-Panasonic TV Line-Up 2016-
hristoslav2
8 January 2016
359
Varna, Bulgaria
Panasonic UltraHD TV 2016
ProductUHD
Premium
Dolby
Vision
HDR
_____________________
Videopanel - LCD matrix
___________________________________
Backlight
Dimming
_____________________________________
Color Space
Contrast
White & Black level
Viewing angle
_____________
Input Lag
SoC
software
OS
_________________
Conectors
_________________
Networks
Tuner
Picture Accuracy Out-of-the-Box (score out of 10)
_______________
Product
CZ950
65"
OLED
YesNo65" -Oled, WRGB, 10bit, 120/100HzNo65" -65" - ∞ / 130cd/m2 / 0.00cd/m2-
Lan -
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth
Wi-Fi Direct
DLNA (RUI2.0/DTCP-IP/DMP/DMR/DMS)
2 x DVB-C/T2/S2,
1 x SAT>IP Client & Server
DVB-T2: HEVC H.264 и H.265
Analog (PAL,SECAM)
2 x CI+1.3
HEVC
VP9
CZ950
DX900
58", 65"
YesNo65"- max 1250cd/m[SUP]2[/SUP]
58"- max 1320cd/m[SUP]2[/SUP]
Yes HDR10
SMPTE standards
ST2084, ST2086
65"- SMVA, 10-bit, 120/100Hz + MCFI
58"- SMVA, 10-bit, 120/100Hz + MCFI
65"' - FALD - 512 zones (32 columns x 16 rows)
58" - FALD - 512 zones (32 columns x 16 rows)
Honeycomb backlight structure
Blue Leds (actually white
LEDs "boosted"
with red phosphorus)
(BLS - Backlight Scaning) +
(BFI - Black Frame Insertion)
6 cooling fan backlight
65"- DCI P3 - 98% / Rec.2020 - 78%
58"- DCI P3 - 96% / Rec.2020 - 74%
65" - 5360:1 / 134cd/m2 / 0.025cd/m2
58" - 4600:1 / ---- cd/m2 / 0.023cd/m[SUP]2
[/SUP]
65" - 42°(cone)
58" - 46°(conе)
65"- Game mode -41ms / by default-51ms
58" -
Quad Core
P163
Firefox 2.5
Bluetooth Ver. 4.0 (keyboards, mouse)
1 x Ethernet RJ45
2 x USB 2.0 (max500mA)
1 x USB 3.0 (max900mA)
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
2 x HDMI 2.0 (ARC,CEC)
1 x Satelite In (Main: F-type female)
1 x Satelite In (Sub: F-type female)
1 x AV Composite In
1 x AV Component In
1 x Optical Audio Out
1 x 3.5mm Audio Out
1 x Antena (RF)female
1 x CI+ 1.3
Card reader SD/SDHC
Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
2x DVB-C/T2/S2,
Analog (PAL,SECAM)
2 x CI+1.3
HEVC
VP9
9DX900
DX800
58", 50"
YesNo58" - max...cd/m[SUP]2[/SUP]
50" - max...cd/m[SUP]2[/SUP]
Yes HDR10
SMPTE standards
ST2084, ST2086
58"- SMVA, 8-bit+Hi-FRC, 120/100Hz + MCFI
50"- SMVA, 8-bit+Hi-FRC, 120/100Hz + MCFI
58" - Edge Led
50" -
58"-
50"-
58"-
50"-
58" -
50" -
58" -
50" -
Quad Core
P163
Firefox 2.5
1 x Ethernet RJ45
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Card reader SD/SDHC
Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
2 x DVB-C/T2/S2,
Analog (PAL,SECAM)
2 x CI+1.3
HEVC
VP9
DX800
DX780
65", 58", 50"
NoNo65" - max......cd/m[SUP]2[/SUP]
55" - max 577cd/m[SUP]2[/SUP]
50" - max .....cd/m[SUP]2[/SUP]
Compatible
HDR processing
(but no hardware for HDR)
65" - SMVA, 8-bit+FRC, 120/100Hz + MCFI
58" - SMVA, 8-bit+FRC, 120/100Hz + MCFI
50" - SMVA, 8-bit+FRC, 120/100Hz + MCFI
65" - Direct Led, Local Dimming
58" - Edge Led (below) Vertical Dimming
50" - Edge Led (below) Vertical Dimming
65" -
58" -
50" - DCI P3 - 89% / Rec.2020 - 66%
65" -
58" -
50" -
65" -
58" -
50" -
65" -
58" -
50" -
Quad Core
P163
Firefox 2.5
1 x Ethernet RJ45
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Card reader SD/SDHC
Lan (10BASE-T/100BASE-TX)
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
2 x DVB-C/T2/S2,
Analog (PAL,SECAM)
2 x CI+1.3
HEVC
VP9
DX780
DX750
65", 58", 50"
No
No65" - max 435cd/m[SUP]2[/SUP]
58" - max 550cd/m[SUP]2[/SUP]
50" - max 550cd/m[SUP]2[/SUP]
Compatible
HDR processing
very glossy panel
65" - Direct Led, No Dimming
58" - EdgE Led (below), Vertical Dimming ?
50" - Edge Led (below), Vertical Dimming ?
