CBR/ABR/VBR: the 3 encoding modes
LAME is able to encode your music using one of its 3 encoding modes: constant bitrate (CBR), average bitrate (ABR) and variable bitrate (VBR).
Αγαπητοί φίλοι και φίλες,
Constant Bitrate (CBR)
This is the default encoding mode, and also the most basic. In this mode, the bitrate will be the same for the whole file. It means that each part of your mp3 file will be using the same number of bits. The musical passage beeing a difficult one to encode or an easy one, the encoder will use the same bitrate, so the quality of your mp3 is variable. Complex parts will be of a lower quality than the easiest ones. The main advantage is that the final files size won't change and can be accurately predicted.
Average Bitrate (ABR)
In this mode, you choose a target bitrate and the encoder will try to constantly maintain an average bitrate while using higher bitrates for the parts of your music that need more bits. The result will be of higher quality than CBR encoding while the average file size will remain predictible, so this mode is highly recommended over CBR.
Variable bitrate (VBR)
In this mode, you choose the desired quality on a scale going from 9 (lowest quality/highest distortion) to 0 (highest quality/lowest distortion). Then encoder tries to maintain the given quality in the whole file by choosing the optimal number of bits to spend for each part of your music. The main advantage is that you are able to specify the quality level that you want to reach, but the inconvenient is that the final file size is totally unpredictible.
Το ABR είναι καλυτερο απο το CBR ποιοτικά στο video encoding. Εγω το εχω ABR auto. Οπως ηταν απο την αρχή. Υπαρχει και το VBR που ειναι το καλυτερο αλλα δεν το εχει το box. VBR>ABR>CBR έτσι παει η σειρά. Και γω δεν τα ήξερα ακριβώς αλλα το έψαξα στο internet.
Σε έναν κόσμο όπου όλοι θα είχαμε γραμμές με σταθερό transfer rate 200Mbps π.χ., το CBR θα ήταν το καλύτερο.
Επειδή δεν έχουμε όλοι σφαίρα γραμμές, και μπορεί να υπάρχουν και μεγάλες πτώσεις στην ταχύτητα αν π.χ. έχουμε πολλούς χρήστες στην γραμμή, υπάρχουν τα VBR/ABR και τα "πρωτόκολλα" που κάνουν target bitrate adaptation.
Το VBR/ABR μπορεί να είναι καλύτερο από το CBR αν έχουν υψηλότερο bitrate ενώ ταυτόχρονα το minimum bitrate target τους δεν πέφτει κάτω από το br του CBR.
VBR/ABR έχουν μικρές ως και μη εντοπίσημες διαφορές μεταξύ τους (με κοντινά bitrates προφανώς, όχι με ουσιαστική διαφορά στο file size δηλ.).
Αν κατάλαβα σωστά, κάποιος με αρκετά γρήγορη και σταθερή σύνδεση καλύτερα να προτιμήσει το CBR στα 7 Mbps !
Και σε μένα τα ζήτησαν τα 50 ευρώ μετατροπή, παρότι έχω ανοιχτό συμβόλαιο, γιατί η δέσμευση έχει λήξει από τον Ιούλιο.Τα 50€ για την μετατροπη που μου ειπε μαλλον ειναι αυτο που λενε τα παιδια τελος υποβαθμισης
Όταν της είπα ότι "Γιατί τότε να μην το κάνω σε άλλο όνομα, κάποιου μέλους της οικογένειας, ώστε να πάρω και τους 3 μήνες δώρο;"
Μου είπε ότι οι τρεις μήνες δεν είναι ακριβώς δώρο, αλλά μια μικρή έκπτωση 5-10 ευρώ το μήνα στο πάγιο.
-- edit --
Και επίσης να μοιραστώ κι εγώ την εμπειρία μου,
Συνδρομητής Full Pack με 50άρα γραμμή και απεριόριστα κινητά, και novagoExtra, έχει λήξει η δέσμευση από το καλοκαίρι.
Τους πηρα τηλ για ανανέωση και μου είπαν θα με καλέσει το τμήμα ανανεώσεων.
Με πήραν μετά από 2-3 μέρες, και μου είπαν ότι με καλούν κατευθείαν από τα κεντρικά της Nova ώστε να μου δώσουν ειδική προσφορά, λόγω των τόσων χρόνων που είμαι συνδρομητής.
Η προσφορά ήταν μετατροπή σε 100αρα και EON+ με απεριόριστα σταθερά και κινητά στα 46 ευρώ. Κόστος μετατροπής 50 ευρώ και χωρίς μήνες δώρο (όπως είπα από πάνω).
Ναι θα παίξει μόλις τώρα μίλησα με την nova γιατί εμένα είναι να έρθει σήμερα το box και μου είπαν εάν δεν έχει έρθει η υπηρεσία θα ενεργοποιηθεί ούτως ή άλλως σήμερα οπότε θα μπορώ να την χρησιμοποιήσω κανονικάΜου ήρθαν πριν από λίγο οι κωδικοί της υπηρεσίας, χωρίς να μου έχει έρθει ο τεχνικός με το box.
Αν εγκαταστήσω την εφαρμογή στο mi box θα παίξει; Διαβάζω ότι δουλεύει μόνο σε κινητό και tablet, ισχύει;
Αν έχεις υπογράψει συμβόλαιο με το box μπορεί να το χρησιμοποιήσεις ΚΑΙ στο mi boxΜου ήρθαν πριν από λίγο οι κωδικοί της υπηρεσίας, χωρίς να μου έχει έρθει ο τεχνικός με το box.
Full quality και σε tv app ας πουμε lg tv?Κύριοι, full quality μόνο από eon box. Μην συγκρίνετε με cast, browsers κλπ. Αν θέλετε να κάνετε σύγκριση να είναι μήλα με μήλα. Browser με browser,cosmote box με eon box, cast με cast. Το box παίζει το native raster scan της πηγής χωρίς μετατροπές. Σε όλα τα άλλα γίνονται μετατροπές (που ρίχνουν την ποιότητα).
Το tv app της eon αλλά και της cosmote είχαν λίγο καλύτερη εικόνα από τα box! Τα έχω δοκιμάσει και τα δύο σε Samsung smart.Full quality και σε tv app ας πουμε lg tv?
