια
Απάντηση: Panasonic TH-42PX80E: Ξανατριπλάρει και ξανασκοράρει!!!
Φίλε chrppgr...για ρίξε μια ματιά στο παρακάτω, πιθανόν να είναι κάτι αντίστοιχο με το πρόβλημα που αντιμετωπίζεις...
http://www.avforums.com/forums/showpost.php?p=6967720&postcount=187
It seems the problem with the built-in tuner is linked (very suprisingly) to the HMDI slots!
When I have an hdmi cable (well dvi to hdmi cable) in the back and the TV has been on standby for more than about 3mins the tuner fails to function properly. However as long as the tv is on the tuner works fine, even with the cable in.
No matter what channel was last watched. Only channel ITV in analogue mode and the ITV multiplex in DTV work!
The akward fix is to switch the tv off, pull the cable out and switch the TV back on.
This suggests that the TV is working fine and the source preamp is working fine, but the tuners are not.
Why the tuners are affected by the hdmi cable I do not know, but I need a solution!
any ideas?
..λίγο παρακάτω περιγράφει το πρόβλημα πιο αναλυτικά...
http://www.avforums.com/forums/showpost.php?p=6973589&postcount=195
Can you please run test for me:
  • Can you set your computer up with the output to the TV.
  • Then select the internal tuner to the TV (analogue or digital) and make sure all channels work
  • Then switch the TV off.
  • Then switch it on after say 3-4 mins to the TV
  • Then check to see which tv channels still work
...κάποιος άλλος κάτοχος προτείνει κάποια άλλη λύση...
http://www.avforums.com/forums/showpost.php?p=6990904&postcount=209
I have the same problem with the tuner. It is very annoying!
Other solution: switch off the pc (release the hdmi signal...) or desktop right click and go back "single display mode" in vga settings panel - turn off tv - turn on tv - and voila: works everything is fine (no need to pull out the hdmi cable)
Somebody has an idea to the simplier solution?
...αλλά αφού δεν έχεις συνδέσει τίποτα σε θύρα HDMI...δεν ξέρω αν θα σε βοηθήσουν τα παραπάνω...κάνε μια δοκιμή ακολουθώντας τα παραπάνω για τη svhs...π.χ. αν έχεις συνδέσει το lap top στη svhs, να το επαναφέρεις σε single display mode (πριν κλείσεις την TV)...και μετά να το κλείνεις...
http://www.avforums.com/forums/showpost.php?p=7231914&postcount=587
Hi guys
I'm new at this forum and have a question for you if you know how to resolve it.
Here it is
I have connected my 42pV80(european model) with pc trough HDMI cable and experienced problems. Problem is that when I turn on my PC before TV on the plasma display there is only "snow" and tv wont find any of the SD channels, but when I unplug HDMI from graphic card or TV everything goes back to normal. Graphic card is Nvidia POV 8800 GTS with 640Mb of memory
And another thing, if I turn TV first and then PC everything works fine, problem persists only if PC is turned on before TV
Is it possible that PC or graphic card is blocking the tuner of the telly, if someone has experienced the same please help
Thank you
μάλλον θα πρέπει...να ανοίγεις πρώτα τη τηλεόραση...και μετά το PC...μην το συνδέσεις αναμμένο...και πριν το κλείσεις να κάνεις επαναφορά σε single display mode..
...ελπίζω να είναι αυτό....:nounder:
Re: Panasonic TH-42PX80E: Ξανατριπλάρει και ξανασκοράρει!!!
Xρηστο εισαι απαιχτος!!!! Φιλε ευχαριστω παρα πολυ για ολη αυτη τη μελετη που εκανες με αφορμη την ερωτηση μου. Εκανα επαναφορα ρυθμισεων το πρωι σημερα, και προς το παρον δεν μου ξαναπαρουσιασε προβλημα στις λιγες δοκιμες που εκανα( την εκλεισα και την ανοιξα με αναμονη 2-3 λεπτα ). Ας ελπισουμε οτι εστρωσε.....Και παλι thanks!!!