65" - DCI P3 - 94% / Rec.2020 -
58" - DCI P3 - 94% / Rec.2020 -
50" - DCI P3 - 86% / Rec.2020 - 66%
65" - 4300:1 / 123cd/m2 / 0.03cd/m2
58" -
50" - 3795:1/ ---- cd/m2 / 0.29cd/m2
65" - 30° (cone)
58" -
50" -
65"- Game mode-45ms / by default-106ms
58"- Game mode-44ms / by default-105ms
50"- Game mode-44ms / by default-105ms
Quad Core
P163
Firefox 2.5
Bluetooth Ver. 4.0(keyboards, mouse)
1 x Ethernet RJ45
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Card reader SD/SDHC
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB- C/T2/S2
with PIP functions, PAP, PAT, PVR and Time shift
Analog (PAL,SECAM)
HEVC
VP9
THX & ISF sertification
Accurate Colour Drive: 3DLUT with 8000 points corrections
DX750
DX730
58", 50", 40"
NoNo58"- max....cd/m[SUP]2[/SUP]
50"- max 317cd/m[SUP]2[/SUP]
40" - max...cd/m[SUP]2[/SUP]
Compatible
HDR processing
58" - SMVA, 8-bit, 60/50Hz + BLB + MCFI
50" - SMVA, 8-bit, 60/50Hz + BLB + MCFI
40" - SMVA, 8-bit, 60/50Hz + BLB + MCFI
very glossy panel
40" - Edge Led (below) Vertical Dimming
58" -
50" -
40" -
58" -
50" - 4824:1 / 0.04cd/m[SUP]2[/SUP]
40" -
58" -
50" - 42° (cone)
40" -
58" -
50" -
40" -
Quad Core
P193
Firefox 2.5
1 x Ethernet RJ45
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Card reader SD/SDHC
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C
Analog (PAL,SECAM)
HEVC
VP9
DX730
DX700
58", 50"'40"
NoNo58" - HDR 350cd/m2
50" - HDR 350cd/m[SUP]2
[/SUP]
40" -
Compatible
HDR processing
very glossy panel
58" - Edge Led (below), Vertical Dimming
40" - Edge Led (below),
58" - DCI P3 - / Rec.2020 - 68.27%
50" -
40" -
58"- 5736:1 / 153cd/m2 / 0.03cd/m2
3184:1 / 0.038cd/m[SUP]2[/SUP]
ANSI - 2304:1 / 0.046cd/m[SUP]2
[/SUP]
50" - 4700:1 /
40" -
58" - 40°(conе)
50" -
40" -
58"- Game-49.8ms / by default-69.7ms
50"- Game
40" -
Quad Core
P193
Firefox 2.5
Bluetooth Ver.4.0(keyboards, mouse)
1 x Ethernet RJ45
1 x USB 2.0 (max 500mA)
1 x USB 3.0 (max 900mA)
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
1 x Antena (RF) female
1 x CI+ 1.3
WiFi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-C/T2/S/S2
Analog (PAL,SECAM)
HEVC
9DX700
DX650
58", 50",40"
NoNo58" -
50" -
40" -
No
58"- SMVA, 8-bit, 60/50Hz + BLB
50"- SMVA, 8-bit, 60/50Hz + BLB
40"- SMVA, 8-bit, 60/50Hz + BLB
58" - Edge Led
50" - Edge Led
40" - Edge Led
58"-
50"-
40"-
58"-
50"-
40"-
58"-
50"-
40"-
Quad Core
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C
Analog (PAL,SECAM)
DX650
DX600
55", 49", 40"
NoNo55" - max 294cd/m2
49" - max...cd/m[SUP]2[/SUP]
No
55"- S-IPS, 8-bit, 60/50Hz + BLB
49"- S-IPS, 8-bit, 60/50Hz + BLB
55" - Edge Led
49" - Edge Led
40" - Edge Led
55"-
49"-
40"-
55"-
49"-
40"-
55"- 78° (cone)
49"-
40"-
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DLNA
DVB-T/T2/C
Analog (PAL,SECAM)
DX600
Panasonic Full HD TV 2016
ProductUHD
Premium
Dolby
Vision
HDR
_________________
_________________
Backlight
Dimming
Color Space
Contrast & Black level
Viewing angle
____________
Input Lag
_____________
SoC
software
OS
_________________
Conectors
Networks
Tuner
_______________
Product
DS630
50", 40", 32"
NoNo50" - max - 362cd/m2
32" - max...cd/m[SUP]2[/SUP]
No
50"- SMVA, 8-bit, 120/100Hz + BLB + MCFI
40"- SMVA, 8-bit, 120/100Hz + BLB + MCFI
32"- ?, 8-bit, 60/50Hz
50" - Edge Led
40" - Edge Led
32" - Edge Led
Only globally
(Adaptive Backlight Dimming)
50"- DCI P3 - 74%
40"-
32"-
50"- 4311:1 /0.038cd/m2
40"-
32"-
50"-
40"-
32"-
P162
my Home Screen 1.0
Bluetooth 3.0(2.402GHz-2.480GHz)
1 x Lan Ethernet RJ45
3 x HDMI 1.4 (CEC)
1 x mini Jack (3.5mm) stereo
1 x SCART
1 x Component (RCA PIN type)
Wi-Fi
Wi-Fi Direct
DLNA
802.11 a/n
5.180GHZ-5.320GHz,5.500GHz-5.580GHz
5.660GHZ-5.700GHz
802.11 b/g/n
2.412GHz-2.472GHz
Security
WPA2-PSK(TKIP/AES)
WPA-PSK(TKIP/AES)
WEP(64-bit/128-bit)
DVB-T/T2/C
Analog (PAL,SECAM,NTSC)
No HEVC
DX630
DS600
50", 40", 32"
NoNo50" - max...cd/m2
40" - max...cd/m2
32" - max...cd/m2
No
50" - , 8-bit, 60/50Hz
40" - SMVA, 8bit, 60/50Hz
32" - , 8/-bit, 60/50Hz
50" - Edge Led
40" - Edge Led
32" - Edge Led
50"-
40"-
32"-
50"-
40"-
32"-
50"-
40"-
32"-
P161
3 x HDMI 1.4 (CEC)
1 x
1 x
Wi-Fi
Wi-Fi Direct
DLNA
802.11 a/n
5.660GHZ-5.700GHz
802.11 b/g/n
2.412GHz-2.472GHz
Security
WPA2-PSK(TKIP/AES)
WPA-PSK(TKIP/AES)
WEP(64-bit/128-bit)
DVB-T/T2/C
Analog (PAL,SECAM)
No HEVC
DX600
DS500
55", 49", 40",32",24"
NoNo55" - max...cd/m[SUP]2[/SUP]
49" - max 314cd/m2
24" - max...cd/m[SUP]2[/SUP]
No
55" - IPS, 8bit, 60/50Hz
49" - , 8-bit, 60/50Hz
40" - , 8-bit, 60/50Hz
32" - , 8-bit, 60/50Hz
24" - , 8-bit, 60/50Hz
55" - Edge Led
49" - Edge Led
40" - Edge Led
32" - Edge Led
24" - Edge Led
55"-
49"-
40"-
32"-
24" -
55"-
49"- 882:1 /
40"-
32"-
24" -
55"-
49"- 66° (cone)
40"-
32"-
24" -
P161
1 x
1 x
Wi-Fi
Wi-Fi Direct
DLNA
802.11 a/n
5.660GHZ-5.700GHz
802.11 b/g/n
2.412GHz-2.472GHz
Security
WPA2-PSK(TKIP/AES)
WPA-PSK(TKIP/AES)
WEP(64-bit/128-bit)
DVB-T/T2/C
Analog (PAL,SECAM)
No HEVC
DS500
DS400
40"
NoNo40" - max...cd/m[SUP]2[/SUP]
No
40" - VA, 8bit, 60/50Hz40"-40"-40"--
P161
DVB-T/T2/C
Analog (PAL,SECAM)
DS400
technisat
13 January 2010
869
Όπως φαίνεται line-up 2017 δεν θα υπάρξει...
Panasonic Corp said it will close its unprofitable television screen manufacturing business...
