Zidoo X9S (4K,HDR,3D,Blu ray Menu,HD Audio)
Re: Απάντηση: Zidoo X9S (4K,HDR,3D,Blu ray Menu,HD Audio)
Blu-ray δομή σε 4K παίζει;
Δοκίμασα και έμεινε να γυρίζει η ροδέλα επ' άπειρον......
Εννοείται το έπαιξε μια χαρά σε απλό play χωρις μενού κλπ
Ακριβώς έτσι και το Χ10 σε μερικα bd
New poster version 2.6.1 (the latest version from z9s,works on x9s).
1. Optimize the display of the details interface and the movie video
2. Optimize segmented video scanning
3. Optimize scanning to solve the problem that stopping scanning during scanning may cause unmatched videos to not match properly when continuing scanning
4. Solve the problem that the child lock set is not displayed synchronously after the movie rating is initially set
5. Increase the HDR corner mark (scanned videos will not be displayed)
6. Optimize file name recognition
7. Optimize application stability
8. Optimize bracket processing for title recognition
9. Added trailer filter filtering, the word 'trailer' in the file name will no longer be scanned
10. Optimize the NFS mount method
New poster wall version 2.6.3 (the latest version from z9s,works on x9s).
1. Fix the problem that the background service causes the setup wizard language to be incorrect
2. Fixed the problem of disordered video in the folder video list interface
3. Fixed the problem that poster information cannot be obtained based on the file path
4. Fixed the problem that the total number of videos on the device does not change after moving the video out of the poster wall
5. Clear device and delete device will remove related video information from database
6. Fixed the issue that the poster does not refresh after modifying the rating of the child lock
7. Child lock setting interface adds function description and child lock reset function
8. Optimize the collection function
http://forum.zidoo.tv/index.php?attachments/zidoo_poster-apk.3913/
Την αναβάθμισα και παίζει άψογα!
https://sage.makefast.co/dl/n2N6NfDtaraLvXnZlSt-Eg/1578991605/522907225/5e14456b1a3e85.39868969/zidoo_poster.apk
Όχι απλώς κάνει update, έχω και iso κσι folder και παίζει μια χαρά...δεν χάνεις την βιβλιοθήκη, απλώς καλώς είναι να κάνετε backup που και που...
Εντάξει το πέρασα. Μια χαρά όλα τα πόστερ στην θέση τους.
Βεβαια εξακολουθεί να μην παίζει bd menu. Δοκίμασα και με τον nuplayer και με τον native player . Γυρνάει το μπλε κυκλάκι και σε 10 δευτερόλεπτα με πετάει πισω στο εξώφυλλο της ταινιας.
Model: ZIDOO_Z9S
Version number: v2.3.10 :grinning-smiley-043
Changelog
(From here, translation via Google Translate.)
(original text below)
System
1. Optimize the problem of the USB 3.0 port even if the device is lost
2. Fix DTS full-track music can not play problems
3. Repair HIFI music sporadic automatically at a problem can not be played
4. Optimize online play
The "information" button to display the current HDMI output
6. optimized music pause play DTS sound unusual problem
7. Repair HDMI output is set to source output, Bluetooth devices abnormal sound problems
8. Repair very few sources, Dolby Atmos audio playback of the Caton problem
9. DLNA voted screen function optimization
File manager
1. Fix the problem that the same share name is displayed in NFS (for Usbshare multiple external hard disk cabinets, only one can be found)
2. Cancel the top navigation classification, increase circulation list
3. Increase CD-ROM into tips
4. Optimize sorting function (save separately by path)
5. Added the function of pressing "Popup" to return to the top of the list
6. Fixed the problem that the played video does not prompt the watched icon
7. Modify the problem that the volume label does not display more than 20 characters
Poster wall
11. Fix the problem that the background service causes the setup wizard language to be incorrect
12. Fixed the problem of disordered video in the folder video list interface
13. Fixed the problem that poster information cannot be obtained based on the file path
14. Fixed the problem that the total number of videos on the device does not change after moving the video out of the poster wall
15. Clear device and delete device will remove related video information from database
16. Fixed the issue that the poster does not refresh after modifying the rating of the child lock
17. Child lock setting interface adds function description and child lock reset function
18. Optimize the collection function
19. Fixed the issue that playback records cannot be saved when playing NFS source
20. NFO added sorttitle field support, only use this field for sorting in movie collection interface