Λίστα κατόχων PX80 & ΡΧ8:
ΜΑΡΤΙΟΣ 2008
01.czoun--------------42PX80---13/3/08 (OK)
02.geogoust-----------37PX80---16/3/08 (OK)
03.gzoun--------------42PX80---18/3/08 (OK)
04.pz107--------------42PX80---20/3/08 (πιθανό πρόβλημα με ηλεκτρική παροχή 21/3/08)
05.Δημοκηδής---------42PX80---26/3/08 (ΟΚ)
06.Const--------------42PX80---26/3/08 (OK)
07.vastsar-------------42PX80---27/3/08 (OK)
08.lorry6204-----------42PX80---27/3/08 (OK)
09.GK1964-------------42PX80---27/3/08 (OK)
10.kapoera-------------42PX80---27/3/08 (OK)
11.gorgor--------------37PX80---27/3/08 (OK)
12.Preve---------------37PX80---29/3/08 (OK)
13.Διονύσης-----------42ΡΧ80---30/3/08 (ΟΚ)
ΑΠΡΙΛΙΟΣ 2008
14.kparis--------------37PX80---02/4/08 (OK)
15.tasio550------------42PX80---04/4/08 (πιθανό πρόβλημα pictureoverscan 03/5/08)
16.perd----------------42PX80---06/4/08 (OK)
17.Stelliospapa---------42PX80---9/4/08 (OK)
18.Jacob---------------42PX80---18/4/08 (OK)
19.Panosxgr------------42ΡX80---20/4/08 (OK)
20.ppage---------------42PX80---24/4/08 (OK)
21.gsar10--------------42PX80---30/4/08 (OK)
ΜΑΪΟΣ 2008
22.dimogrec------------42PX80---06/5/08 (OK)
23.nikos.s--------------42PX80---06/5/08 (OK)
24.axaios---------------42PX80---08/5/08 (OK)
25.eNeRGy--------------37PX80---13/5/08 (OK)
26.nikos1671------------42PX80---16/5/08 (OK)
27.Nikos Arvanitakis-----42PX80---19/5/08 (OK)
28.BadCarma------------42PX80---19/5/08 (OK)
29.MAVROS-------------42PX80---21/5/08 (OK)
30.tacolla---------------42PX80---22/5/08 (OK)
31.Χρήστος Ιωαννίδης---42ΡΧ80---23/5/08 (ΟΚ)
32.
chrppgr--------------42PX8----26/5/08 (OK)
33.makis_p--------------37ΡX80---30/5/08 (OK)
34.lisaki2004------------37PX80---31/5/08 (ελαττωματική εκ κατασκευής, άμεσο πρόβλημα όμοιο με το cnet 01/6/08 -αντικατάσταση συσκευής με νέα)
35.mitsos_athens--------42PX8----31/5/08 (OK)
ΙΟΥΝΙΟΣ 2008
36.Trisalon---------------42PX80----03/6/08 (OK)
37.sapporo---------------37PX8-----04/6/08 (OK)
38.stefan123-------------37PX8-----04/6/08 (OK)
39.G.K.------------------42PX80----04/6/08 (OK)
40.jimp------------------42PX80----05/6/08 (OK)
41.aragorn---------------37PX80----06/6/08 (OK)
42.Busoni----------------37PX8-----10/6/08 (OK)
43.alaz------------------37PX80----11/6/08 (OK)
44.Age4greeks-----------42PX80----12/6/08 (OK)
45.Messenger------------37PX8-----16/6/08 (OK)
46.sotos65--------------42PX80----17/6/08 (OK)
47.ALEXF----------------37PX80----20/6/08 (OK)
48.Ripclaw07------------37PX80-----24/6/08 (OK)
49.zoser-----------------42PX80----25/6/08 (OK)
50.malwnakos-----------37ΡΧ80-----26/6/08 (ΟΚ)
Φίλε τσιροροπιπιτζιρο (αν προφέρει κανείς το nickname σου κερδίζει τσικουλάτα)...γι' αυτό είναι το forum, για να αλληλοβοηθιόμαστε....-bye-
Φίλε τσιροπιπιτζιρο (αν προφέρει κανείς το nickname σου κερδίζει τσικουλάτα)...γι' αυτό είναι το forum, για να αλληλοβοηθιόμαστε....-bye-
:worshippy:
.....:a0210:
Άμα κατέβω Κρήτη...χρωστάω τσικουλάτα...-bye-
δεν ξερεις απο τσι..πρεπει να εισαι γνησιος Κρητικος-bye-
Τράπεζες δεν εκάμανε σε τούτουσες τσι τόπους[FONT=Arial, Heletica, sans-serif]
να καταθέσω τσι καϋμούς να ζω από τσι τόκους
Υ.Γ.: Πήρα τηλέφωνο το πεθερό μου....:flipout:
[/FONT]
[/FONT]απο το σπίτι τζι περνώ
τη νύχτα σαν τον κλέφτη
γιατί πολύ κουτσομπολιό
στη γειτονιά τζη πέφτει"
[/FONT]
:ernaehrung004:
τελος του:offtopic:
Re: Απάντηση: Panasonic TH-42PX80E: Ξανατριπλάρει και ξανασκοράρει!!!