A Panasonic spokeswoman said the company will stop producing TV screens at its plant...
xavito
29 October 2008
8,991
58"...[lesnumeriques.com]...Panasonic TX-58DX750F review...http://www.lesnumeriques.com/tv-televiseur/panasonic-tx-58dx750f-p31107/test.html
μετάφραση google fr to en
TX-58DX750F : VA panel RGB subpixel structure
Edge LED backlight system composed of a single bar placed at the base of the screen.
xavito
29 October 2008
8,991
50"...[hdtvtest.co.uk]...Panasonic TX-50DX750B review...http://www.hdtvtest.co.uk/news/tx50dx750b-201607034309.htm
Measured panel refresh rate 120Hz,
Motion resolution:1080 lines with optimised [IFC] “Custom“
]TX-50DX750:Macro photo of subpixel structure confirming VA-type LCD matrix RGB,Super MVA (SMVA) from Taiwanese vendor Innolux Corporation.
A quick thermal scan revealed that the edge LEDs are mounted along the bottom of the screen
Verdict
Even though its HDR rendition left us slightly underwhelmed owing to 500-nit peak brightness and ineffectual pseudo-local dimming, the Panasonic TX-50DX750B delivered outstanding SDR image quality with accurate colours and superb processing. The TV’s restricted viewing angles and higher propensity for dark smearing were direct consequences of the Innolux SMVA panel used, but at least it yielded some of the deepest native black-level reproduction we’ve measured from an LED LCD.
In fact, when you consider that LG’s UH770V and Sony’s XD85 use IPS-type LCD panels which feature weaker contrast performance, and the HDR presentation of Samsung’s KS7500 was just downright unconvincing despite its ability to hit 1000 nits, the Panasonic DX750 could very well turn out to be the best-performing midrange 4K HDR television for 2016. We’ll know more when we test Samsung’s flat-screen KS7000 sometime this month…
source photos:[hdtvtest.co.uk]
xavito
29 October 2008
8,991
58"...[hdtvpolska.com]...Panasonic TX-58DX800E review...http://hdtvpolska.com/topic/37786-panasonic-dx800-tx-58dx800e-test-ultra-hd-4k-hdr-120hz/
μετάφραση google pl to en
TX-58DX800E:VA panel RGB 100/120Hz με MCFI+αναβόσβησμα του οπίσθιου φωτισμού,
55"...[avforums.com]...Panasonic TX-55DX600B review...https://www.avforums.com/review/panasonic-tx-55dx600b-ultra-hd-4k-tv.12495
TX-55DX600B: panel IPS variety,50/60Hz (4K 800 Hz BMR IFC ) ,average black level of 0.19 nits, ANSI contrast ratio of less than 750:1
https://www.youtube.com/watch?v=kEwhuzvJL04
https://www.youtube.com/watch?v=8ewysgY2ZXM
xavito
29 October 2008
8,991
50"...[tweakers.net]...Panasonic TX-50DXW804 review...https://tweakers.net/reviews/4719/panasonic-dxw804-uhdtv-mooi-beeld-en-geluid-in-een-uniek-ontwerp.html
μετάφραση google nl to en
TX-50DXW804:VA panel RGB 100/120Hz με MCFI+αναβόσβησμα του οπίσθιου φωτισμού,
...DXW804 is actually the German version of the DX800...
... Unfortunately, Panasonic has chosen to omit a DTS-licensed, so very many movies have to do it without sound...
... The image is in fact divided into only four vertical zones...
Conclusion
Panasonic DXW804 may be costly, because you get something in return. The picture is stunning, with beautiful colors and a good contrast LCDTV. The maximum brightness is high, so you have a good picture under many lighting conditions, but for HDR rendering is the maximum brightness a bit on the low side. Panasonic has the view been properly adjusted at the factory, but if you're going to calibrate, you have these TV a good one, thanks to the pleasant working color management system.
Besides a good idea this TV also has a good sound, thanks to the single soundbar you get included. This provides a good stereo image and clearly intelligible voices. The bass is compelling, but very deep bass do not go. By separate speaker system, this is one of best-sounding televisions today.
You get two remote controls, which the infrared model works nicely; on the Touch Pad Controller, we are talking less. The DXW804 running on Firefox OS, we like it works and that is clearly designed. However, it is worrisome is that its development as well as stationary, because it still works exactly the same as last year.
Regarding design, this unique television; screen hangs in a sleek stand and therefore you get a single soundbar with. The choice of Panasonic to come up with a distinctive design, we applaud much, but the uncompromising design are the opinions strongly divided. That means there is a large group of people who will leave this screen left because they did not find him nice. If you find it beautiful design and the high price is no object, you have to DXW804 a very good TV.
hristoslav2
8 January 2016
359
Varna, Bulgaria
Product
Certification UHD
Premium
Resolution: 3,840x2,160.
Color depth: 10-bit.
Color gamut: Wide, including the ability to show at least 90 percent of the P3 color gamut .
High dynamic range: Specifically the ability to use SMPTE ST2084's electro-optical transfer function, which Dolby helped create .
Minimum brightness and contrast ratios: There are two possible minimum specs. A minimum brightness of 1,000 nits, along with a black level of a maximum of 0.05 nits (20,000:1 contrast ratio), or a minimum brightness of 540 nits, along with a black level of a maximum of 0.0005 (1,080,000:1)
Dolby Vision
The metadata is graded in each scene so you get different grades throughout the file. Dolby tells us that scene by scene grading is the superior way to grade a movie, which on paper does sound more efficient.
