Re: Αγορα νεου πικαπ
Tούς λόγους που δεν μπορούσε να γίνει αυτό τους εξήγησα όπως και ότι η κρίση ήταν βάση του ηχητικού αποτελέσματος δύο σετάπ
παρόμοιας τιμής.
Η Matsushita έχει βγάλει και Hi-End εκδόσεις του χωρίς δυστυχώς να αλλάξει τον βραχίονα.
The SL-1200MK4 (1997) is only available for sale in Japan. This model is aimed at the hi-end audiophile market rather than for DJ's. This is the last model made with the detent in the middle of the pitch adjustment slider. It has a third button added for 78 RPM located to the right of the 33 RPM and 45 RPM buttons. It is also designed to be used with regular removable RCA cables (along with a removable ground/earth cable) rather than having hard wired RCA cables like all the other 1200 models.
The SL-1200MK6 and SL-1200MK6K1 (black) released in 2007 have some minor improvements including: Improved tonearm mounting and oxygen-free copper wire being used for the signal, improved vibration damping in the body, improvements to the pitch control accuracy and better LEDs
Βέβαια είναι εκπληκτική η ακρίβεια της περιστροφής του όπως παραδέχοντε όλοι
The SL-1200 design strengths
The SL-1200 series was developed as a special project by Technics parent company Matsushita in an attempt to solve many of the problems related to the difficult task of turntable design. The task included minimizing acoustic feedback, unwanted resonances, wow & flutter and speed errors.
This was achieved by designing a plinth made of a non-resonant composite sandwiched between a cast alloy top plate and a solid rubber base. Additionally the use of rubber damped and spring loaded feet ensured that the Technics SL-1200 series was very well insulated against acoustically harmful feedback.
The drive system designed by Matsushita is of the direct drive variety rather than the more commonly found belt drive type. This design was developed in order to virtually eliminate the problems of wow and flutter and also produces a very quiet turntable with minimal motor and bearing noise (rumble). The SL-1200 utilizes a Frequency Generator Servo Control Quartz Lock system that
is claimed to produce the most accurate and consistent speed possible. The system is immune to static and dynamic stylus drag which would otherwise cause unwanted speed variances that change the pitch and tempo of the music. Due to these strengths the SL-1200 lends itself to both hi quality Hi-Fi reproduction and demanding DJ usage
http://en.wikipedia.org/wiki/SL-1200