[/quote]
Φίλε τσιροροπιπιτζιρο (αν προφέρει κανείς το nickname σου κερδίζει τσικουλάτα)...-bye-
[/quote]
Φιλε czoun ειμαστε συννοματοι. Και μενα χρηστο με λενε....
Απάντηση: Re: Απάντηση: Panasonic TH-42PX80E: Ξανατριπλάρει και ξανασκοράρει!!!
[/quote]
Φιλε czoun ειμαστε συννοματοι. Και μενα χρηστο με λενε....[/quote]
Για να σε λένε Χρήστο...καλό παιδί θα είσαι...:flipout:...-bye-
Σας ενημερώνω για την σπασμένη τηλεόραση: Ήρθαν απο το πλαίσιο σήμερα στις 8:30 το πρωί (!) και την αντικατέστησαν. Η νέα τηλεόραση φαίνεται πως λειτουργεί καλα αν και μεγάλες διαφορές δεν βλέπω από την προηγούμενη. Προφανώς θα θέλει το χρόνο της όπως αναφέρατε. Σύνδεσα και ένα DVD Philips´μέσω HD καλωδίου. Ελπίζω όλα να πάνε καλα...:)
Απάντηση: Re: Panasonic TH-42PX80E: Ξανατριπλάρει και ξανασκοράρει!!!
Απο την σπασμενη εννοεις οτι δεν βλεπεις διαφορες?:BDGBGDB55:
ΥΓ. Πλακα κανω , τι τηλεοραση ειχες πριν?
Έιχα μια LOEWE 26' CRT κλασική και μάλιστα πολλά χρόνια. Η PANASONIC δεν με θαμπώνει και βλέπω πιο άνετα τα χρώματα όμως έχω την εντύπωση πως στην CRT ήταν πιο ζωντανά. Ίσως φταίει κάποια ρύθμιση...
Μια χαρά εξυπηρέτηση δηλαδή. Τους είχες έτοιμο πρωινό ? :D
Καλές και απροβλημάτιστες θεάσεις και σιγά σιγά θα φέρεις την εικόνα στα μέτρα σου.
ΜΑΡΤΙΟΣ 2008
ΑΠΡΙΛΙΟΣ 2008
ΜΑΪΟΣ 2008
32.
ΙΟΥΝΙΟΣ 2008
51.christosmed----------42PX80-----27/6/08 (OK)
Συνονόματε καλορίζικη......-bye-
Aν απο 26" πηγες στις 42" και δεν βλεπεις χειροτερευση στην εικονα τοτε αυτο θα πει οτι η PX80 κανει καλα την δουλεια της.
Re: Απάντηση: Re: Panasonic TH-42PX80E: Ξανατριπλάρει και ξανασκοράρει!!!
+1 από εμένα. Πολύ σωστή παρατήρηση.
Επίσης να αναφέρω κάτι για τη συσκευασία. Προσωπικά δεν ξέρω αν θα παραλάμβανα οποιοδήποτε προϊόν με ανοιχτή συσκευασία γιατί πάντα θα έμενα με την απορία...Είμαι σίγουρος ότι και εσύ christosmed το ίδιο θα έκανες. Δεν νομίζω να μην σε παραξένευε καθόλου!!!
Όταν ένα προϊόν κάνει κάτι εκατοντάδες ή και χιλιάδες χλμ βόλτα μέχρι να φτάσει στην πόρτα μας οτιδήποτε μπορεί να συμβεί. Shit happens που λέμε.
Από εκεί και πέρα είναι θέμα κατανόησης του καταστήματος. Στο Πλαίσιο φάνηκε να εφαρμόζουν τα αυτονόητα, τα οποία στην Ελλαδίτσα μας μόνο αυτονόητα δεν είναι.
Φιλικά Πασχάλης
Υ.Γ. Πώς το έλεγε στην ταινία Pink Panther? "Every day in any way we are getting better and better". Το panel δηλαδή...Η εσοδεία του 2008 φαίνεται να λέει πολλά....
[FONT=Arial, Heletica, sans-serif]Υ.Γ.: Πήρα τηλέφωνο το πεθερό μου...[/FONT]
Το πεθερό τι ακριβώς είναι? :jester:
Φιλικά Πασχάλης
