hristoslav2
Panasonic UltraHD TV 2016 | |||||||||||||||
Product | UHD Premium | Dolby Vision | HDR _____________________ | Videopanel - LCD matrix ___________________________________ | Backlight _____________________________________Dimming | Color Space _____________________________ | Contrast _________________________________White & Black level | Viewing angle _____________ | Input Lag _________________________________ | SoC _________________software OS | Conectors _________________ | Networks _______________________________ | Tuner _______________________________ | Picture Accuracy Out-of-the-Box (score out of 10) _______________ | Product |
CZ950 65" OLED | Yes | No | 65" - | Oled, WRGB, 10bit, 120/100Hz | No | 65" - | 65" - ∞ / 130cd/m2 / 0.00cd/m2 | - - - | - - - | Lan - Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Bluetooth Wi-Fi Direct DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS) | 2 x DVB-C/T2/S2, 1 x SAT>IP Client & Server DVB-T2: HEVC H.264 и H.265 Analog (PAL,SECAM) 2 x CI+1.3 HEVC VP9 | CZ950 | |||
DX900 58", 65" | Yes | No | 65"- max 1250cd/m[SUP]2[/SUP] 58"- max 1320cd/m[SUP]2[/SUP] Yes HDR10 SMPTE standards ST2084, ST2086 | 65"- SMVA, 10-bit, 120/100Hz + MCFI 58"- SMVA, 10-bit, 120/100Hz + MCFI | 65"' - FALD - 512 zones (32 columns x 16 rows) 58" - FALD - 512 zones (32 columns x 16 rows) Honeycomb backlight structure Blue Leds (actually white LEDs "boosted" with red phosphorus) (BLS - Backlight Scaning) + (BFI - Black Frame Insertion) 6 cooling fan backlight | 65"- DCI P3 - 98% / Rec.2020 - 78% 58"- DCI P3 - 96% / Rec.2020 - 74% | 65" - 5360:1 / 134cd/m2 / 0.025cd/m2 58" - 4600:1 / ---- cd/m2 / 0.023cd/m[SUP]2 [/SUP] | 65" - 42°(cone) 58" - 46°(conе) | 65"- Game mode -41ms / by default-51ms 58" - | Quad Core P163 Firefox 2.5 | Bluetooth Ver. 4.0 (keyboards, mouse) 1 x Ethernet RJ45 2 x USB 2.0 (max500mA) 1 x USB 3.0 (max900mA) 1 x Ethernet RJ45 1 x HDMI 1.4 (CEC) 2 x HDMI 2.0 (ARC,CEC) 1 x Satelite In (Main: F-type female) 1 x Satelite In (Sub: F-type female) 1 x AV Composite In 1 x AV Component In 1 x Optical Audio Out 1 x 3.5mm Audio Out 1 x Antena (RF)female 1 x CI+ 1.3 Card reader SD/SDHC | Lan Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Wi-Fi Direct DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS) | 2x DVB-C/T2/S2, 1 x SAT>IP Client & Server DVB-T2: HEVC H.264 и H.265 Analog (PAL,SECAM) 2 x CI+1.3 HEVC VP9 | 9 | DX900 |
DX800 58", 50" | Yes | No | 58" - max...cd/m[SUP]2[/SUP] 50" - max...cd/m[SUP]2[/SUP] Yes HDR10 SMPTE standards ST2084, ST2086 | 58"- SMVA, 8-bit+Hi-FRC, 120/100Hz + MCFI 50"- SMVA, 8-bit+Hi-FRC, 120/100Hz + MCFI | 58" - Edge Led 50" - | 58"- 50"- | 58"- 50"- | 58" - 50" - | 58" - 50" - | Quad Core P163 Firefox 2.5 | Bluetooth Ver. 4.0 (keyboards, mouse) 1 x Ethernet RJ45 2 x USB 2.0 (max500mA) 1 x USB 3.0 (max900mA) 1 x Ethernet RJ45 1 x HDMI 1.4 (CEC) 2 x HDMI 2.0 (ARC,CEC) 1 x Satelite In (Main: F-type female) 1 x Satelite In (Sub: F-type female) 1 x AV Composite In 1 x AV Component In 1 x Optical Audio Out 1 x 3.5mm Audio Out 1 x Antena (RF)female 1 x CI+ 1.3 Card reader SD/SDHC | Lan Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Wi-Fi Direct DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS) | 2 x DVB-C/T2/S2, 1 x SAT>IP Client & Server DVB-T2: HEVC H.264 и H.265 Analog (PAL,SECAM) 2 x CI+1.3 HEVC VP9 | DX800 | |
