In terms of functionality, there is another simple but important part. That is, the power supply capacity of the HDMI output terminal has been strengthened from the conventional 150mA to 300mA. If you are familiar with AV equipment, you know that transmitting high-resolution, high-frame-rate video with a large amount of data over a long distance with an HDMI cable causes problems such as signal attenuation and poor delivery.
The AV amplifier, which new products appear every year, is an evolution of the previous model, but this time the circuit design such as the power supply, internal wiring, and printed circuit board pattern has been completely redesigned. In other words, it is not the level of "where has changed", but it is "all new" by recreating from scratch while using the know-how so far.
At that time, the amplifier circuit was redesigned. Compared to the conventional model, the slew rate has been improved by about twice. This is the same slew rate as the flagship separate amplifier "MX-A5200".
At a high slew rate, the followability of the signal is improved, and in particular, the reproducibility of a music signal including high frequencies such as a high resolution source is improved. However, in general, signal transmission becomes unstable in a high slew rate amplifier. The RX-V6A uses a new design circuit to achieve stable signal transmission even at high slew rates.
What I usually use is the "MusicCast" app for network music playback. Until now, it was an application for selecting and operating the music to be played, and the setting change of the AV amplifier was using "AV CONTROLLER", but from this time, you can also operate and change the setting of the AV amplifier from the MusicCast application. It became so. It's easy to understand and convenient that you don't have to use the two apps properly.
Από
εδώ
