Παιδια να σας ρωτησω. Πιστευετε οτι αξιζει να δωσω το LG390 και να παρω αυτο? Μονο και μονο για το bluray iso και τα m2ts. Επισης για τα καινουργια mkv με header compression?
H' να παρω ενα bluray recorder με ενα επανεγραψιμο δισκο 50gb?
Δηλαδη
Η' 170 για το xtreamer
Η' 100 για το recorder
Με το youtube τι παιζει?Το ξηλωσαν?Εαν οχι HD youtube παιζει?
πισης περα απο bluray iso παιζει και folder?
Υπαρχει κατι αλλο σε αυτην την τιμη που να προσφερει περισσοτερα?
xLive Changelog - v9.1 > v9.2
Version summary:
csb: The first, very tentative update in a long time. I'm trying to slowly take over Cap's project. This is a mostly a hotfix to fix freezes and crashes!
*Thank you, Cap, for all your great work and I hope you are well, wherever you may be.*
01) Forcing the "classic" web-player for all channels. This should prevent most freezes, lock-ups and crashes for the time being.
I'm planning to re-enable the full and more comfortable player for all stable and reliable content in the future.
(This change only affects firmware 2.4.2 and higher)
02) Internal refactoring of the main menu.rss. This should eventually make it much more flexible and configurable. I'm hoping that there is no notable performance hit when opening the Xtreamer Live main menu.
03) Support for localized content! If your OSD-language is switched to "German" there will be new button linking to my German feeds and videos.
I'm planning to add a lot more different languages in the future. If your OSD-language is set to anything but German, you shouldn't be able to see it.
If you want to forcefully enable this button, simply change createGermanButton=0 to createGermanButton=1 in the menu.rss
Caveats / Known Bugs:
- There appears to be a minor problem with the auto-updater that I previously wasn't aware of: It may corrupt files that were bigger than their updated version.
This should hopefully be fixed in future firmware versions and I'll try to include a workaround in future version of xLive. The bug shouldn't really affect the upgrade from an unmodified 9.1 -> 9.2 too much. If you are experiencing any problems, simply delete your /scripts/xLive folder and re-download. Everything should be fine that way.- As mentioned earlier, there is no new content (other than the German test-entry for localized content) and no broken feeds have been removed yet. I'll get around to it, I promise.
Ναι. Το επόμενο.... Xtreamer Super Pro ( που δεν βγήκε ακόμα)
'Οπως φαίνεται και από το mediainfo, είναι format VP 6, που ως γνωστόν, δεν το υποστηρίζειΤο πρώτο αρχείο που έφαγα "πόρτα" : Unsupported Video file
ένα αρχείο .flv
Και flv να το αφήσεις, αν μετατρέψεις το format σε κάτι άλλο (πχ AVC) θα το παίξει.Τι είναι αυτό το φορμάτ; τόσο extreme είναι;
Αν μετατρέψω το αρχείο π.χ. σε .mkv, .wmv θα παίξει ή από την στιγμή που είναι φτιαγμένο με VP6 το ξεχνάω;
Πως γίνεται αυτό; έχεις να προτείνεις κανά προγραμματάκι;
