QNAP NMP-1000P Network Multimedia Player Review
έχεις δίκιο onlineN όντως αυτό ήταν τα είχα και τα δύο 10 είδα μια ταινία και έπαιξε νεράκι!! είσαι δάσκαλος τέλος ...
εγώ πάντως το motion plus το έχω off όταν βλέπω HD ταινία από το media player και παίζει άψογα.
[Beta Firmware] NMP-1000P v1.2.0 Build0818
Postby QNAPTony » Fri Aug 19, 2011 5:21 pm
Hi all,
Below link please find the latest beta firmware for NMP-1000P.
[Download Links]
http://forum.qnap.com/viewtopic.php?f=176&t=48445
[Checksum]
3122646390 86543279 NMP-1000P_20110818-1.2.0_ALL_PAL.fw
1911410532 86543371 NMP-1000P_20110818-1.2.0_ALL_NTSC.fw
[Version & Build]
v1.2.0 Build0818
[New]
- Support audio only live stream
- Playback UI for TuneIn Radio
- Update safe mode
- Support .flv
- Upgrade SDK
- Play-count function
- Upgrade transmission daemon for BT Download Station
[Bug fix]
- Change NAND Flash access clock
- Music Title value empty
- Picture changes Play mode setting
- Fix detection failure on wireless dongle
- Disable wireless driver messages on the console
- Disable HWJPEG
- Initial mute variable
- Enable Youtube video url translation function in codec library
- HTTP buffer controller for FLV
- Fix power on detecting issues (on Ralink2870 wireless dongle)
- Restrict max 8192 files visible in a folder because of long user wait
- Enable Youtube option, fix typo
- Press key [play] to playback DVD/BD folder
- Fisable slide-in effect of active-menu in photo playback
- Translate remote file name to local filename for Media DB initialization and web playback
- USB folder remove problem
- delay to avoid power-off failure
- Modify get album art rule
- Solve Youtube query fail
- Login YouTube, no options Add to favorites
- Enhance volume adjustment performance
- Youtube change web page
- DCM support to delete the current playback track
- Enhance the setting volume performance for DVD, CD and BD mode
- Mute and playback and unmute, there are noise on HDMI
- Disable option "Eject/Disconnect" for Internal disk
Προσπάθησα να ξαναπάρω το Qnap NMP1000P από την αντιπροσωπεία για επαναληπτικό τέστ αλλά στάθηκα προσωρινά άτυχος.......
Υ.Γ. Επίκειται media players test από γνωστό κομπιουτεροπεριοδικό και τόχουν λέει αυτοί....!!!!
Αυτό το τεστ θέλω να το δω........:flipout:
ΝΕΟ FIRMWARE
[Beta Firmware] NMP-1000P v1.2.0 Build1026
by QNAPTony » Thu Oct 27, 2011 3:22 pm
Hi all,
Below links please find the latest beta firmware for NMP-1000P.
[Download Links]
NMP-1000P v1.2.0 Build1026 NTSC :http://eu.qnap.com/NMP/NMP-1000P/NMP-1000P_20111026-1.2.0_NTSC.zip
NMP-1000P v1.2.0 Build1026 PAL :http://eu.qnap.com/NMP/NMP-1000P/NMP-1000P_20111026-1.2.0_PAL.zip
[Checksum]
2536472287 87049415 NMP-1000P_20111026-1.2.0_NTSC.fw
1822341603 87049699 NMP-1000P_20111026-1.2.0_PAL.fw
[Major Change]
1. Fix the system event logs time & playback event logs end time is not concurrent problem
2. Force /mnt/config recovery when it cannot be mounted
3. Player language, Picasa picture information
4. ShOUTCAST waiting animation
5. Fix virtual keyboard
6. Fix SPDIF max sample rate and other option
7. Fix when switch audio to DTSHD, HDMI output disappear
8. Disable auto starting btd.sh
9. not disable '-sparse' ufsd mount option
10. Solve Jukebox occupy much CPU resource problem (*.wav)
11. Display internet items in WIN_ID_ALLMEDIADEVICE
12. Replace [Apply] button by "Please wait." message to inform user of action still in processing. (Download Station Web UI)
13. Show waitting icon immediately while video playback start
14. Fix always power off while rebooting.
15. Add TuneIn Radio presets function while no login
16. Quite a few updates in order to fix bugs on Download Station
17. Add Enable-lightweight on TRANSMISSION
18. Fine tune TuneIn Radio navigation UI
19. Modified NAS mode/Shutdown message
Regards,
Tony
QNAPTony
Gold Warrior
NAS Model: TS-639 Pro
Μια πολυ γρηγορη ερωτηση.
Μπορεις να δουλεψεις τον download manager που εχει, οπως και στα NAS της QNAP?
Δηλαδη να του βαλεις links και να τα κανει download οπως και τα NAS?
Re: Απάντηση: QNAP NMP-1000P Network Multimedia Player Review
Εάν μπορείς να περιμένεις για την απάντησή σου μετά τα Χριστούγεννα που θα το δοκιμάσω πάλι ...έχει καλώς. Αλλιώς κάνε ερώτηση στο forum τους ...
Καλημέρα σε όλους τους φίλους,
είπα να ξεκινήσω και εγώ να κάνω ένα καλό home cinema και επέλεξα το QNAP media player, ορμώμενος απο το thread. Το έχω συνδέσει με το router μέσω powerline με καλή απόδοση και παρατηρώ οτι κάνει σπασίματα όταν παίζει απο το NAS που έχω συνδέσει στο router. Επίσης στα .mkv αρχεία δεν υποστηρίζει τους ελληνικούς υπότιλους με πρόβλημα στο encoding. Θα ήθελα να ρωτήσω αν υπάρχει κάποια ρύθμιση που θα μπορούσα να κάνω για να διορθώσω τους ελληνικούς υπότιλους (όσο και να έψαξα δεν βρήκα την επιλογή για αλλαγή στο encoding των υποτίτλων) καθώς και καμια πιθανή ρύθμιση για το streamαρισμα...