DX780 65", 58", 50" | No | No | 65" - max......cd/m[SUP]2[/SUP] 55" - max 577cd/m[SUP]2[/SUP] 50" - max .....cd/m[SUP]2[/SUP] Compatible HDR processing (but no hardware for HDR) | 65" - SMVA, 8-bit+FRC, 120/100Hz + MCFI 58" - SMVA, 8-bit+FRC, 120/100Hz + MCFI 50" - SMVA, 8-bit+FRC, 120/100Hz + MCFI | 65" - Direct Led, Local Dimming 58" - Edge Led (below) Vertical Dimming 50" - Edge Led (below) Vertical Dimming | 65" - 58" - 50" - DCI P3 - 89% / Rec.2020 - 66% | 65" - 58" - 50" - | 65" - 58" - 50" - | 65" - 58" - 50" - | Quad Core P163 Firefox 2.5 | Bluetooth Ver. 4.0 (keyboards, mouse) 1 x Ethernet RJ45 2 x USB 2.0 (max500mA) 1 x USB 3.0 (max900mA) 1 x Ethernet RJ45 1 x HDMI 1.4 (CEC) 2 x HDMI 2.0 (ARC,CEC) 1 x Satelite In (Main: F-type female) 1 x Satelite In (Sub: F-type female) 1 x AV Composite In 1 x AV Component In 1 x Optical Audio Out 1 x 3.5mm Audio Out 1 x Antena (RF)female 1 x CI+ 1.3 Card reader SD/SDHC | Lan (10BASE-T/100BASE-TX) Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Wi-Fi Direct DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS) | 2 x DVB-C/T2/S2, 1 x SAT>IP Client & Server DVB-T2: HEVC H.264 и H.265 Analog (PAL,SECAM) 2 x CI+1.3 HEVC VP9 | DX780 | |
DX750 65", 58", 50" | No | No | 65" - max 435cd/m[SUP]2[/SUP] 58" - max 550cd/m[SUP]2[/SUP] 50" - max 550cd/m[SUP]2[/SUP] Compatible HDR processing (but no hardware for HDR) | 65" - SMVA, 8-bit+FRC, 120/100Hz + MCFI 58" - SMVA, 8-bit+FRC, 120/100Hz + MCFI 50" - SMVA, 8-bit+FRC, 120/100Hz + MCFI very glossy panel | 65" - Direct Led, No Dimming 58" - EdgE Led (below), Vertical Dimming ? 50" - Edge Led (below), Vertical Dimming ? | 65" - DCI P3 - 94% / Rec.2020 - 58" - DCI P3 - 94% / Rec.2020 - 50" - DCI P3 - 86% / Rec.2020 - 66% | 65" - 4300:1 / 123cd/m2 / 0.03cd/m2 58" - 50" - 3795:1/ ---- cd/m2 / 0.29cd/m2 | 65" - 30° (cone) 58" - 50" - | 65"- Game mode-45ms / by default-106ms 58"- Game mode-44ms / by default-105ms 50"- Game mode-44ms / by default-105ms | Quad Core P163 Firefox 2.5 | Bluetooth Ver. 4.0(keyboards, mouse) 1 x Ethernet RJ45 2 x USB 2.0 (max500mA) 1 x USB 3.0 (max900mA) 1 x Ethernet RJ45 1 x HDMI 1.4 (CEC) 2 x HDMI 2.0 (ARC,CEC) 1 x AV Composite In 1 x AV Component In 1 x Optical Audio Out 1 x 3.5mm Audio Out 1 x Antena (RF)female 1 x CI+ 1.3 Card reader SD/SDHC | Lan (10BASE-T/100BASE-TX) Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Wi-Fi Direct DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS) | DVB- C/T2/S2 with PIP functions, PAP, PAT, PVR and Time shift Analog (PAL,SECAM) HEVC VP9 | THX & ISF sertification Accurate Colour Drive: 3DLUT with 8000 points corrections | DX750 |