music player
1. Optimize folder browsing function
2. Add CD playback function (requires external optical drive)
3. Optimize the sorting function
4. Optimize the calculation method of scanning progress
5. Optimize track identification for SACD and CUE albums
6. Improved the interface of obtaining track list, and solved the problem that the mobile phone cannot control the CUE / DSF track list of the temporary list
7. Modify the time display format of CUE to keep the same with SACD
8. Optimize focus control logic to solve the problem of focus flicker
9. Modify the recording method of the playlist to solve the problem that the last song in the random play mode will replay randomly
10. Added screen saver function in play details interface
11. Fixed an issue where the list interface displayed an error after the grid layout removed the list
12. Fixed the problem of getting albums when playing music from file manager
13. Fixed the problem that the lyrics could not be closed without playing the details interface
14. Fixed the problem that sometimes the detailed interface picture cannot be obtained
15. Added automatic full-screen playback switch
16. Added music file information display to the list
17. Solve the problem that search interface focus may be lost
18. Fix the problem that the song is cut abnormally in the playback interface
19. Modify singer details interface
**-Add album sub-categories, you can directly enter album details from the list
**-Add picture subclasses, you can set the default, delete and add operations for pictures
**-Add details sub-category, you can browse all the information of the singer
20. Add "View Artist" and "View Album" functions
21. Add song names that do not match the file name "track + number"
22. Fixed the problem of flashing back when pressing the "Home" key in the folder song interface
23. Fix the problem that Bluetooth remote control connection stops playing
24. Add multi-folder scanning. The abnormality will be displayed after the scanning is completed, and the normal display will be restored after all scanning
25. Fix the problem that the time of the song displayed on the front panel is incorrect
26. Fix the problem that the sample rate of the playback details interface is incorrect.
27. Fix the problem that some DTS-CDs cannot be played
Local player
1. The problem that the optimized bit rate is displayed incorrectly
2. Fix the problem that the movie name is displayed incorrectly
3. Add ZOOM function
4. Increase the video ratio
5. Fixed the issue that Polish subtitles are displayed in Portuguese
6. Optimized subtitle download function
7. Optimize the front panel USB icon display
8. Optimize the problem that DVD cannot select chapters
9. Optimize ASS subtitle display
10. Fixed the problem that the srt subtitle space is not displayed completely
11. Fixed the problem that the file name of the DVD folder was displayed abnormally during playback
12. Optimize the setting of video scale interface display
13. Add sequence play function
Blu-ray navigation
1. Added the function of subtitle track list displayed by shortcut keys
2. Optimize subtitle download function
3. Fixed the problem of incomplete display of srt subtitle space
Quick settings
1. Add ignore EDID function
2. Increase video playback order
Scheduled shutdown
1. Modify the problem that the traditional display is abnormal
Picture Manager
1. When optimizing the slideshow, the picture is blurred
the weather
1. Optimize the problem that the weather is not available in some cities
Mobile APP (need to update mobile app v.1.5.5)
1. Add audio offset setting in the setting interface
2. Folder browsing function has been added to the music device interface
3. Application interface adds sorting function
4. Fixed the problem that the same device is repeatedly added to the music device interface
5. Fixed the issue that the CUE / DSF track list cannot be obtained from the temporary list songs
6. Optimize the problem that the application interface icon is not displayed
7. Optimize poster wall interface display
8. Solve the problem that the file management is affected by the search bar, and it will return to the upper directory when rescanning SMB or NFS
9. File manager adds list refresh function
10. File Manager adds CD-ROM drive list
Posted on @ZidooNews
Χαζομάρα μου ..
Απολογούμαι !!
Ας το μεταφέρει ο συντονιστής στην φυσική του θέση .
Προς το παρόν ναι, μόνο για το Z9s/Z10 αν και πιστεύω πολύ σύντομα να δούμε κάτι σχετικό και για το x9s.
Θα σας ενημερώσω..
