Sony A7S III
evanfotis
26 March 2008
5,485
Επιτέλους σπαστη οθόνη στα πλάγια...
umored Sony A7sIII specs:
  • New 12MP sensor with fast readout and S-Cinetone colorscience
  • records FHD 240fps, 4k120fps 10bit 4:2:2 and 4K120fps raw over HDMI
  • ONLY Up to 4k60 will be 10bit 4:2:2 internal.
  • Downsampled 1080p from 4K, making this the best 1080p hybrid ever made! No line skipping or pixel binning.
  • No internal RAW.
  • 600mbps bitrate
  • Base ISO 160 for S-LOG3
  • no Dual ISO
  • Max ISO 409600 (video)
  • 16bit RAW output
  • Sony claims 15 stops dynamic range
  • Movie Edit add-on compatibility for Image Stabilization in post
  • world’s highest resolution new 9.44 million dot EVF (QXGA resolution)
  • same Sony A7rIV AF system
  • new kind of passive (noise free) cooling system
  • no overheating, no recording time limits (They are claiming to not have overheating issues for at least 1hr even at the highest framerate.)
  • UHSII card and CFexpress Type A card support (each of th two slots takes them both!)
  • Looks pretty similar to a Sony A7rIV.
  • fully articulating screen like the one used by the Sony ZV-1.
  • The video record button is now on the top of the camera, placed behind the shutter button.
  • Screen: Touch function available when navigating the menu.
  • Ports: Removable port door. Two usb-c, one micro hdmi, no flash sync port.
  • price around 4.000 Euro (A7sIII now listed at BHphoto and in Germany at Fotokoch)
  • announcement late July
shipment start mid August
https://www.sonyalpharumors.com/first-leaked-image-of-the-new-sony-a7siii/
Για τα υπόλοιπα χαρακτηριστικά, μοιάζουν ολίγο "too little too late"...
22 June 2006
34,850
NEO HRAKLEIO
Προσωπικά με χαλάει αυτή η οθόνη, αλλά τη ζητάνε πολλοί....
Για τ αλλα, αν ισχύουν όσα γράφουν, περίμενα περισσότερα κι εγώ.
Σίγουρα raw εσωτερικά, κάποιου είδους ηλεκτρονικού φίλτρου Nd, πιο πολλά MP....24 είναι η Χρυσή τομή νομίζω.
Sent from my Mi 9T Pro using Tapatalk
evanfotis
26 March 2008
5,485
Εννοείται ήθελε 24 Mpx (6K) & downsample to 4K, όπως κάνουν οι ανταγωνιστές και οι άλλες α7. Να έχει νόημα κ ως φωτογραφική.
Αυτό ακούγεται ενδιαφέρον, να το δούμε πως υλοποιείται στη πράξη.
Kosh
7 September 2006
91,507
Εκεί ψηλά.....
Ποιος θα την παρει για φωτογραφικη βρε σεις ?
Καθαρα για video την παιρνουν αυτην την καμερα απλα ειναι σε σασι φωτογραφικης.
22 June 2006
34,850
NEO HRAKLEIO
Εμείς τη θέλουμε και για τα 2.....
Είχα την α7s Kai για λίγο την 7sii και μου έλειπαν τα MP.
Αλλά και στα υπόλοιπα θεωρώ ότι άργησε...αν ισχύουν αυτά που ακούμε.
Έτσι όπως είναι έπρεπε να είχε βγει 2 χρόνια πριν.
Τώρα θα πιάσει κυρίως τους βιντεαδες εκδηλώσεων, που θέλουν αρκετή ώρα εγγραφής χωρίς υπερθέρμανση.
Το κοινό που θα χάσει δηλ. Η canon.
kbouk
8 January 2010
22,439
ΠΕΙΡΑΙΑΣ
Απάντηση: Re: Sony A7S III
Αν είχε περισσότερα MPX δεν θα είχε αυτές τις επιδόσεις σε low light στο βίντεο και πιθανόν να ζοριζόταν και με θερμοκρασία
Kosh
7 September 2006
91,507
Εκεί ψηλά.....
Re: Απάντηση: Re: Sony A7S III
Ακριβως.
Δεν ειναι τιποτα ασχετοι τωρα οι βασιλιαδες του high iso για να βγαλουν καμερα με λιγοτερα Mp απο το προηγουμενο μοντελο.
Εστιαζουν ξεκαθαρα στους εικονοληπτες και λογικα θα υπαρχει λογος να το κανουν αυτο.
22 June 2006
34,850
NEO HRAKLEIO
Λόγος υπάρχει....εμάς δεν ικανοποιεί!
Εγώ περιμένω την a7 Mark IV....ελπίζω να δωσει εκει οσα θέλω.
Βασικά το μόνο που θέλω παραπάνω από την iii που έχω είναι ένα 4κ 60p 10 bit.
Kosh
7 September 2006
91,507
Εκεί ψηλά.....
Re: Απάντηση: Sony A7S III
600mbps bitrate
16bit RAW output
Αυτα τα 4 χαρακτηριστικα δεν ειναι ασχημα για οποιαδηποτε καμερα.
