Davinci Resolve Updates
evanfotis
26 March 2008
5,489
Release of DaVinci Resolve Studio 19 Public Beta 2
Έβαλαν μερικά μικρά αλλα σημαντικά όπως η επιλογή track / clip effects σε Edit & Fairlight pages και έστρωσαν bugs
We are pleased to announce the release of DaVinci Resolve Studio 19 Public Beta 2. This release is available at no charge for existing customers from our support web site.
https://www.blackmagicdesign.com/suppor ... and-fusion
What's new in DaVinci Resolve 19.0 Public Beta 2
• Ability to wipe and apply grade to clip or active node stack layer.
• Icon to switch inspector between clip and track view in edit and Fairlight.
• Support for safe area overlay options in the edit timeline viewer.
• If selected, safe area overlays are displayed in the cut and edit viewers during playback.
• Ripple overwrite in the cut page can now be invoked from the application menu.
• Deselecting trackers in Fusion now hides tracking paths in viewer.
• Media management can now trim mp3 and flac audio in mov and mp4 clips.
• User prompt when upgrading older projects.
• Scripting API support for querying media audio track mapping.
• Scripting API support to query and set speaker detection from project settings.
• Support for HDR scans using the new Cintel scanner 8mm gate.
• Support for black and white scans from the Cintel scanner.
• Addressed angle metadata not set when auto syncing audio to video.
• Addressed timecode entry issue when in multicam mode on the source viewer.
• Addressed an issue with moving Open FX keyframes with smoothing.
• Addressed a potential issue with rendering in place retimed clips on Apple silicon.
• Addressed an issue with copying transitions in the edit timeline.
• Addressed transition resizing from the trim editor not updating the viewer.
• Addressed a timing issue with draw on lower thirds text.
• Addressed an issue with alpha passthrough in referenced compositions.
• Addressed a Fusion tracking issue with disabled IntelliTrack.
• Addressed issue with Fusion tracker zoom if not previewed.
• Addressed an issue with middle clicking Fusion clips to apply compositions.
• Addressed an issue where Magic Mask in Fusion would apply to one frame.
• Addressed Fusion mask artifacts when using Resolve Color Management.
• Addressed issue with inverted masks in some Fusion merges.
• Addressed an issue displaying nested inspector controls in Fusion macros.
• Addressed issue with double polygons in multipoly.
• Addressed a potential crash with Fusion particle emitters when using bitmaps.
• Addressed a refresh issue when previewing DCTLs in the color page.
• Addressed incorrect labels for yellow hue and center controls in the Mini Panel.
• Addressed artifacts when using Speed Warp on Mac and Nvidia systems.
• Addressed a crash creating a project from preset with multiple node stack layers.
• Addressed an issue with side-chained tracks in upgraded projects.
• Addressed scenarios with offset audio when using Dialogue Separator.
• Addressed a scenario where pans would be invoked for the wrong audio track.
• Addressed audio clipping for audio normalized renders using optimize.
• Addressed an issue decoding motion JPEG formatted AVI clips.
• Addressed an issue with accented names in remote monitoring connections.
• General performance and stability improvements.
For full details of the DaVinci Resolve Studio 19 release and minimum system requirements etc, please see the original public beta thread.
