https://www.sonyalpharumors.com/first-leaked-image-of-the-new-sony-a7siii/umored Sony A7sIII specs:
- New 12MP sensor with fast readout and S-Cinetone colorscience
- records FHD 240fps, 4k120fps 10bit 4:2:2 and 4K120fps raw over HDMI
- ONLY Up to 4k60 will be 10bit 4:2:2 internal.
- Downsampled 1080p from 4K, making this the best 1080p hybrid ever made! No line skipping or pixel binning.
- No internal RAW.
- 600mbps bitrate
- Base ISO 160 for S-LOG3
- no Dual ISO
- Max ISO 409600 (video)
- 16bit RAW output
- Sony claims 15 stops dynamic range
- Movie Edit add-on compatibility for Image Stabilization in post
- world’s highest resolution new 9.44 million dot EVF (QXGA resolution)
- same Sony A7rIV AF system
- new kind of passive (noise free) cooling system
- no overheating, no recording time limits (They are claiming to not have overheating issues for at least 1hr even at the highest framerate.)
- UHSII card and CFexpress Type A card support (each of th two slots takes them both!)
- Looks pretty similar to a Sony A7rIV.
- fully articulating screen like the one used by the Sony ZV-1.
- The video record button is now on the top of the camera, placed behind the shutter button.
- Screen: Touch function available when navigating the menu.
- Ports: Removable port door. Two usb-c, one micro hdmi, no flash sync port.
- price around 4.000 Euro (A7sIII now listed at BHphoto and in Germany at Fotokoch)
- announcement late July
shipment start mid August
Αυτό ακούγεται ενδιαφέρον, να το δούμε πως υλοποιείται στη πράξη.Movie Edit add-on compatibility for Image Stabilization in post
Αν είχε περισσότερα MPX δεν θα είχε αυτές τις επιδόσεις σε low light στο βίντεο και πιθανόν να ζοριζόταν και με θερμοκρασία
Για τα υπόλοιπα χαρακτηριστικά, μοιάζουν ολίγο "too little too late"...