Στην ευαισθησια μαλλον καταλαβαινουμε (204000max iso ολες οι αλλες καμερες του ανταγωνισμου) γιατι διαλεξαν τα 12mp.
Και τα 15 στοπς DR θαναι επιτευγμα για τετοιου ειδους καμερα.
Εχουμε και καποια ακομα πιθανα νεα για την καμερα :
Gyroscope data will be available for post stabilization like the FX9.
Digital IS like the zv1 will be available for the first time on a full frame Sony Camera. This does not use further crop. Only the slight crop previously mentioned for UHD. The 4k is still 1:1 pixel readout.
There may be features left out at launch that will be available via software update. Similar to the FX9 version 2.0 update coming later this year. They will be mentioned on the presentation next week.
Compared to an FX9, this does not down sample 6K to 4K, which would require a 24mp sensor.
waroo
20 April 2012
1,697
οι πρώτες φωτογραφίες
σπαστή οθόνη με μικρότερο πλαίσιο και μεταφορά του movie button (σωστή κατά τη γνώμη μου)
το EVF φαίνεται τεράστιο συγκριτικά με την A7rIV!
και νέο μενού;
και μια λίστα με φήμες για:
- digital stabilization
- το χαμηλότερο ever rolling shutter
- από τα 100mpbs της a7III στα 600
θα τα χτυπήσει τα 4k πάντως
να δούμε τι θα πάρει απ'ολα αυτά η a7IV όταν βγει...
22 June 2006
34,850
NEO HRAKLEIO
διορθωσε πολλα... μενου, EVF, full touch screen, καλυτεροι codec 10bit, slow motion με ηχο, ελαχιστο RS, χωρις χρονικο οριο 30 λεπτων στην εγγραφη βιντεο, 120p 4k kai 240 1080 με πολυ καλη ποιοτητα εικονας , καλυτερη εργονομια, full size HDMI (πολυ σημαντικο) , εξωτερικο 16bit RAW κλπ
Δεν μας εδωσε εσωτερικο RAW, αλλα βολευομαστε με τα υπολοιπα.
Η τιμη ειναι πολυ τσουχτερη γιας μας βεβαια...ακουγεται 4200 στην Ευρωπη.
Τεσπα.... θα δουμε και την επισημη παρουσιαση σε λιγο και βλεπουμε.
evanfotis
26 March 2008
5,485
Θέλω να δω συγκριτικά με S1H.
Ξεκινώντας η α7s3 δίνει FF 4k/60 και πολύ καλύτερο AF κ φυσικά low light advantage.
Στα υπόλοιπα θα έχει ενδιαφέρον.
nicksoti
14 April 2013
1,911
Πλεον όλοι προσπαθούν να χωρέσουν cinema camera με IBIS και caf σε FF φωτογραφικά σώματα. Tα πάντα όλα δηλαδή. Αναγκαστικά θα υπάρχει κάποιος συμβιβασμός. Είτε με τη μορφή εξωτερικής εγγραφής, είτε στην υπερθέρμανση, είτε στην ανάλυση του αισθητήρα. Και φυσικά στο κόστος.
Πάντως για καθημερινή χρήση (και όχι μόνο) κάνεις δουλειά με πολύ λιγότερα χρήματα. Πχ η ZV1 που στο αντίστοιχο νήμα ψιλοθάψαμε, φαντάζει τρομερό εργαλείο και κάποια από τα specs της "δανείστικε" η μεγάλη από ότι φαίνεται. Με τα χρήματα μιας A7Siii/eos R5/SH1 αγοράζεις ZV1 + BMPCC4k με speed booster + EOS RP/R. Και τα έχεις όλα κι ας μην είναι σε 1 σώμα. Δεν μπορώ δηλαδή να πιστέψω ότι κάποιος την ίδια μέρα θα κάνει διαφημιστικό/video clip με Raw, vlogging/youtube και φωτογράφιση τοπίου ώστε να τον βολέψει που θα τα έχει όλα (ψιλοκουτσουρεμένα κιόλας) σε 1 σώμα.
tiniakos
7 August 2007
16,154
Τήνος / Ελλάς
Δίκιο έχεις.
Με πολλά λιγότερα χρήματα κάνεις δουλειά σε φωτογραφία και βίντεο, το μάτι να έχει και τα υπόλοιπα έρχονται.
22 June 2006
34,850
NEO HRAKLEIO
Σκοπός είναι να τα έχεις σε ε να σώμα....αυτό ζητάνε όλοι....κι αυτό παλεύουν οι εταιρείες.
Και θα γίνει προφανώς....σε λίγο απλά θα διαλέγεις σύστημα.
Το raw επίσης θα έρθει παντού, δεν είναι λογικό να έχεις raw σε φωτό και όχι σε βίντεο.
Όσο και να αρνούνται οι εταιρείες, σεμια δύο γενιές όλα αυτά θα έρθουν όπως πρέπει.
Χρόνια το ζητάμε....