Standard: Poprietary
Peak Luminance: Up to 10,000 nits
Video Bit Depth: 12-bit
Metadata: Dynamic (scene by scene)
Software Upgradability: No(SoC hardware-embedded)
HDR 10
The metadata is graded and determined, and is then sent at the beginning of the file and covers the entire file. One set of metadata
Standard: Open
Peak Luminance: Up to 4,000 nits
Video Bit Depth: 10-bit
Metadata: Static (per title)
Software Upgradability: Yes
Videopanel
Type LCD matrix,
Bits of color,
Operating frequency of T-Con board of the panel,
Curvature,
Index,
Anti-reflective filter
Backlight
Type backlight
(Local Dimming zone)
Type LED
MEMC
Backlight Scanning
PulsΠϴ Wide Modulation
Color Space
DCI P3 - %
Rec.2020 - %
Contrast
White & Black level
ANSI
With local dimming
Without local dimming
Viewing angle
_____________
Input Lag
SoC
CPU
GPU
software
OS
_________________
Conectors
Networks
Tuner
Opportunities for
calibration
______________________________________
Product
CZ950
65"
OLED
YesNo65" - max 450cd/m2
Yes
SMPTE standarts
ST2084, ST 2086
Oled, WRGB (LG Display), 10bit, 120/100HzNo backlight65" - DCI P3 X,Y - 86% / Rec.2020 - 70%65" - ∞ / 151cd/m2 / 0.00cd/m265" - 45°
65" - Game mode - 0ms / by default - 80ms
Quad Core Pro 5
Firefox 2.0
1 x Ethernet RJ45
4 x HDMI 2.0a (ARC,CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
1 x Card reader SD/SDHC
Lan -
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth ver. 4.0
Wi-Fi Direct
2 x DVB-C/T2/S2,
DVB-T2: HEVC H.264 ΠΈ H.265
Analog (PAL,SECAM)
2 x CI+1.3
PVR, Time Shifting
HEVC
VP9
CZ950
DX900
58", 65"
58"- max 1430cd/m[SUP]2[/SUP]
Yes HDR10
SMPTE standards
ST2084, ST2086
Blue Leds - with red phosphorus
MEMC - Intelligent Frame Creation
BFI - Clear Motion
65"- DCI P3 X,Y - 98% / Rec.2020 - 78%
58"- DCI P3 X,Y - 96% / Rec.2020 - 74%
65" - ANSI
Static - 5360:1 / 134cd/m2 / 0.025cd/m2
Dynamic - 50000:1
58" - ANSI
Static - 4600:1 / ---- cd/m2 / 0.023cd/m[SUP]2[/SUP]
Dynamic - 50000:1
65" - 42°(cone)
58" - 46°(conΠϴ)
65"- Game mode - 41ms / by default - 51ms
58" - Game mode- 40ms / by default - 50ms
Quad Core
Chassis P163
Firefox 2.5
1 x Ethernet RJ45
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth ver. 4.0
Wi-Fi Direct
2x DVB-C/T2/S2,
Analog (PAL,SECAM)
2 x CI+1.3
PVR, Time Shifting
HEVC
VP9
ISF Professional
THX Bright Room
3D LUT
CMS - RGBCYM
gray scale of 10 points
Rec.2020
Rec.709
direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via Ethernet
DX900
DX800
58", 50"
NoNo58" - max 553cd/m, 10% - 458cd/m[SUP]2[/SUP]
Yes HDR10
SMPTE standards
ST2084, ST2086
58"- Super-MVA, 8-bit+FRC, 120/100Hz
50"- Super-MVA, 8-bit+FRC, 120/100Hz
58" - Edge Led
50" - Edge Led
Dimming - 4 Vertical zones
Blue Leds - with red phosphorus)
BFI - Clear Motion
58"- DCI P3 X,Y - 95% / Rec.2020 - 72%
50"- DCI P3 X,Y - 92%
58" - ANSI 3500:1
50"-
58" -
50" -
58" - Game mode 43ms / by default 110ms
50" - Game mode
Quad Core
Chassis P163
Firefox 2.5
1 x Ethernet RJ45
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth ver. 4.0
Wi-Fi Direct
2 x DVB-C/T2/S2,
Analog (PAL,SECAM)
2 x CI+1.3
PVR, Time Shifting HEVC
VP9
ISF Professional
THX Bright Room
3D LUT
CMS - RGBCYM
Rec.2020
Rec.709
DX800
DX780
65", 58", 50"
50" - max 5....cd/m[SUP]2[/SUP]
Compatible
HDR processing
65" - Super-MVA, 8-bit+FRC, 120/100Hz + MCFI
58" - Super-MVA, 8-bit+FRC, 120/100Hz + MCFI
50" - Super-MVA, 8-bit+FRC, 120/100Hz
65" - Direct Led, Local Dimming - 32 zones (8 x 4)
BFI - Clear Motion
65" - DCI P3 X,Y -
58" - DCI P3 X,Y -
50" - DCI P3 X,Y - 89% / Rec.2020 - 66%
65" -
58" -
50" -
65" -
58" -
50" -
65" - Game mode
58" - Game mode
50" - Game mode
Quad Core
Chassis P163
Firefox 2.5
1 x Ethernet RJ45
2 x HDMI 2.0a (ARC,CEC)
2 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth ver. 4.0
Wi-Fi Direct
2 x DVB-C/T2/S2,
Analog (PAL,SECAM)
2 x CI+1.3
PVR, Time Shifting
HEVC
VP9
DX780
DX750
65", 58", 50"
No
No65" - HDR max 435cd/m[SUP]2[/SUP]
58" - HDR 50-100% max 550cd/m[SUP]2[/SUP]
50" - HDR 10% max 628cd/m2/ 50-100% - 550cd/m2
SDR max 500cd/m[SUP]2[/SUP]
Compatible
HDR processing
very glossy panel
58" - Edge Led (below), Vertical Dimming ?
65" - DCI P3 X,Y- 94% / Rec.2020 - 75%
58" - DCI P3 X,Y - 94% / Rec.2020 - 75%
50" - DCI P3 X,Y- 95% / Rec.2020 - 76%
65" - ANSI 4300:1 / 123cd/m2 / 0.03cd/m2
58"- ANSI 4313:1 /120cd/m2 / 0.017cd/m2
50" - ANSI 4000:1 /
Static - 4800:1/ 120 cd/m2 / 0.025cd/m2
Dynamic - 5000:1 / 625cd/m2 / 0.10cd/m2
65" - 35° (cone)
58" - 40° (cone)
50" - 46° (cone)
65"- Game mode-46ms / by default-106ms
58"- Game mode-47ms / by default-105ms
50"- Game mode-47ms / by default-105ms
Quad Core
Chassis P163
Firefox 2.5
1 x Ethernet RJ45
2 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth ver. 4.0
Wi-Fi Direct
DVB- C/T2/S2
PVR and Time shift
Analog (PAL,SECAM)
PVR, Time Shifting
HEVC
VP9
Accurate Colour Drive technology with 3D LUT conversion table with 8 000 points correction and the ability to calibrate 6 primary and secondary colors within a CMS on 3 axes. Or Black Gradation Drive that can provide more gradations in dark scenes through treatment with 12 bit color.
To adjust the colorimetry, the DX750 offers all the necessary settings with the choice of gamut used (Rec.601, Rec.709, EBU, DCI / P3 or Rec.2020), gamma used (with varying gamma whose BT.1886 with compensation of black, 2.2 used in lit room, the 2.4 used in dark room). You can edit each Gamma to correct on 10 points. Each gamut can be calibrated from a CMS (Color Management System) 3-axis (luminance, saturation and hue) with opportunity to correct 6 primary and secondary colors (RGBCMY). Finally, we also find a Balance Whites 2P and 10P (10 points) to adjust the color temperature.
