Dune HD Homatics Box R 4K Plus (Netflix in 4K DV Atmos, ISO 4K DV P7 FEL (!)
chocbhed
26 August 2007
579
Δεν είμαι κάτοχος του συγκεκριμένου αλλά προηγούμενου μοντέλου αλλά τα μενού σε πολύ μεγάλο ποσοστό είναι τα ιδια
nakata
11 June 2007
2,236
var/etc/home
Σε αντίθεση με την υποστήριξη του λογισμικού όπου κατά δήλωση της DUNE οι ενημερώσεις (firmware updates) δεν αναμένεται να ειναι συχνές.
Firmware updates pass through a long Google/Netflix certification, and usually are not expected to be frequent.
Η υποστήριξη της δικής της εφαρμογής Dune HD Media Center έχει σε διάστημα ενός μηνός τρεις ενημερώσεις.
Reactions: vadergr
nakata
11 June 2007
2,236
var/etc/home
Νεο firmware v11.8.4674
καθως και αναβαθμηση του dune mefia center.
230404_2222 (beta):
Fixed: With the Dune HD Media Center app installed (and the accessibility service enabled), remote control button handling could sometimes become slower when running other Android applications.
Fixed: HTTP port changed from 10080 to 11080. This fixes the issue of not being able to use the web interface of plugins due to port 10080 being blocked in the Chrome browser and other browsers. If some plugins were using the hardwired port number 10080 instead of correctly using the HTTP_PORT variable, they should now be changed.
Fixed: When accessing via SMB/NFS folders that have been colored using the dune_folder.txt mechanism, the folder design could sometimes be displayed incorrectly.
Fixed: The quality of posters in "My Collection" was degraded due to unnecessary incorrect processing.
Added: A new setting (My Collection - Data Storage - Poster Quality) allows to download posters in even better quality for My Collection. This setting is disabled by default because it requires more disk space for the posters and can affect performance.
Added: A new setting (Playback - Preferences - HLS/DASH starting bandwidth) allows you to choose the starting bitrate for adaptive HLS and DASH streams.
Added: When you click the Play... button on the Movies screen in the Movies or Series sections, if more than one source is available, you will be prompted to select a source (even if the movie was selected in a specific source's subsection ).
Reactions: avlovers
iandros
11 April 2011
3
Καλησπέρα σας
Αγόρασα επιτέλους το Dune HD Homatics R 4K Plus .Το πρόβλημα (και αν μπορείται να με βοηθήσετε) είναι ότι σε ταινίες που έχουν ήχο DTS δεν έχω ήχο.
Ουσιαστικα δεν γίνεται η αποκωδικοποιηση του DTS . Σημειώστε ότι έχουν γίνει οι απαραιτητες ρυθμίσεις στο μηχανημα,οπως και στο Dune application ,
SYSTEM = Passthrough, DUNE = Bitstream.
Στη θέση του Homatics είχα πιο παλια το Media Tank Popcorn Model A-110 και επαιζαν κανονικα τανειες με hxo DTS .
nakata
11 June 2007
2,236
var/etc/home
Καλησπέρα σας
Καλορίζικο. Δεν ξέρω τι ακριβώς έχεις κάνει άλλα εφόσον το σύστημα σου υποστηρίζει DTS θα πρέπει να επιλέξεις στις ρυθμίσεις του android στο display & sound / advanced sound settings / select formats / passthrough και οχι automatic, αλλά το μέγιστο που μπορείς παρεις είναι dts core.
Επίσης αν θες να δεις τι ακριβώς ηχο σου περνάει υπάρχει το εξης κολπο πας στα settings /device preferences / about / kernel version και πατάς το ok πέντε φορές αμέσως μετά πατάς δεξί βελάκι / αριστερό βελάκι / και ξανά δεξί βελάκι μόλις σου ανοίξει το κρυφό μενού επιλέγεις video info overlay.
Reactions: vadergr
iandros
11 April 2011
3
Σε ευχαριστώ για την ανταπόκριση σου.
