1
General
Unique ID : 183700691698923425348613589817826749179 (0x8A33775F17EA5D78BC4A184D27EC2AFB)
Complete name : 1.mkv
Format : Matroska
Format version : Version 1
File size : 6.56 GiB
Duration : 1h 37mn
Overall bit rate : 9 675 Kbps
Encoded date : UTC 2011-07-31 10:07:47
Writing application : mkvmerge v2.3.0 ('Freak U') built on Sep 8 2008 18:32:16
Writing library : libebml v0.7.7 + libmatroska v0.8.1
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile :
[email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 5 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 1h 37mn
Bit rate : 9 029 Kbps
Width : 1 920 pixels
Height : 816 pixels
Display aspect ratio : 2.35:1
Frame rate : 24.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.240
Stream size : 5.99 GiB (91%)
Writing library : x264 core 116 r2019 9cc407d
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=24 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc=2pass / mbtree=0 / bitrate=9029 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:1.00
Language : English
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Codec ID : A_AC3
Duration : 1h 37mn
Bit rate mode : Constant
Bit rate : 640 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Stream size : 444 MiB (7%)
Title : DD5.1
Language : English
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Title : Nederlands SRT
Language : Dutch
Text #2
Format : UTF-8
Title : Engels
Language : English
2
General
Unique ID : 171942844658836832210918302725131497346 (0x815AFCC1576EBBD1B8488D3E7BC46F82)
Complete name : 2.mkv
Format : Matroska
Format version : Version 2
File size : 7.43 GiB
Duration : 1h 48mn
Overall bit rate : 9 807 Kbps
Encoded date : UTC 2010-08-13 21:31:55
Writing application : mkvmerge v3.3.0 ('Language') built on Mar 24 2010 14:59:24
Writing library : libebml v0.8.0 + libmatroska v0.9.0
Video
Format : AVC
Format profile :
[email protected]
Format settings, ReFrames : 3 frames
Muxing mode : Container
[email protected]
Duration : 1h 48mn
Bit rate mode : Variable
Bit rate : 7 658 Kbps
Maximum bit rate : 18.0 Mbps
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 23.976 fps
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.154
Stream size : 5.65 GiB (76%)
Title : x264
Writing library : x264 core 79 r1352M d487de4
Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=7 / psy=1 / psy_rd=1.0:0.3 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / chroma_qp_offset=-4 / threads=6 / nr=0 / decimate=1 / mbaff=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / wpredp=0 / keyint=24 / keyint_min=2 / scenecut=40 / rc_lookahead=24 / rc=2pass / mbtree=1 / bitrate=7658 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / vbv_maxrate=18000 / vbv_bufsize=18000 / ip_ratio=1.10 / aq=1:1.00 / pulldown=0 / nal_hrd=1
Language : English
Audio #1
Format : AC-3
Codec ID : A_AC3
Duration : 1h 48mn
Bit rate : 640 Kbps
Bit depth : 16 bits
Stream size : 497 MiB (7%)
Title : AC3
Language : English
Audio #2
Format : DTS
Format/Info : Digital Theater Systems
Codec ID : A_DTS
Duration : 1h 48mn
Bit rate : 1 510 Kbps
Bit depth : 24 bits
Stream size : 1.14 GiB (15%)
Title : DTS
Language : English
Text
Format : UTF-8
Title : Subtitles
Language : Dutch
3
General
Complete name : 3.mkv
Format : Matroska
File size : 8.74 GiB
Duration : 2h 0mn
Overall bit rate : 10.4 Mbps
Writing application : x264.exe
Writing library : mkv2rls v1.4 (date: 2011 mar 29)
Video
Format : AVC
Format profile :
[email protected]
Format settings, ReFrames : 4 frames
Duration : 2h 0mn
Bit rate : 8 908 Kbps
Height : 1 040 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.186