δεν θέλω να το μετανιώσω που το πήρα καθώς διαβάζω ότι πιο φτηνα media player είναι απροβλημάτιστα...
Φιλικά,
Γιώργος
Φιλικά,
Γιώργος
Γεια σου φίλε Γιώργο και καλώς ήρθες στο forum.
Δυστυχώς δεν κατάφερα να σου απαντήσω νωρίτερα...λόγω προσωπικών υποχρεώσεων.
Λοιπόν...:
Είναι περίεργο το Qnap. Εάν πας στην γλώσσα και την γυρίσεις στα Ελληνικά τότε - ως δια μαγείας - θα δεις τους υπότιτλους να υποστηρίζονται.
Επίσης μπορείς να "γυρίσεις" το encoding των υποτίτλων από ANSI σε UTF-8. Και στις 2 περιπτώσεις θα δεις υπότιτλους.
Τώρα όσον αφορά το streaming ..είναι παρακινδυνευμένο να υποστηρίξουμε ποιο αρχείο θα παίξει σωστά και πιο όχι με σύνδεση μέσω powerline.
Επίσης - αν και Qnap ...που έπρεπε να είναι καλύτερο από άλλα σε θέματα δικτύου - ακόμα και ενσύρματα, iso files μέσω δικτύου δεν θα παίξεις.
Πρόσφατα το δοκίμασα με το νέο firmware 1.02 v.1125 και δεν παρατήρησα καμμία αλλαγή σημαντική από τα προηγούμενα.
Κρίμα για την Qnap γιατί θα μπορούσε με αυτό το μηχάνημα να αναβαθμίσει την ενεργή ακόμα κατηγορία των Sigma chipsets 8642-3 η οποία είναι ότι πιο αξιόπιστο κυκλοφορεί αυτήν τη στιγμή.
Κατά τα άλλα η εικόνα κορυφαία..(αναμενόμενο) ο ήχος κορυφαίος σε όλα τα επίπεδα...( αναλογικά και ψηφιακά..) Το GUI ...απορώ γιατί δεν το αναβαθμίζουν ...ή γιατί δεν δίνουν την δυνατότητα στον χρήστη να το κάνει μόνος του....
Απάντηση: Re: QNAP NMP-1000P Network Multimedia Player Review
Καλώς σας βρήκα,
την αλλαγή με το αρχείο των τίτλων σε Unicode την βρήκα και την έκανα, δεν μπορούσα να φανταστώ ότι το γενικό μενου στα Ελληνικά υποστηρίζει και ελληνικούς χαρακτήρες .... Επίσης μετά απο λίγο καιρό είδα οτι streamαρισμά απο το NAS πρέπει να το ξεχάσω.... να σου πώ απογοητεύτηκα λίγο καθώς δεν το μελέτησα σε βάθος, είχα διαβάσει πολλά καλά πράγματα για την QNAP ως εταιρεία στα NAS και έτσι σκέφτηακα να τα συνδυάσω... τελικά δεν ήξερες, δεν ρώταγες; Ωραίο μηχανηματάκι, πολύ δυσχρηστό το GUI ( ηλίθια δυσχρηστό και με ελλείψεις...) αλλά για τον βασικό σκοπό που το πήρα - για streamαρσιμα απο NAS- δεν την κάνει την δουλειά του...
Επειδή είναι και τρία κατοστάρικα και δεν είναι καιρός για να πετάς λεφτά θα μείνω σε αυτο αλλά θα πρότεινα να μην το αγοράσει κάποιος εκτός αν καταλαβαίνει την διαφορά στην ποιότητα εικόνας... εγώ θα προτιμούσα να έβλεπα το Matrix I απο το NAS χωρίς σπασίματα και με χειρότερη εικόνα ( όσο σκέφτομαι ότι αυτό θα το είχα με τα μισά λεφτά μου την δίνει!)
ΒΤW αναβάθμισα το firmware στην τελευταία έκδοση και απορώ πως ζούσαν με την έκδοση που ήρθε το μηχανάκι! Αν και η τελευταία είναι εξαιρετικά δύσχρηστη... Έπρεπε να πάρω κανα WD Live και να αφήσω την ποιότητα για να βλέπω άνετα ταινιούλες στο σαλόνι μου....
Σε ευχαριστώ για την βοήθειά σου! Ότι ακούσεις που μπορεί να το διορθώσει το μηχανάκι, ανέβασέ το!
Γιώργος
Εδώ και κανα μήνα δεν βρίσκει τα εξώφυλλα και τις πληροφορίες των ταινιών με την εντολή ¨get the brief indroduction" από το menu "file attributes". Σαν να σταμάτησε να λειτουργεί ο server από όπου παίρνει τα στοιχεία από το internet
Γνωρίζει κάτι κανένας επ' αυτού;
Υπάρχει άλλος τρόπος να κατεβάζεις τα στοιχεία αυτά; Eγκαθιστώντας ίσως κάποιο άλλο πρόγραμμα.
Όσον αφορά το media library πάντως το Qnap είναι πολύ πίσω στο software. Κρίμα τόσο καλό μηχανάκι να χαντακώνεται από την υποστήριξη στο software.
