Re: AZBOX Me & MINI ME
http://www.youtube.com/watch?v=6_RRcjXLeEY
http://www.youtube.com/watch?v=9ywkrPtyx2Y
http://www.youtube.com/watch?v=oV4EijIss1U
Δε ξέρω τι ισχύει αλλά το tuner του azbox me λένε θα είναι ή το
Availink : AVL2108 for DVB-S2
Code:
● Advanced demodulation technology achieves 120Mbps (45 MSps) 8PSK data rate which is 150% of similar products
● Powerful LDPC/BCH FEC decoder for all-weather signal reception
● Typical power consumption is less than 850mW. No exposed pad required.
● Fast acquisition allows wide frequency uncertainty
● Robust timing and frequency synchronization accommodates low-cost LNB
● Robust symbol timing recovery loop and carrier tracking loop to handle the worst case phase noise
● Compact 12x12mm LQFP 80-pin package.
● Automatic identification of modulation mode and FEC code rate reduces workload of host software
● Fully compliant with DVB-S2 standard broadcast profile, supports QPSK and 8PSK demodulation
● Fully supports DVB-S legacy standard
● Symbol rates from 1MSps to 45MSps for all modes including 8PSK modes
● FEC decoder code rates: DVBS-2: 1/2, 3/5, 2/3,3/4, 4/5, 5/6, 8/9, 9/10, DVB-S: 1/2, 2/3, 3/4, 5/6,7/8
●Signal quality monitor and lock detector
●Automatic blind signal identification scan for all
supported modes
●Integrated dual ADC with DC component cancellers, IQ imbalance compensator, and phase imbalance compensator
● Built-in RF AGC circuit, directly interfaces with a variety of tuners
● DiSEqC™ 2.0 compatible LNB controller interface
● Parallel/serial output data interface, output bit stream retiming
● Standard two-wire serial bus with four selectable addresses
● Power saving mode
που απ'ότι διαβάζω έχουν οι δέκτες
et9000
qboxhd
coolstream hd1 ( neutrino hd )
ή το
Sony CXD2820R
http://www.sony.net/Products/SC-HP/cx_news/vol60/pdf/cxd2820r.pdf
Code:
CXD2820R - The World's First Demodulator LSI for "DVB-T2" Terrestrial Digital Broadcast Standard
The CXD2820R is a demodulator LSI for high-definition television use conforming to the "DVB-T2"
(Digital Video Broadcasting - Terrestrial 2) terrestrial digital broadcast standard adopted in the UK.
This LSI is the world's first*1 demodulator LSI for "DVB-T2"*2, compatible with three standards
("DVB-T2", "DVB-T"*3 and "DVB-C"*4) contributing to product miniaturization and reduction of components.
Codice:
*1 Based on Sony research (as of February, 2010) *2 Second generation terrestrial digital broadcast standard. This is the improved version of the first generation "DVB-T". Digital sound and video signals are transmitted using orthogonal frequency-division multiplexing (OFDM) digital modulation. Using a time interleaver and LDPC code (a kind of error correction system) improves the transmission efficiency by approximately 50% compared with "DVB-T". *3 First generation terrestrial digital broadcast standard. This standard is adopted in various countries and regions around the world including Europe. Digital sound and video signals are transmitted using orthogonal frequency-division multiplexing (OFDM) digital modulation. *4 Cable digital broadcast standard. This standard is adopted in various countries and regions around the world including Europe. Digital sound and video signals are transmitted using quadrature amplitude modulation (QAM) digital modulation.
[B]
* Supports reception of "DVB-T2" broadcasts
* Supports "DVB-T" and "DVB-C" demodulation
* Supports multiple-PLP
* Low power consumption
* Compact 64-pin LQFP package[/B]
Λέγεται ένας τρόπος αναβάθμισης του firmware θα είναι αυτός
The method of installing the firmware on the new receivers is quite simple:
Everything will be possible from web page (dreambox style) without the help of external programs (such azup).
then:
- Turn off the power
- Turn the receiver on the front of the receiver and press vol +
- Will see the ip address
- Open the preferred broswers (chrome, firefox, opera, ie)
- Type the ip and you will have the web page sections to install the new firmware (the web interface that draws a lot of dream)
- To install over the receiver will restart and you will have the new release date
Most likely, this mode of installation is also implemented for the old receivers, if so, the next firmware (rti core 1.3) will be installed with the latest firmware azup.
Επίσης
well, something that is not the most interesting .. but the receiver is designed to perform 3 different boot without risking brick and receiver. also use the latest mrua. There will be good news for those used with the dream as well as those who would not abandon Sigma.
Στο multimedia part και στο android menu φαίνονται ομοιότητες με αυτό
http://www.1e2.it/2011/08/hardware/dvico-tvix-xroid-a1-android-media-player-recensione-opinioni.html
πηγή:azboxhd.it