Stream size : 7.30 GiB (84%)
Writing library : x264 core 116 r2044 392e762
Encoding settings : cabac=1 / ref=4 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=8908 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 2h 0mn
Bit depth : 24 bits
Stream size : 1.27 GiB (14%)
Language : English
Text
Format : UTF-8
Language : English
4
General
Complete name : E:\4.mkv
Format : Matroska
File size : 5.46 GiB
Duration : 2h 2mn
Overall bit rate : 6 397 Kbps
Video
Format : AVC
Format profile :
[email protected]
Duration : 2h 2mn
Bit rate : 4 888 Kbps
Width : 1 280 pixels
Height : 536 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.297
Stream size : 4.06 GiB (74%)
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=8 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=50 / rc=2pass / mbtree=1 / bitrate=4888 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 2h 2mn
Bit depth : 24 bits
Stream size : 1.29 GiB (24%)
Language : English
Text
Format : UTF-8
Language : English
5
General
Unique ID : 221021404526690456992975615563126437722 (0xA6472C93F86656039603A9BC57FE775A)
Complete name :5.mkv
Format : Matroska
File size : 12.7 GiB
Duration : 2h 24mn
Overall bit rate : 12.5 Mbps
Encoded date : UTC 2008-03-22 19:36:15
Writing application : mkvmerge v2.1.0 ('Another Place To Fall') built on Aug 19 2007 13:40:07
Video
Format : AVC
Format profile :
[email protected]
Duration : 2h 24mn
Bit rate : 11.0 Mbps
Height : 816 pixels
Original display aspect ratio : 2.35:1
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.293
Stream size : 10.9 GiB (86%)
Writing library : x264 core 58 svn-745M
Encoding settings : cabac=1 / ref=5 / deblock=1:0:0 / analyse=0x3:0x113 / me=umh / subme=6 / me-prepass=0 / brdo=1 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=2 / deadzone=4,6 / chroma_qp_offset=0 / threads=6 / nr=0 / decimate=1 / mbaff=0 / bframes=5 / b_pyramid=1 / b_adapt=1 / b_bias=0 / direct=3 / wpredb=1 / bime=1 / keyint=250 / keyint_min=25 / scenecut=40(pre) / rc=2pass / bitrate=11000 / ratetol=1.0 / rceq='blurCplx^(1-qComp)' / qcomp=1.00 / qpmin=10 / qpmax=51 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / pb_ratio=1.30 / aq=1:0.5:13.0
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 2h 24mn
Bit depth : 24 bits
Stream size : 1.53 GiB (12%)
Language : English
Text
Format : UTF-8
Language : English
6
General
Unique ID : 200343510523697021638847094915893226823 (0x96B8C1B111EFA60EBB6D3847C032ED47)
Complete name : 6.mkv
Format : Matroska
File size : 6.02 GiB
Duration : 2h 18mn
Overall bit rate : 6 223 Kbps
Encoded date : UTC 2011-06-27 07:46:59
Writing application : mkvmerge v4.8.0 ('I Got The...') 编译于 May 24 2011 03:12:58
Writing library : libebml v1.2.0 + libmatroska v1.1.0
Video
Format : AVC
Format profile :
[email protected]
Format settings, ReFrames : 9 frames
Duration : 2h 18mn
Bit rate : 4 650 Kbps
Height : 534 pixels
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.284
Stream size : 4.44 GiB (74%)
Writing library : x264 core 115 r1995 c1e60b9
Encoding settings : cabac=1 / ref=9 / deblock=1:-3:-3 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=12 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=8 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=2pass / mbtree=1 / bitrate=4650 / ratetol=1.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / cplxblur=20.0 / qblur=0.5 / ip_ratio=1.40 / aq=1:1.00
Language : English
Audio
Format : DTS
Codec ID : A_DTS
Duration : 2h 18mn
Bit depth : 16 bits
Stream size : 1.46 GiB (24%)
Language : Japanese
Text
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : Japanese
οι 1,2,3,4 παίζουν μεγάλους. η 5 είναι η ιν και η 6 η γιαμ