DX750
DX730
58", 50", 40"
Compatible
HDR processing
58" - Super-MVA, 8-bit, 60/50Hz + BLB
50" - Super-MVA, 8-bit, 60/50Hz + BLB
40" - Super-MVA, 8-bit, 60/50Hz + BLB
very glossy panel
58" - DCI P3 -
50" - DCI P3 -
40" - DCI P3 -
58" -
40" -
58" -
50" - 42° (cone)
40" -
58" - Game mode
50" - Game mode
40" - Game mode
Quad Core
Chassis P193
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C
Analog (PAL,SECAM)
PVR, Time Shifting
HEVC
VP9
DX730
DX700
58", 50"'40"
[/SUP]
40" -
Compatible
HDR processing
very glossy panel
40" - Edge Led(below), Vertical Dimming
50" - DCI P3 -
40" - DCI P3 -
[/SUP]
50" - 4700:1 /
40" -
58" - 40°(conΠϴ)
50" -
40" -
58"- Game mode-49.8ms / by default-69.7ms
50"- Game mode
40" - Game mode
Quad Core
Chassis P193
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
1 x CI+ 1.3
WiFi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth ver. 4.0
Wi-Fi Direct
DVB-C/T2/S/S2
Analog (PAL,SECAM)
HEVC
9DX700
DX650
58", 50",40"
NoNo58" -
50" -
40" -
No
58"- Super-MVA, 8-bit, 60/50Hz + BLB
50"- Super-MVA, 8-bit, 60/50Hz + BLB
40"- Super-MVA, 8-bit, 60/50Hz + BLB
58" - Edge Led, (below)
50" - Edge Led, (below)
40" - Edge Led, (below)
MEMC - Inteligent Frame Creation
58"- DCI P3 -
50"- DCI P3 -
40"- DCI P3 -
58"-
50"-
40"-
58"-
50"-
40"-
58" - Game mode
50" - Game mode
40" - Game mode
Quad Core
Chassis -
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C
Analog (PAL,SECAM)
DX650
DX600
55", 49", 40"
No
55"- Super-IPS, 8-bit, 60/50Hz + BLB
49"- Super-IPS, 8-bit, 60/50Hz + BLB
55" - Edge Led, (below)
49" - Edge Led, (below)
40" - Edge Led
55"- DCI P3 -
49"- DCI P3 -
40"- DCI P3 -
55"-
49"-
40"-
55"- 78° (cone)
49"-
40"-
55" - Game mode
49" - Game mode
40" - Game mode
Chassis -
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C
Analog (PAL,SECAM)
DX600
ProductUHD
Premium
Dolby
Vision
HDR
_________________
_________________
Backlight
Dimming
Color Space
Viewing angle
____________
Input Lag
_____________
SoC
software
OS
_________________
Conectors
Networks
Tuner
_______________
Product
DS630
50", 40", 32"
No
50"- Super-MVA, 8-bit, 120/100Hz + BLB
40"- Super-MVA, 8-bit, 120/100Hz + BLB
50" - Edge Led
40" - Edge Led
32" - Edge Led
Only globally
50"- DCI P3 - 74%
40"- DCI P3 -
32"- DCI P3 -
40"-
32"-
50"-
40"-
32"-
50" -
40" -
32" -
Chassis P162
my Home Screen 1.0
3 x HDMI 1.4 (CEC)
1 x SCART
Wi-Fi
Wi-Fi Direct
DLNA
802.11 a/n
5.660GHZ-5.700GHz
802.11 b/g/n
2.412GHz-2.472GHz
Security
WPA2-PSK(TKIP/AES)
WPA-PSK(TKIP/AES)
WEP(64-bit/128-bit)
DVB-T/T2/C
No HEVC
DS630
DS600
50", 40", 32"
40" - max...cd/m2
32" - max...cd/m2
No
50" - MVA , 8-bit, 60/50Hz
40" - Super-MVA, 8bit, 60/50Hz
Backlight Motion Rate 400
50" - Edge Led
40" - Edge Led
32" - Edge Led
50"- DCI P3 -
40"- DCI P3 -
32"- DCI P3 -
50"-
40"-
32"-
50"-
40"-
32"-
50" -
40" -
32" -
Chassis P161
3 x HDMI 1.4 (CEC)
2 x USB 2.0
1 x SCART
1 x CI+ 1.3
Bluetooth 3.0 (2.402GHz-2.480Ghz)
Wi-Fi
Wi-Fi Direct
DLNA
802.11 a/n
5.660GHZ-5.700GHz
802.11 b/g/n
2.412GHz-2.472GHz
Security
WPA2-PSK(TKIP/AES)
WPA-PSK(TKIP/AES)
WEP(64-bit/128-bit)
DVB-T/T2/C
Analog (PAL,SECAM)
No HEVC
DS600
DS500
49" - max 314cd/m2
No
55" - Super-IPS, 8bit, 60/50Hz
49" - Super-IPS , 8-bit, 60/50Hz
55" - Edge Led
49" - Edge Led
40" - Edge Led
32" - Edge Led
24" - Edge Led
55" - DCI P3 -
49" - DCI P3 -
40" - DCI P3 -
32" - DCI P3 -
24" -
55"-
49"- 882:1 /
40"-
32"-
24" -
55"-
49"- 66° (cone)
40"-
32"-
24" -
55" -
49" -
40" -
32" -
24" -
Chassis P161
1 x USB 2.0
1 x Ethernet RJ45
2 x HDMI 1.4 (ARC, CEC)
1 x Scart
1 x AV Composite In
1 x AV Component In
1 x Opticasl Audio Out
1 x 3.5mm Audio Out
1 x CI+ 1.3
Bluetooth 3.0 (2.402GHz-2.480GHz)
Wi-Fi
Wi-Fi Direct
802.11 a/n
5.660GHZ-5.700GHz
802.11 b/g/n
2.412GHz-2.472GHz
Security
WPA2-PSK(TKIP/AES)
WPA-PSK(TKIP/AES)
WEP(64-bit/128-bit)
DLNA
DVB-T/T2/C
Analog (PAL,SECAM)
No HEVC
DS500
DS400
40"
No
40" - MVA, 8bit, 60/50Hz
Backlight Motion Rate - 400
40" - Edge Led40"- DCI P3 -40"-40"-40" --
Chassis P161
1 x USB 2.0
1 x Ethernet RJ 45
1 x SCART
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Lan
WiFi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5Ghz
DLNA
DVB-T/T2/C
Analog (PAL,SECAM)
DS400
xavito
29 October 2008
8,991
50"...[avforums.com]...Panasonic TX-50DX802B review...https://www.avforums.com/review/panasonic-dx802-tx-50dx802b-ultra-hd-4k-tv-review.12800
Conclusion
The DX802 is clearly aimed at the lifestyle sector of the TV market but we were pleased to discover that despite the emphasis on design, Panasonic haven't compromised on performance. The 50DX802 uses an easel-style silver stand that includes a separate soundbar and it is certainly eye-catching. The build quality is good and although you will need a wide surface to position the DX802B on, there is also the option to wall mount both the TV and the soundbar. In the case of the soundbar itself, it definitely sounds better than most built-in speakers but will struggle to compete with a dedicated soundbar that includes its own active subwoofer. In terms of features the DX802 includes THX certification, active shutter 3D and support for HDR10, along with Panasonic's excellent Firefox Smart TV platform with a full compliment of catch-up and streaming services. The input lag was measured at 44ms and if energy consumption is important to you, the DX802 proved to be very efficient.