(Αυτη την φορα το 'σωστο'... :ears:)
Νεο λογισμικο για την οικογενια Χ9S/Χ10, εχουμε το v2.1.36
Model: ZIDOO_X8 / X9S / X10
Version number: v2.1.36
Changelog
System
1. Add the "Information" button on the remote control to display the current HDMI output information
2. Optimize DLNA projection function
2. Optimize system stability
File manager
2. Cancel the top navigation category and add the list rotation function
3. Added CD disc insertion tips
Poster wall
Music player
6. Improved the interface of obtaining track list, and solved the problem that the mobile phone cannot control the CUE / DSF track list of temporary list
9. Modify the recording method of the playlist to solve the problem that the last song in the random play mode will be rerandom.
Local player
1. Add sequence play function
2. Fixed the issue that subtitles in Polish are displayed as Portuguese
3. Optimize subtitle download function
4. Optimize the problem that DVD cannot select chapters
5. Optimize ASS subtitle display
6. Fixed the problem that the srt subtitle space is not displayed completely
7. Fixed the problem of displaying the DVD folder format and file name abnormally
Blu-ray navigation
Quick settings
1. Modify DMR switch settings
2. Add video sequence playback function
Picture manager
The weather
-----------------------------ž–
Οπως παντα θελει λιγη προσοχη γιατι ειναι.. beta :2thumb22sup:
δεν μ αφηνει να ο κανω εγκατασταση,μου βγαζει μνμ NOT enough space....
ο ελευθερος χωρος που εχω ειναι 8 γιγα,,,,, η μονη εφαρμογη που εχω ειναι το kodi me 1 γιγα και το android system me 14 giga...
Αυτό το μηχάνημα έχει αυτονομηθεί εντελώς,
στον καθένα βγάζει διαφορετική συμπεριφορά και bugs.
Σε εμένα δεν παίζει το music player από το 2.1.28 και μετά.
'Οταν λέω δεν παίζει, εννοώ καθόλου.
Οπότε, δοκιμάζω τα καινούργια μπας και...
αλλά πάντα το γυρίζω στο 2.1.25.
Και τώρα αυτό κάνω, Κινέζος βελονιστής έγινα με αυτό το μηχάνημα...
Από το λίγο που το δοκίμασα, αυτό που άλλαξαν το top navigation με το list rotation στο file list είναι και χρήσιμο και αυτονόητο.
Διαχειρίζεσαι μία λίστα είτε από την αρχή, είτε από το τέλος.
Το αν οι πολωνικοί υπότιτλοι εμφανίζονται ως πολωνικοί και όχι ως πορτογαλικοί, δεν το τσέκαρα.
Και η προηγούμενη .30 beta δεν ήταν; βγήκε καινούργια και είναι πάλι beta;
Αυτά τα firmware είναι επίσημα της zidoo; ρωτάω γιατί στο φόρουμ στο νήμα "X10 Official Firmware Releases" η τελευταία
official είναι η .25. Οι δύο τελευταίες beta είναι στα γενικά θέματα από κάτω.
Απάντηση: Re: Zidoo X9S (4K,HDR,3D,Blu ray Menu,HD Audio)
Ολες 'Official' -ΒΕΤΑ- ειναι...
Απο αυτους μας δινονται-διαρρεονται..
Απλα ως χαρακτηρισμενες -beta τους λυνουν τα χερια απο πολλες αποψεις.
Οταν δεν υπαρχουν πολλες γκρινιες-μουρμουρες χαρακτηριζονται -official.
Εσεις απλα να ελεγχεται ΟΠΟΣΔΗΠΟΤΕ το MD5 για να ειστε βεβαιοι οτι κατεβαινουν σωστα.
'''Συντομα''' ερχεται μεγαλο update οπου και θα λυσει 'ιακονποιητικα' και το θεματακι με το seemless.
Πάντως οι Κινέζοι με εκπλήσσουν με το support τους. Το μηχάνημα έχει βγάλει τα λεφτά του και με το παραπάνω.
Από ότι κατάλαβα πρόκειται για ήμι-επίσημη υποστήριξη σε παλιότερα μοντέλα, που μάλλον έχει σταματήσει η κανονική υποστήριξη.
Πάλι καλά γιατί πριν από μερικά χρόνια είχαν κράξει τη zidoo στα φόρουμ για εγκατάλειψη των παλιότερων μοντέλων μόλις έβγαζε το
καινούργιο.
