OPPO BDP-93 BD Player
ενταξυ. εγω εχω θεμα με το 95αρι μου και με 15μ hdmi. γιαυτο σε ρωταω. αλλα το δικο μου θεμα εχει να κανει με τα 15μ hdmi σε συνδιασμο με τον qdeo.
Αμα πρεπει να κρυψω τα καλωδεια ισως φτασω και τα 10 μετρα.
Ελλαδα δεν βλεπω να το πουλαει κανεις οποτε κοιταω εξω.
Το οππο 95 ειναι πανεμορφο αλλα τα λεφτα αποιρα !!!
Αναφέρθηκε στο νήμα του 95, το μεταφέρω και εδώ:
Release date: December 23, 2011
Category: Latest Official Release
Main Version: BDP9xEU-61-1219
Loader Version: CN0900
Sub Version: MCU93-09-0218 (BDP-93EU)
Sub Version: MCU95-08-0218 (BDP-95EU)
Note: This version was previously released as a public beta test version on December 6, 2011. It has been qualified and promoted to an official release version. If you have installed the public beta version during the week of December 5, there is no need to reinstall the firmware.
Release Notes:
This version is designed for the OPPO BDP-93EU and BDP-95EU Blu-ray Disc players. This version is the same as the latest Public Beta release version BDP9xEU-60-1125B. Comparing to the previous Official release version BDP9xEU-57-917, the major changes are:
1. Added "Title/Chapter Repeat" capability to some Blu-ray movies authorized with BD-Java technology. During movie playback, press the REPEAT button on your remote to select the desired repeat mode. As BD-Java is an evolving technology, this function may not apply to all present and future BD-Java based movies.
2. Resolved the loading failure issue observed on several recently-released Blu-ray TV series, including "Fringe" (Season 3, 2011), "Chuck" (Season 4, 2011), "Dexter" (Season 5, 2011). Normally, these movies can be played with no problems when initially loaded. However, if disc playback has been stopped or the disc ejected, the disc would fail to load properly and remain on a black screen with the front VFD displaying 00:00:00. The cause of this error was related to the player failing to load pop-up menu to display disc resume functionality. This firmware properly resolves the pop-up menu.
3. Resolved a Fast Forward (FWD) bug during some FLAC music playback. Customers have reported that during some FLAC playback, if you press the FWD button to 2x and up, the music playback could automatically skip to the next track. This issue has been resolved.
4. Resolved the extra BD-Live setting required to load some Blu-ray movies such as "Warlord" (2010). To load such titles it was necessary to set "BD Live" to be "ON" under Network Setup, even if no internet connection was present. This issue has been resolved and for all "BD-Live" states ("ON", "LIMITED", "OFF").
5. Resolved FL and FR channels missing from user generated 7.1 WAV media. Customers have reported that FL and FR channel contents may be lost during the playback of 7.1 WAV files. This issue has been resolved.
6. Added the direct play capability to BDAV folder. BDAV is a container for videos recorded using AVCHD camcorders such as Sony's HDR-SR series.
7. Improved general disc compatibility based on recent and upcoming Blu-ray releases as well as user-submitted disc samples.
All features and improvements of the previous firmware are also included in this version.
Στο αμερικάνικο avsforum διαμαρτύρονται έντονα για την κακή απόκριση του τ/χ στο νήμα του Oppo 93. Εδώ και στο νήμα του 95 δεν έχω ακούσει κανέναν να διαμαρτύρεται.
Προσωπικά, το έχω καταργήσει. Είναι ότι χειρότερο έχω πιάσει στα χέρια μου όλα αυτά τα χρόνια. Χρησιμοποιώ ένα προγραμματιζόμενο της Logitech αλλά και πάλι το αποτέλεσμα δεν είναι πολύ ικανοποιητικό. Τουλάχιστον με το logitech ''ακούει'' όταν είναι στραμμένο πάνω του.
Με το δικό του, κάποιες φορές ανταποκρίνεται καλούτσικα και κάποιες πρέπει να πατήσεις τα πλήκτρα δυο και τρεις φορές. Ασε που είναι γκουμούτσα.