The overall performance of the 50DX802B was very good, with a decent out-of-the-box performance and an impressive greyscale accuracy after calibration. We were a little disappointed at the overall colour accuracy, especially from a Panasonic, but the DX802 handled the HDR tests quite well. The native colour gamut was 67% of Rec.2020, the peak brightness was limited to 545nits and the tone mapping appeared to clip content mastered at more than 1,000nits but overall the HDR performance was good, although lacking some of the impact of other TVs we've tested. The performance with standard and high definition content was excellent and we were glad to find that the local dimming was much improved over other Panasonic TVs we've seen. The 3D was also very good, delivering plenty of depth whilst keeping the flicker and crosstalk to a minimum. So overall the Panasonic TX-50DX802B proved to be an excellent combination of design and performance that is worthy of recommendation.​
hristoslav2
8 January 2016
359
Varna, Bulgaria
Panasonic UHD TV 2016 - european models
Series
Model​
________________
Certification UHD Premium (1)
________
Dolby Vision(2)
____
HDR 10
_________________
In Windows
2/5/10/20/100%
Videopanel
Type LCD matrix,
Bits of color,
(Operating frequency of T-Con board of the panel)
Curvature,
Index,
Screen Uniformity
Backlight
Type backlight
Type LED
MEMC
Backlight Scanning
Pulsе Wide Modulation
Color Space
DCI P3 / Rec.2020 / Delta E / Gamma / Temperature
Contrast White & Black level
ANSI
With local dimming
Viewing angle___________
( ° cone)
Motion resolution​
Horizontal Lines
Product_____________
Input Lag
Audio
SoC,
CPU,
GPU,
Software,
OS
Networks
Conectors
Tuners
________________
Opportunities for calibration
Note
____________________________________________________________________________
Pros & Cont
Product
CZ950 OLED
TX-65CZ950
YesSMPTE standartsST2084, ST 2086
Oled, WRGB (LG Display), 10bit, 120/100HzNo backlight65" - DCI P3 X,Y - 86% / Rec.2020 - 70%65" - ∞ / 151cd/m2 / 0.00cd/m265" - 45°CZ950
65"
OLED
65" - Game mode - 0ms / by default - 80ms-
Quad Core Pro 5
Firefox 2.0
1 x Ethernet RJ45
4 x HDMI 2.0a HDCP2.2 (ARC,CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Lan -
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth ver.4.0(for keyboard and mouse, no Bluetooth audio)
Wi-Fi Direct
2 x DVB-C/T2/S2,
Analog (PAL,SECAM)
2 x CI+1.3PVR, Time Shifting
HEVC, VP9
CZ950
DX900
TX-65DX900E
TX-65DXC904
TX-65DXW904
TX-65DX902B
TX-58DX900E
TX-58DXC904
TX-58DXW904
TX-58DX902B
Yes HDR10SMPTE standardsST2084, ST2086
Motion Clarity Frame Interpolation
Black Frame Insertion (Clear Motion)
65"' - FALD, 512 zones (32 columns x 16 rows)
58" - FALD, 512 zones (32 columns x 16 rows)
Honeycomb backlight structureBlue Leds - with red phosphorusMEMC - Intelligent Frame CreationBLS - Backlight ScaningBFI - Clear Motion6 cooling fan backlight
65"- 98% / 78% /
58"- 96% / 74%
phosphorus-based diodes for a wide gamut close to the DCI 4K(Blue Led + Red/Green phosphorus)
65" - ANSIStatic - 5360:1 / 134cd/m2 / 0.025cd/m2Dynamic - 50000:1
58" - ANSI Static - 4600:1 / ---- cd/m2 / 0.023cd/m[SUP]2 /[/SUP]Dynamic - 50000:1
65" - 42°(cone)
58" - 46°(conе)
DX900
58", 65"
40Watt (10W+10W+10W+10W)
integrated subwoofer
Dolby Digital Plus
No DTS
VR-Audio Master Surround 2.1
Quad Core
Chassis P163
Firefox 2.5
1 x Ethernet RJ45
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
2x DVB-C/T2/S2,
1 x SAT>IP Client & ServerDVB-T2: HEVC H.264 и H.265
Analog (PAL,SECAM)
HEVC, VP9
ISF ProfessionalTHX Bright Room3D LUTCMS - RGBCYMgray scale of 10 pointsRec.2020Rec.709direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via EthernetDX900
DX800
TX-58DX800E
TX-58DXW804
TX-58DX802B
TX-50DX800E
TX-50DXW804
TX-50DX802B
50" - 10% - 545cd/m[SUP]2[/SUP]
Panasonic have done an excellent job of ensuring the backlight is suitably uniform. There was no apparent dirty screen effect or any obvious bright edges and overall with normal viewing material the backlight performance was very good. At night in a dark room you could see some minor backlight issues but those were rare and easily mitigated with some bias lighting.
58" - Edge Led
50" - Edge Led
Dimming - 4 Vertical zonesBlue Leds - with red phosphorus)MEMC - Intelligent Frame CreationBFI - Clear Motion
58"- 95% / 72%
50"- 86% / 67% / DeltaE 2.3 / Gamma 2.4
58" - ANSI 3500:1 / 0.0
50" - ANSI 5310:1 / 0.02cd/m2
with Adaptive Backlight Control (local dimming) 0.002cd/m2,
58" -
50" -
58" -
50" - with IFC - 1080 / without - 350
DX800
58", 50"
50" - Game mode 44ms / by default 110ms
The DX802 delivered an input lag of 44ms in Game Mode, which whilst not as low as some of the competition, should be good enough for all but the most demanding of gamers. We certainly had no problems with lag when gaming and found the overall performance to be very good with our PS4. One interesting thing to note is that you can select the Game Mode when watching HDR content, which means that when HDR games are released you should still be able to enjoy the benefits of a lower input lag.
40 W (10W+10W+20W)
Dolby Digital Plus
No DTS
VR-Master Audio 2.1 Surround
12 TrainPrismatic Speaker
The soundbar includes a 12 train prismatic speaker, a quad passive radiator and 40W of amplification, whilst there are holes at the back so that it can, along with the TV, also be wall mounted. The fact that you can detach the soundbar completely means you also have the option to not use it at all and simply use your DX802 with a third-party audio solution.
