Panasonic 46PZ80
Pro's
- Image retention is minimal
- Excellent build quality
- Ok looks (not in the same league as the PG6000)
- full HD with highly detailed images
- 24p support with correct pulldown (4:4 - 96hz)
- Stunning black level perforance and shadow detail
- SD card slot for viewing photos
- Good SD performance for a full HD panel
Con's
- Annoying fan noise which can vary and change pitch. Distracting.
- Poor sound
- The most stupid position I have ever seen for an HDMI port (1 located in the front). This cannot be used if you wanted a tidy setup with the set wall mounted (unless you wanted to leave the fron cover open).
- Poor menu system with very few picture settings
- Sluggish remote which can be unresponsive if it isn't pointed right at the IR receiever
- Expensive (by comparison, the PG6000 is over £300 cheaper and you get an extra 4 inches)
- HD pictures can be noisy at times
- High power consumtion (400-odd watts I believe)
Although I would agree that the PZ80 is probably the more detailed image and definitely a superior black level performance, I'm really struggling to think why anyone would want to spend an extra £300 on a set that is otherwise light years behind the LG. The sound, design, features, tweaking, noise (db) level and SD performance are all way better on the LG. I can't help thinking that Panasonic are using their reputation to squeeze as much money out of people as they can. There is no way is this worth £300 more. Now I know I'll have the Panasonic fans on bashing me for this, but I don't really care. I have owned both sets, albeit briefly, and I am in a position to make this judgement. People may, or may not agree with me. That's entirely up to them. I'm just disappointed as I was expecting a lot more from the PZ80. I see no reason (other than native 24p support and deeper blacks) to buy this over the 2007 Panasonic models which can be had for a bargain.
Ενα μελος που ειχε PG6000 και την αλλαξε με PZ80 συγκρινει τις δυο τηλεορασεις.
Μάλλον απογοητευμένος είναι από την 46PZ80, γιατί σκέφτεται να την στείλει πίσω και να ξαναπάρει την 50PG6000. Να δούμε πως θα τα πάει και η PZ800.
Προδοσία!Στον ιδιο δρομο βαδιζω και εγω.
Προδοσία!
Εσύ που με τα ποστ σου τόσο καιρό με ετοίμασες για Α656
Και την αγοράζω σε μια βδομάδα.
Μην υποκύψεις στο μαρκετιγκ της Σόνυ.
Κάνε την υπέρβαση και πάρε το αστέρι!!!
Θα το μετανιώσεις!!!!!!!
Άλλωστε αν διάβασα σωστά έχεις Σόνυ. Το δις εξ αμαρτείν...
Aν δεν σου αρκεί αυτό δες το παρακάτω:
http://presse.samsung.de/webdownloads/pressedownloads/LCD650_46_L30%20(350dpi).JPG
Προδοσία!
Εσύ που με τα ποστ σου τόσο καιρό με ετοίμασες για Α656 :BDBDG54:
Λοιπον ο jopar πηρε την 46W4000. Στον ιδιο δρομο βαδιζω και εγω.
Tην 656 στις 46" την πηρε τελικα κανενας να μας πει εντυπωσεις?
Θα την πάρω εγώ Γιάννη μόλις τελειώσει το βάψιμο...![]()
Ποια την 656 η την W4000?:ernaehrung004:
Eγω περιμενω να με ενημερωσουν για τιμη απο ενα καταστημα οποτε δεν την παράγγειλα ακομη.
Στα 1830Ε η 46Α656?Ακομα και ετσι παλι η 46W4000 κατω απο τα 1750Ε είναι..
Πάντως κοντά στα 1830 είναι 46Α656?
Η 46W4000 πόσο πιο φτηνή να είναι..