DX730 58", 50", 40" | No | No | 58"- max....cd/m[SUP]2[/SUP] 50"- max 317cd/m[SUP]2[/SUP] 40" - max...cd/m[SUP]2[/SUP] Compatible HDR processing (but no hardware for HDR) | 58" - SMVA, 8-bit, 60/50Hz + BLB + MCFI 50" - SMVA, 8-bit, 60/50Hz + BLB + MCFI 40" - SMVA, 8-bit, 60/50Hz + BLB + MCFI very glossy panel | 58" - Edge Led (below) Vertical Dimming 50" - Edge Led (below) Vertical Dimming 40" - Edge Led (below) Vertical Dimming | 58" - 50" - 40" - | 58" - 50" - 4824:1 / 0.04cd/m[SUP]2[/SUP] 40" - | 58" - 50" - 42° (cone) 40" - | 58" - 50" - 40" - | Quad Core P193 Firefox 2.5 | 1 x Ethernet RJ45 2 x USB 2.0 (max500mA) 1 x USB 3.0 (max900mA) 1 x Ethernet RJ45 1 x HDMI 1.4 (CEC) 2 x HDMI 2.0 (ARC,CEC) 1 x AV Composite In 1 x AV Component In 1 x Optical Audio Out 1 x 3.5mm Audio Out 1 x Antena (RF)female 1 x CI+ 1.3 Card reader SD/SDHC | Lan (10BASE-T/100BASE-TX) Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Bluetooth Ver. 4.0 (keyboards, mouse) Wi-Fi Direct DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS) | DVB-T/T2/C Analog (PAL,SECAM) HEVC VP9 | DX730 | |
DX700 58", 50"'40" | No | No | 58" - HDR 350cd/m2 50" - HDR 350cd/m[SUP]2 [/SUP] 40" - Compatible HDR processing (but no hardware for HDR) | 58" - SMVA, 8-bit, 60/50Hz + BLB + MCFI 50" - SMVA, 8-bit, 60/50Hz + BLB + MCFI 40" - SMVA, 8-bit, 60/50Hz + BLB + MCFI very glossy panel | 58" - Edge Led (below), Vertical Dimming 50" - Edge Led (below), Vertical Dimming 40" - Edge Led (below), | 58" - DCI P3 - / Rec.2020 - 68.27% 50" - 40" - | 58"- 5736:1 / 153cd/m2 / 0.03cd/m2 3184:1 / 0.038cd/m[SUP]2[/SUP] ANSI - 2304:1 / 0.046cd/m[SUP]2 [/SUP] 50" - 4700:1 / 40" - | 58" - 40°(conе) 50" - 40" - | 58"- Game-49.8ms / by default-69.7ms 50"- Game 40" - | Quad Core P193 Firefox 2.5 | Bluetooth Ver.4.0(keyboards, mouse) 1 x Ethernet RJ45 1 x USB 2.0 (max 500mA) 1 x USB 3.0 (max 900mA) 1 x HDMI 1.4 (CEC) 2 x HDMI 2.0 (ARC,CEC) 1 x AV Composite in 1 x AV Component in 1 x Optical Audio Out 1 x 3.5mm Audio Out 1 x Antena (RF) female 1 x CI+ 1.3 | Lan (10BASE-T/100BASE-TX) WiFi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Wi-Fi Direct DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS) | DVB-C/T2/S/S2 Analog (PAL,SECAM) HEVC | 9 | DX700 |
DX650 58", 50",40" | No | No | 58" - 50" - 40" - No | 58"- SMVA, 8-bit, 60/50Hz + BLB 50"- SMVA, 8-bit, 60/50Hz + BLB 40"- SMVA, 8-bit, 60/50Hz + BLB | 58" - Edge Led 50" - Edge Led 40" - Edge Led | 58"- 50"- 40"- | 58"- 50"- 40"- | 58"- 50"- 40"- | Quad Core - Firefox 2.5 | 1 x Ethernet RJ45 1 x USB 2.0 (max 500mA) 1 x USB 3.0 (max 900mA) 1 x HDMI 1.4 (CEC) 2 x HDMI 2.0 (ARC,CEC) 1 x AV Composite in 1 x AV Component in 1 x Optical Audio Out 1 x 3.5mm Audio Out 1 x Antena (RF) female 1 x CI+ 1.3 | Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Wi-Fi Direct DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS) | DVB-T/T2/C Analog (PAL,SECAM) | DX650 | ||
DX600 55", 49", 40" | No | No | 55" - max 294cd/m2 49" - max...cd/m[SUP]2[/SUP] 40" - max...cd/m[SUP]2[/SUP] No | 55"- S-IPS, 8-bit, 60/50Hz + BLB 49"- S-IPS, 8-bit, 60/50Hz + BLB 40"- SMVA, 8-bit, 60/50Hz + BLB | 55" - Edge Led 49" - Edge Led 40" - Edge Led | 55"- 49"- 40"- | 55"- 49"- 40"- | 55"- 78° (cone) 49"- 40"- | - - Firefox 2.5 | 1 x Ethernet RJ45 1 x USB 2.0 (max 500mA) 1 x USB 3.0 (max 900mA) 1 x HDMI 1.4 (CEC) 2 x HDMI 2.0 (ARC,CEC) 1 x AV Composite in 1 x AV Component in 1 x Optical Audio Out 1 x 3.5mm Audio Out 1 x Antena (RF) female 1 x CI+ 1.3 | Wi-Fi 802.11 a 802.11 b 802.11 g 802.11 n 802.11 n 5GHz Wi-Fi Direct DLNA | DVB-T/T2/C Analog (PAL,SECAM) | DX600 | ||