Quad Core
Chassis P163
Firefox 2.5
1 x Ethernet RJ45
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Lan
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
2 x DVB-C/T2/S2,
Analog (PAL,SECAM)2 x CI+1.3PVR, Time Shifting HEVC, VP9
As with all Panasonic TVs, the DX800 comes with an excellent set of calibration controls, including 2- and 10-point white balance controls, a separate gamma control and a full Colour Management System (CMS),ISF Professional, THX Bright Room, 3D LUTCMS - RGBCYM gray scale of 10 points. Rec.2020, Rec.709 direct Display Control mode to allow to adjust settings directly from the Calman software (professional edition) by connecting screen to a PC via EthernetThe colour accuracy of the DX802 wasn't as good as we would expect from a Panasonic TVDX800
DX780
TX-65DX780E
TX-65DXW784
TX-58DX780E
TX-58DXW784
TX-58DXX789
TX-58DXN788
TX-58DXF787
TX-58DXT786
TX-50DX780E
TX-50DXW784
TX-50DXT786
TX-50DXF787
CompatibleHDR processing (but no hardware for HDR)
65" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz
58" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz
50" - Super-MVA, 8-bit+Hi-FRC, 120/100Hz
Blue Leds - with red phosphorusMEMC - Intelligent Frame CreationBFI - Clear Motion
65" - DCI P3 X,Y -
58" - DCI P3 X,Y -
65" -
58" -
50" -
65" -
58" -
50" -
DX780
65", 58", 50"
65" - Game mode
58" - Game mode
50" - Game mode
2x10 Watt RMS
Dolby Digital Plus
No DTS
VR-Audio Surround True
Quad Core
Chassis P163
Firefox 2.5
1 x Ethernet RJ45
2 x HDMI 2.0a HDCP2.2 (ARC,CEC)
2 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x Antena (RF)female1 x CI+ 1.3
Wi-Fi 802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth Ver.4.0(for keyboard and mouse, no Bluetooth audio)
Wi-Fi Direct
2 x DVB-C/T2/S2,
1 x SAT>IP Client & ServerDVB-T2: HEVC H.264 и H.265Analog (PAL,SECAM)2 x CI+1.3PVR, Time Shifting
HEVC, VP9
DX780
DX750
TX-65DX750E
TX-65DX750B
TX-58DX750E
TX-58DX750F
TX-50DX750E
TX-50DX750F
TX-50DX750B
NoNo65" - max 435cd/m[SUP]2[/SUP]
58" - 100% max 550cd/m[SUP]2[/SUP]
50" - 10% max 529cd/m2/
50" - Super-MVA, 8-bit+HI-FRC, 120/100Hz
50"- panel Innolux V500DK4-KS7-Rev.R24
very glossy panel
The Adaptive Backlight Control (local dimming) on the DX750 was a little disappointing, especially compared to the sophisticated system employed by Samsung, and even in the low mode we saw artefacts that were quite obvious at times. Although it was less an issue of haloing and more of a problem of the entire image obviously dimming in certain scenes. However since the native blacks and backlight uniformity are good, if you sit central to the screen there is very little difference with the local dimming on or off and at least when it's off you avoid any issues.
MEMC - Intelligent Frame CreationBMR 1800
65" - 90% / 70%
58" - 90% / 70%
50" - 86% / 66%
50" - ANSI 3795:1 / 0.023cd/m2
with Adaptive Backlight Control(Local Dimming) 0.001cd/m2
Static 4800:1/ 120 cd/m2 / 0.025cd/m2
Dynamic 5000:1 / 625cd/m2 / 0.10cd/m2
65" - 42° (cone)
58" - 44° (cone)
50" - 46° (cone)
65" -
58" - with IFC 1080 / without - 350
50" - with IFC 1080 / without - 350
DX750
65", 58", 50"
2x10 Watt RMS
Dolby Digital Plus
No DTS
The rendering is still acceptable, average with perfectly intelligible dialogue, but rather limited power with 2 x 10 Watts and no Subwoofer output as Sony. no one still finds a lot of settings to optimize the sound rendering, level the volume changes from one channel to another, a 7-band EQ, a surround mode, etc.
Quad Core
Chassis P163
Firefox 2.5
1 x Ethernet RJ45
2 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
Wi-Fi 802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB- C/T2/S2
Analog (PAL,SECAM)
PVR, Time Shifting
HEVC H.265, VP9
Accurate Colour Drive technology with 3D LUT conversion table with 8 000 points correction and the ability to calibrate 6 primary and secondary colors within a CMS on 3 axes. Or Black Gradation Drive that can provide more gradations in dark scenes through treatment with 12 bit color.To adjust the colorimetry, the DX750 offers all the necessary settings with the choice of gamut used (Rec.601, Rec.709, EBU, DCI / P3 or Rec.2020), gamma used (with varying gamma whose BT.1886 with compensation of black, 2.2 used in lit room, the 2.4 used in dark room). You can edit each Gamma to correct on 10 points. Each gamut can be calibrated from a CMS (Color Management System) 3-axis (luminance, saturation and hue) with opportunity to correct 6 primary and secondary colors (RGBCMY). Finally, we also find a Balance Whites 2P and 10P (10 points) to adjust the color temperature.THX - NoISF - NoAs for upscaling UHD Panasonic, there is no doubt he has made great progress. It's quite different from what Samsung offers, closer to what Sony offers, that is to say a very natural image, less chiseled than on the Samsung TV, but very precise and with a sumptuous quilted. The upscaling provides an image with rich texture and greatly improves accuracy without displaying traces of upscaling. So it is very comprehensive, especially for network management, but lacks however DisplayPort who was present on the AX900, or aptX Bluetooth and a Subwoofer output like what Sony offers. Standard remote control, without micro or backlit button. A good remote control, solid but rather plain .., and no possibility to calibrate the TV for a tablet like the DX900 as the DX750 is not certified ISF.
  • + Design, build quality, the possibility of multiple foot positions
  • + A powerful contrast to an Edge LED (4800: 1 ANSI)
  • + A bright peak in HDR pretty good (625 nits)
  • + System of internal gradation great despite the slab 8 bit
  • + HDR rendering of very good quality
  • + A rich spectrum of beautiful, balanced colors, a wide gamut (91.2% of DCI)
  • + Colorimetry output very correct card (delta E less than 3)
  • + A high-performance video processing, including SD content with a very natural picture
  • + Several algorithms with efficient remastering yet made once natural
  • + Ultra settings to complete color management level and HDMI
  • + IFC made without a fluid including 24P
  • + Complete network management, Samba, DLNA / UPnP, multiroom client / server, sharing the tuner on the network
  • + interesting multimedia management (UHD video playback and HDR, VP9 and HEVC, MKV, TS, Flac, ALAC, etc.), but no DTS decoding that just spoils the fun!
  • + A good quality 3D rendering, although some ghosting
  • + The best quality / price ratio in 2016, certainly!