(Το ρακ μου είναι ανοιχτού τύπου, δεν υπάρχουν εμπόδια μπορστά, φορτωμένο με 10 μηχανήματα και μόνο με το τ/χ του Οππο υπάρχει πρόβλημα)
Re: Απάντηση: OPPO BDP-93 BD Player
Με το 95 μέχρι στιγμής δεν έχω παρατηρήσει κανένα πρόβλημα. Υπακούει απροβλημάτιστα.
Κακά μαντάτα έρχονται από την άλλη άκρη του Ατλαντικού!
Στο αμερικανικό φόρουμ οι ψίθυροι έγιναν φωνές.
Η Oppo δέχεται πιέσεις να σταματήσει την υποστήριξη αναπαραγωγής αρχείων .iso στα μηχανάκια της και μάλλον αυτό θα συμβεί.
Από εδώ και μπρος διαβάστε προσεκτικά το change log των μελλοντικών αναβαθμίσεων.
"ISO PLAYBACK is being removed via an upcoming firmware update. That will include DVD, Blu-Ray, and my use of it, DVD-Audio."
"Just confirmed ISO support will be removed in a future firmware. They are too small of a company not to comply."
επιτέλους βρήκαν τον τρόπο να καταπολεμήσουν την πειρατεία... πόσο χαζοί είναι αυτοί που "πιέζουν" τελικά?
Μια επιλογή είναι να μην ξανα-αναβαθμίσουμε τα 93/95 από τη μέρα που θα κυκλοφορήσει το "fix"
Μπορούμε επίσης να παραιτηθούμε από τα .iso και να αναβαθμίζουμε κανονικά.
Εγώ όμως εκτιμώ ότι θα συμβεί κάτι άλλο και θα συνεχίσουμε να απολαμβάνουμε τις βελτιώσεις. Θα κυκλοφορήσουν εναλλακτικά firmware από ''ανεξάρτητες'' ομάδες. Το Oppo έχει εξαπλωθεί πολύ, είναι εξαιρετικά δημοφιλές και φανατίζει. Οσοι το απέκτησαν το αγάπησαν με έναν μοναδικό τρόπο.
...και όπως αναφέρεις η κίνηση αποτελεί ένα σημαντικό βήμα για την πάταξη της πειρατείας!
Aλεξ ο μόνος μου καημός για τα iso είναι τα καμιά 40 SACD iso που έχω καμένα σε DVD...
Λίγες ταινίες 3D που αξίζουν (για τα γούστα μου) πάω και τις αγοράζω/νοικιάζω!
Πάντως πολύ δύσκολα θα κάνω νέα αναβάθμιση αν τελικά γίνει το fix!
To 93 έτσι όπως είναι τώρα, μου κάνει όλα τα κέφια πλην ποιότητας υποτίτλων (δίκτυο δεν βλέπω να στήνω έτσι κι αλλιώς...)
Να συνυπολογιστεί επίσης ότι σε περίπτωση πώλησής του στο μέλλον για το νέο OppoBDP-XX (προφανώς 4Κ θα είναι, δεν υπάρχει λόγος για κάτι άλλο...) καλό θα ήταν ο αγοραστής να έχει το δικαίωμα επιλογής και iso playback...
-bye-
Απάντηση: Re: OPPO BDP-93 BD Player
Οτι έχεις γραμμένο σε DVD παύει να είναι iso. Είναι κανονικότατο δισκάκι dvda ή sacd. Δεν έχεις να φοβάσαι τίποτα.
Αυτό που θα επηρεαστεί είναι η απευθείας ανάγνωση .iso από σκληρό δίσκο και θα αφορά μόνο br-iso, dvd-iso και dvda-iso. Ετσι κι αλλιώς τα sacd-iso δεν διαβάζονται από κανένα player.
Τhanx for the info Αλεχ!!! :a0210:
Άρα, εφόσον το fix επηρεάζει μόνο την αναπαραγωγή από δίσκο, θα συνεχίσει να διαβάζει και αντιγραμμένα ΒDR... τέλεια!
