- 3 March 2009
- 4,065
Τι χαμός είναι αυτός.
Δεν ξέρεις τι να πρωτοδιαλέξεις, δεν ξέρεις τι να πρωτοδιαβάσεις.
Υπάρχει και αυτή η επιλογή, νήμα μεγάλο στο diyaudio.
Μπορεί καποιος να μας πει περιληπτικά τα προτερήματα και μειονεκτήματα σε σχέση με τα: Amanero, και τις 2 υλοποιήσεις του Κινέζου;
Product Highlights
Asynchronous USB interface:
Driver Support:
* No drivers needed for MAC OS version 10.6.4 and above
USB and digital audio outputs:
User interface and signaling:
Hardware and layout:
Product Highlights
- USB Audio Class 2 compatible
- Low latency (sub 3µs in the best case)
- 16 to 24 Bit-transparent reproduction
- 44.1 to 192 kHz standard sample rates supported
- Built with XMOS processor running @ 500 MIPS
Driver Support:
- No drivers instalation required for Linux with UAC2 compliant kernel
- ASIO/KS/WASAPI/Direct Sound drivers for Windows XP to 8 (32 and 64 bit)
- Fully featured Thesycon driver package (without 30 min. periodic beeps)
- Latest version of Windows drivers can be downloaded from here.
- On board gold plated USB-B connector
- 5 pin header for off-board USB socket.
- Isolated I2S port using Giant Magneto Resistive (GMR) isolators
- Non-isolated I2S port by means of 6GHz U.FL mini BNC sockets
- 75R isolated and non-isolated SPDIF outputs
- all I2S/SPDIF outputs are working in parallel
- LEDs for sample rate display (44.1, 48, 88.2, 96, 176.4 and 192 kHz),
- “Host Active” signal available when card is plugged in and recognized by the host
- “Audio Stream” output is enabled when there’s streaming over USB Bus
- Green power-on LED
- 4-layer gold-plated PCB with 1/2/2/1 oz copper thickness
- careful routed PCB layout to preserve signal’s integrity
- Seven linear low-noise, LDO voltage regulators
- Three LP5900 LDOs (6.5µVrms) powers the oscillators & surrounding logic
- High quality parts including OsCON SVP & NPO/COG caps
- Two ultra-low phase noise japanese made oscillators
