@ Nik0sPs@r
Η ευχη σου εγινε πραγματικοτητα
WEB IF Ver.1.2 © 2009 - Telesat Team
FIX : Compatibility with older FW , 0.92880 or lower.
WEB IF Ver.1.1 © 2009 - Telesat Team
FIX : screen shot capture error , when you use 2 usb device.
WEB IF Ver.1.0 © 2009 - Telesat Team
This is the first version of Web If by me
My idea is that AzBox gets respectable Web Interface, and this is
just fundament which will be ( I hope ) upgraded more.
Short Tutorial for Installation :
Run the application, and choose location for install, default is /MMP,
If You dont know what Are You doing - just let it as it stay by default
Set-up parameters : IP address of AzBox, Username, Password
Press Next, wait that application verify if entered data is correct
If everything is ok, process of Installation will start and it will take
about 40 seconds. After installation process is finished, Your AzBox will
reboot itself and then Web Interface is ready for use
In Your favourite Browser ( IE, Firefox, Chrome, Opera ), enter
IP address of AzBox, and It will aks from You username and password which
are default in this case :
username = root
password = azbox
How to change password ( just for Web Interface ) :
connect on Your device by telnet and ssh and type this command :
hpasswd and press enter on keyboard
It will ask from You to enter new Password, enter it and press on keyboard Enter
It will ask You to enter same password for second time, to check if it is same as first entered
If Everything is ok, You will get message that Password is successifully changed
NOTE:
I would like to express big gratitude to NeotionBox ( iPod ) for support with Ideas ( which he has more
and which will be implemented in future releases of Web IF by me
Also gratitude to sofrenic for testing and all others which contribute in making of this Web Interface for AzBox HD.
Best regards,
telesat
http://rapidshare.com/files/325150038/AZBox_WebIf_Installer_v.1.2.rar.html
Υποψιν οτι οποιο pass και να εχεις στον δεκτη σου μετα την εγκατασταση του webif οταν στον internet explorer σου ζητηθει pass θα πρεπει να δωσεις azbox
username = root
password = azbox
NOTE:
Best regards,
telesat