  • - The anti-reflection treatment of limited
  • - A slab 8 bit (although fnally we do not notice it)
  • - IFC made too which generates a digital or video camera (main fault)
  • - Lack of support DTS multimedia
  • - A single HD tuner (DVB-C / T2 compliant HEVC and MPEG4)
  • - A slightly Directive slab contrast term as all VA panels
  • - A detail enhancement filter and / or contours would have been welcome for more chiseled picture lovers
  • - No compatibility Dolby Vision
  • - Local Dimming that a mouth too black to Medium or High
  • - The edges of the slab clearer in some dark scenes
DX750
DX730
TX-58DX730E
TX-50DX730E
TX-40DX730E
TX-40DXW735
TX-40DXW734
58" - Super-MVA, 8-bit+FRC, 60/50Hz
50" - Super-MVA, 8-bit+FRC, 60/50Hz
40" - Super-MVA, 8-bit+FRC, 60/50Hz
Black Frame Interpolation
4K Backlight Motion Rate IFC 1400
very glossy panel
58" - DCI P3 -
50" - DCI P3 -
40" - DCI P3 -
58" -
40" -
58" -
50" - 42° (cone)
40" -
DX730
58", 50", 40"
58" - Game mode
50" - Game mode
40" - Game mode
2x10 Watt RMS
Dolby Digital Plus
No DTS
VR-Audio Surround
True
Quad Core
Chassis P193
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C/S/S2
Double Tuner
Analog (PAL,SECAM)
PVR, Time Shifting
HEVC, VP9
DX730
DX720
TX-58DX720E
TX-50DX720E
TX-40DX720E
50"- max ....cd/m[SUP]2[/SUP]
4K Backlight Motion Rate IFC 1600
very glossy panel
58" - Led, Local Dimming
50" - Led, Local Dimming
40" - Led, Local Dimming
58" - DCI P3 -
50" - DCI P3 -
40" - DCI P3 -
58" -
40" -
58" -
50" - 42° (cone)
40" -
DX720
58", 50", 40"
58" - Game mode
50" - Game mode
40" - Game mode
2x10 Watt RMS
Dolby Digital Plus
No DTS
Quad Core
Chassis P193
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite In
1 x AV Component In
1 x 3.5mm Audio Out
1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C
Analog (PAL,SECAM)
PVR, Time Shifting
HEVC, VP9
DX720
DX700
TX-58DX700E
TX-58DX700F
TX-58DXW704
TX-50DX700E
TX-50DX703E
TX-50DXU701
TX-40DX700E
TX-40DX703E
TX-40DX700F
TX-40DXU701
NoNo58" - HDR max 350cd/m2
50" - HDR max 350cd/m[SUP]2[/SUP]
40" -
very glossy panel
50" - DCI P3 -
40" - DCI P3 -
58"- 5736:1 / 153cd/m2 / 0.03cd/m23184:1 / 0.038cd/m[SUP]2[/SUP]ANSI - 2304:1 / 0.046cd/m[SUP]2[/SUP]
50" - 4700:1 /
40" -
58" - 40°(conе)
50" -
40" -
DX700
58", 50"'40"
50"- Game mode
40" - Game mode
2x10 Watt RMS
Dolby Digital Plus
No DTS
VR-Audio True Surround
Quad Core
Chassis P193
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
1 x CI+ 1.3
WiFi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Bluetooth ver. 4.0
Wi-Fi Direct
DVB-C/T2/S/S2
Analog (PAL,SECAM)
HEVC,
DX700
DX650
TX-55DX650E
TX-55DX653E
TX-55DXW654
TX-49DX650E
TX-49DX653E
TX-40DX650E
TX-40DX653E
NoNo55" -
49" -
40" -
No
49"- Super-MVA, 8-bit, 60/50Hz
4K Black Frame Interpolation 1000
4K Backlight Motion Rate IFC 1000
55"- DCI P3 -
49"- DCI P3 -
40"- DCI P3 -
55"-
49"-
40"-
55"-
49"-
40"-
DX650
55", 49",40"
55" - Game mode
49" - Game mode
40" - Game mode
2x10 Watt RMS
Dolby Digital Plus
No DTS
Quad Core
Chassis -Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
1 x Antena (RF) female1 x CI+ 1.3
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C
Analog (PAL,SECAM)
DX650
DX600
TX-55DX600E
TX-55DX603E
TX-55DXW604
TX-55DXU601
TX-49DX600E
TX-49DX603E
TX-49DXU601
TX-49DXW604
TX-40DX600E
TX-40DX603E
TX-40DXW604
TX-40DXU601
No
4K Backlight Motion Rate IFC 800
40" - Edge Led
55"- DCI P3 -
49"- DCI P3 -
40"- DCI P3 -
55"-
49"-
40"-
55"- 78° (cone)
49"-
40"-
DX600
55", 49", 40"
55" - Game mode
49" - Game mode
40" - Game mode
2x10 Watt RMS
Compatible
Dolby Digital Plus
No DTS
Chassis
Firefox 2.5
1 x Ethernet RJ45
1 x HDMI 1.4 (CEC)
1 x AV Composite in
1 x AV Component in
1 x 3.5mm Audio Out
Wi-Fi
802.11 a
802.11 b
802.11 g
802.11 n
802.11 n 5GHz
Wi-Fi Direct
DVB-T/T2/C
Analog (PAL,SECAM)
DX600
Series
Model
________________
________
Dolby Vision(2)
____
HDR 10
________________
In Windows
2/5/10/20/100%
Videopanel
Type LCD matrix,
Bits of color,
Curvature,
Index,
Screen Uniformity
Backlight
Type backlight
Type LED
MEMC
Backlight Scanning
Color Space
___________________
ANSIWith local dimmingWithout local dimming
Viewing angle
_______________
( ° cone)
Motion resolution​
Product
_____________
Input Lag
Audio
SoCCPUGPUSoftwareOS
Networks
____________
Conectors
Tuners
______________
Note
Pros & Cont
Product
xavito
29 October 2008
8,991
65"...[hdtvtest.co.uk]...Panasonic TX-65DX902B review...http://www.hdtvtest.co.uk/news/tx65dx902b-201608144320.htm
Macro photo of subpixel configuration indicating VA-type LCD matrix sourced from Taiwanese vendor Innolux Corporation,RGB,
Verdict
Some may question our decision to lavish our β€œHighly Recommended – Best Value” award on a flagship TV costing nearly £3000, but when you take into consideration the Panasonic Viera TX-65DX902B’s supreme colour accuracy that’s possible through professional calibration, general picture quality and HDR-compatible game mode, plus the fact that following an official price drop recently to £2899, the TV undercuts rival FALD (full-array local dimming) LED LCD and OLED models by at least £800 in the UK, hopefully you’ll understand our reasoning.
source image:[perfectimage.gr]