Όντως έτσι ειναι προγραμματισμένο. Σου στέλνω φώτο
iandros
11 April 2011
3
Ακριβως .Όπως σου ειπα ,πριν μια βδομαδα επαιζα ταινιες με το Popcorn Model A-110 και ειχα κανονικα DTS
Στο Dune Application στο set up /Audio εχω Bitstream
Το ιδιο και στο VLC Digital Audio Output (passthrough)
Στο Kodi /Audio /Allow passthrough
Κανενα απο τα τρια δεν εχει ηχο DTS
Εχει καποιο λαθος?
nakata
11 June 2007
2,236
var/etc/home
Δοκιμασα αρκετούς συνδυασμούς ρυθμίσεων μπας και τα καταφέρω να μην πάρω ήχο DTS, και δεν τα κατάφερα, όποτε στο μόνο που πάει ο νους μου είναι το πρόβλημα να μην προέρχεται αο το DUNE αλλά από τον ενισχυτή σου αν θες ρίξε μια ματιά στις ρυθμίσεις του μήπως και συνδέοντας το DUNE έκανε κάποια αλλαγή από μόνος του και τα ξαναλέμε.
nakata
11 June 2007
2,236
var/etc/home
Νέα έκδοση του Dune HD media center. Συμβατή με όλα τα μοντέλα της DUNE εκτός από το BOXY το οποίο έχει δική του έκδοση.
230429_1350 (beta):
  • Fixed: When running AFR, video mode would sometimes not be restored after playback was stopped.
  • Fixed: When AFR was running, a crash could occur in some cases due to the change in EDID information when the AVR was turned off.
  • Fixed: Some audio files in DTS CD format were choppy.
  • Fixed: Some DTS CD audio files played with noise instead of sound.
  • Fixed: Some MPEG-2 files did not play correctly.
  • Fixed: For some MPEG PS files, duration detection did not work correctly.
  • Fixed: Default subtitle size was too small.
  • Fixed: Fixed handling of font size for AAS subtitles.
  • Fixed: Display of Arabic characters in subtitles did not work.
  • Fixed: The UP remote button on the first playlist item did not allow jumping to the last item.
  • Fixed: With DUNE accessibility service enabled, some gamepads didn't work correctly.
  • Fixed: Changing the HTTP port from 10080 to 11080 (which was done in the previous version) did not work correctly and some plugins were broken.
  • Fixed: After setting up the TV application for the first time for the New GUI, the display of the current element in the GUI was lost.
  • Fixed: Displaying icons for groups of TV channels in TV playback mode could work incorrectly in case of a large number of groups.
  • Fixed: Adding a TV channel to favorites while playing TV might not update the information in the main menu correctly.
  • Fixed: File manager operations on a large number of files (for example, copying or moving thousands of files) could cause memory leaks.
  • Fixed: Initial internet check might work sometimes not work correctly.
  • Added: Ability to set custom TTF fonts for subtitles by running a TTF file in a file browser (as it was previously supported on regular models).
  • Added: For Developers: Ability to play CENC-encrypted streams with an explicit encryption key specified via the new dune_param "decryption_key" parameter. The feature is available as part of Dune Extra.
  • Added: Support for new Dune HD media player models.
  • Internal changes.
Reactions: vadergr
john18625
6 December 2009
11
Καλησπέρα σας. Μετά από πολλα χρόνια με το Mede8er MED800x3D, αποφάσισα να πάω στο Dune HD Homatics Box R 4K Plus. Εχω πρόβλημα με το NFS. Δεν έχω πρόσβαση στους σκληρούς του υπολογιστή μέσω LAN. Ενω τους βλέπω βγαίνει μνμα για να ανοίξω non-privileged ports. Χρησιμοποιώ στο pc το haneWIN NFS Server. Παραθέτω εικόνα για να γίνω πιο κατανοητός.
Ποια ports πρέπει να ανοίξω; Δεν υπάρχουν τετοιεσ επιλογές στον NFS server. Καθε βοήθεια ευπρόσδεκτη!!!
nakata
11 June 2007
2,236
var/etc/home
Καλά πάμε προς το παρόν.
Info came from the Chinese version of WeChat forwarded by Yong Ge on the Telegram group. They said "This is a notification released by the manufacturer in China."
Reactions: vadergr