Panasonic Full HD TV 2016 | |||||||||||||||
Product | UHD Premium | Dolby Vision | HDR _________________ | Videopanel - LCD matrix _________________ | Backlight Dimming ______________________ | Color Space _____________________________ | Contrast & Black level _______________________ | Viewing angle ____________ | Input Lag _____________ | SoC software OS _________________ | Conectors ______________________________ | Networks _______________________________ | Tuner _______________________________ | Picture Accuracy Out-of-the-Box (score out of 10) _______________ | Product |
DS630 50", 40", 32" | No | No | 50" - max - 362cd/m2 40" - max...cd/m[SUP]2[/SUP] 32" - max...cd/m[SUP]2[/SUP] No | 50"- SMVA, 8-bit, 120/100Hz + BLB + MCFI 40"- SMVA, 8-bit, 120/100Hz + BLB + MCFI 32"- ?, 8-bit, 60/50Hz | 50" - Edge Led 40" - Edge Led 32" - Edge Led Only globally (Adaptive Backlight Dimming) | 50"- DCI P3 - 74% 40"- 32"- | 50"- 4311:1 /0.038cd/m2 40"- 32"- | 50"- 40"- 32"- | - P162 my Home Screen 1.0 | Bluetooth 3.0(2.402GHz-2.480GHz) 1 x Lan Ethernet RJ45 3 x HDMI 1.4 (CEC) 2 x USB 2.0 (max500mA) 1 x mini Jack (3.5mm) stereo 1 x SCART 1 x Component (RCA PIN type) | (10BASE-T/100BASE-TX) Wi-Fi Wi-Fi Direct DLNA 802.11 a/n 5.180GHZ-5.320GHz,5.500GHz-5.580GHz 5.660GHZ-5.700GHz 802.11 b/g/n 2.412GHz-2.472GHz Security WPA2-PSK(TKIP/AES) WPA-PSK(TKIP/AES) WEP(64-bit/128-bit) | DVB-T/T2/C 1 x SAT>IP Client & Server Analog (PAL,SECAM,NTSC) No HEVC | DX630 | ||
DS600 50", 40", 32" | No | No | 50" - max...cd/m2 40" - max...cd/m2 32" - max...cd/m2 No | 50" - , 8-bit, 60/50Hz 40" - SMVA, 8bit, 60/50Hz 32" - , 8/-bit, 60/50Hz | 50" - Edge Led 40" - Edge Led 32" - Edge Led | 50"- 40"- 32"- | 50"- 40"- 32"- | 50"- 40"- 32"- | - P161 - | Bluetooth 3.0(2.402GHz-2.480GHz) 1 x Lan Ethernet RJ45 3 x HDMI 1.4 (CEC) 1 x 1 x | (10BASE-T/100BASE-TX) Wi-Fi Wi-Fi Direct DLNA 802.11 a/n 5.180GHZ-5.320GHz,5.500GHz-5.580GHz 5.660GHZ-5.700GHz 802.11 b/g/n 2.412GHz-2.472GHz Security WPA2-PSK(TKIP/AES) WPA-PSK(TKIP/AES) WEP(64-bit/128-bit) | DVB-T/T2/C Analog (PAL,SECAM) No HEVC | DX600 | ||
DS500 55", 49", 40",32",24" | No | No | 55" - max...cd/m[SUP]2[/SUP] 49" - max 314cd/m2 40" - max...cd/m[SUP]2[/SUP] 32" - max...cd/m[SUP]2[/SUP] 24" - max...cd/m[SUP]2[/SUP] No | 55" - IPS, 8bit, 60/50Hz 49" - , 8-bit, 60/50Hz 40" - , 8-bit, 60/50Hz 32" - , 8-bit, 60/50Hz 24" - , 8-bit, 60/50Hz | 55" - Edge Led 49" - Edge Led 40" - Edge Led 32" - Edge Led 24" - Edge Led | 55"- 49"- 40"- 32"- 24" - | 55"- 49"- 882:1 / 40"- 32"- 24" - | 55"- 49"- 66° (cone) 40"- 32"- 24" - | - P161 - | Bluetooth 3.0(2.402GHz-2.480GHz) 1 x Lan Ethernet RJ45 1 x 1 x | (10BASE-T/100BASE-TX) Wi-Fi Wi-Fi Direct DLNA 802.11 a/n 5.180GHZ-5.320GHz,5.500GHz-5.580GHz 5.660GHZ-5.700GHz 802.11 b/g/n 2.412GHz-2.472GHz Security WPA2-PSK(TKIP/AES) WPA-PSK(TKIP/AES) WEP(64-bit/128-bit) | DVB-T/T2/C Analog (PAL,SECAM) No HEVC | DS500 | ||
DS400 40" | No | No | 40" - max...cd/m[SUP]2[/SUP] No | 40" - VA, 8bit, 60/50Hz | 40"- | 40"- | 40"- | - P161 - | DVB-T/T2/C Analog (PAL,SECAM) | DS400 |
