Zidoo X9S (4K,HDR,3D,Blu ray Menu,HD Audio)
Αν και ειχα αλλη πληροφορηση τελικα επελεξαν να το δωσουν..
Εχουμε λοιπον επισημα το v2.015
Model: ZIDOO X9S
Update list
System:
1,Improve the Stability of system
2,Fix ZDMC port conflicts
3,Add weather in China
4,Fix the setting of front pad can not saved in system
Player:
1,Add 4 colors for internal subtitle
2,Optimize the Video information
3,Optimize subtitle downloading
Filemanager:
1,Add SMB v2
Blu-ray navigation:
1,Fix failing to display subtitle when there is only one subtite
2,Fix failing to choose subtitle in certain movies.
3,Optimize 4K Blu-ray navigation
Theater:
1,Fix malfunction of sorting in PC interface.
2,Add a function to zoom in the photo of actors
3,Fix actors can not relate to the movies when it comes Chinese language.
4,Fix the poster don't refresh when changing from PC interface.
5,Add "year" information for search results when rematching movies.
6,Add a Loop mode in the left side bar
7,Improve Accuracy for matching actors
8,Fix locked movies can be opened by certain operation
9,Fix crash problems when scanning
10,Add path and title displaying of movies
11,Add self-association results when re-matching movies
12,Improve UI
13,Add a function to hide useless files
14,Fix crash after reset data
15,Fix removing inoperative
16,Improving movies matching, such as "Lost in Space" match to "Lost in Space 11"
17,Fix crash when unmatched files are too many
18,Fix crash when removing while scanning
19,Optimize unmatching videos UI.
20,Add more scanning ways
21,Add portaits of actors.
22,Fix crashs when scanning certain SMB devices.
23,Add a tag for path which don't want to scan.
Control Center:
1,Add editing for country and movie duration
2,Fix some movies can't re-matching by IMDB
Launcher
1, New UI
2,Add changing wallpaper
Quicksettings:
1, New UI
2,Improve the way of operative
3,Fix "auto"mode don't work in HDMI audio output
Onekey Clean:
1,New UI
2,Fix problems of self-starting management
3,Improve Cleaning
Setupwizard:
1,Improve UI
Download:http://ota-cloudfront.zidoo.tv/X9S/OTA/OTA-ZIDOO_X9S-v2.0.15-201803082053.zip
MD5:5d40aea27fdbcb014d818d0e2ba0ce91
Re: Απάντηση: Zidoo X9S (4K,HDR,3D,Blu ray Menu,HD Audio)
Περιφημα
Περιμενω το νεο κομματι με πιο πολυ ανυπομονησια τωρα χαχα
Ναι περιμέναμε την 2.0.17, πάντως δείχνουν να δουλεύουν σοβαρά το HT2.0 και λαμβάνουν υπόψιν τις προτάσεις των χρηστών
Παντως σπανιο για κινεζοκουτι να το σαπορταρουν ετσι μετα απο 1,5 χρονο και να ψαχνει ακομα να το αγοραζει κοσμος.
Ωραιοι. Καποιος εκει καταλαβε οτι τα λεφτα δεν βγαινουν μονο πουλωντας νεα μηχανακια.
Εγώ πιστεύω ότι κύριο μέλημα τους είναι η ανάπτυξη μιας σοβαρής εφαρμογής UI (HT2.0) για να διαφέρουν από τον ανταγωνισμό και στη συνέχεια θα δώσουν βάρος σε νέα μηχανάκια.
Και αυτο να ειναι,οφελος δικο μας :)
Που θα παει...θα βγει σταθερο fw,γιατι το κουτακι απο hardware ειναι σουπερ
βεβαια να πω την αληθεια μου μου λειπει το himedia που ουτε fw ηθελε ουτε τιποτα.σταθεροτατο
Ακόμα δεν έχω πεισθεί ότι φταίει η ίδια η zidoo ή είναι bugs στο SDK του Soc, ο χρόνος θα δείξει! Είναι επίσης και από τα λίγα που έχουν δυνατότητες NAS, δεν είναι ένα απλό streaming κουτί. Ίσως αν έδινε αναβάθμιση σε Android 7.0.1 να λύνονταν κάποια προβλήματα
Το δικό μου έχει την 2.0.5
Γιατί όταν πατάω το "Online update" μου γράφει "Your software is up to date";
Μπάμπη η αναβάθμιση γίνεται με στικάκι. Στο φόρουμ που δίνει το update έχει αναλυτικές οδηγίες πως να το κάνεις
Απάντηση: Re: Zidoo X9S (4K,HDR,3D,Blu ray Menu,HD Audio)
:ernaehrung004:
ΟΚ.. Σ´ευχαριστώ.
Πάω για διάβασμα.
Ω ναι!! Και έκαναν αυτό που τους ζήτησα, αναζήτησή μέσω ηθοποιών κτλ! Πατάς σε έναν ηθοποιό και εκτός από τις εικόνες σου δείχνει και σε ποιες ταινίες που είναι στη βιβλιοθήκη σου παίζει.
Πρόσθεσαν κάποια πράγματα, όπως αυτό με τους ηθοποιούς που ήταν σημαντικό μείον, αλλά δεν λύθηκαν πιο σοβαρά προβλήματα, τουλάχιστον σ´ εμένα.
Δεν μπορώ να καταλάβω πχ γιατί ενώ αναγνωρίζει κανονικά τη σειρά σαν 1η σεζόν την 2η την οετάει στα Others. Το ίδιο κάνει πχ στο Hawaii five-0. Όλες τις σεζόν κανονικά και στην τελευταία μέχρι το 14ο επεισόδιο όλα καλά κι απο κει και πέρα τίποτε. Δεν τα αναγνωρίζει, σαν να μην κάνει refresh. :nounder:
Nαι το βλεπω και εγω...Βελτιωθηκε αρκετα, θετικοτατο!
Mεχρι στιγμης παει μια χαρα
Το μονο που μενει να διορθωσουν ειναι το θεμα των υποτιτλων που τους το επισημενουν αρκετοι εξω..
Να επιλεγει πρωτα τους εξωτερικους υποτιτλους σε σχεση με τους ενσωματωμενους και να κρατα τις ρυθμισεις απαξ και να μην χρειαζεται καθε φορα να κανουμε αλλαγες..
Σε καλο δρομο ειμαστε αλλα πρεπει να βιαστουν γιατι σε λιγο καιρο ερχονται τα Dune με nougat...
Για όποιον θέλει netflix στο Zidoo X9S ας δοκιμάσει το πιο κάτω link ,είναι η έκδοση που κατέβασα και παίζει netflix με ανάλυση 720x480p:
https://apkdam.com/download/?p=467&package=com.netflix.mediaclient&lang=en
Από το τιποτα (δείχνει ασύμβατο στο play store) καλύτερο αυτο.
Ωραιο το homethetre κια μπραβο τους, αλλα δεν συγκρινεται με το zdmc....εαν μπορουσαν να λυσουν το θεμα με το κρασαρισμα του zdmc οταν παιζεις με τον zidoo player θα ηταν τελεια......
