Intel NUC (Intel Next Unit of Computing)
Λοιπόοοοον...
η ZOTAC έβγαλε ανακοίνωση όπου αποσύρει τα εξής μηχανήματα (σειρά CI) (λόγω υπερθέρμανσης)
G142400002648; G142400002663; G142500001680; G142500001678; Q142221300014; G142400002649; G142400002662; G142400002667; G142500001676; G142400002651; G142400002666; G142400002668; G142400002659; Q142221300007; Q142221300018; G142400002951; G142400002650; G142300005590; G142400002954; G142400002952; Q142221300006; Q142221300017; Q142221300015; Q142221300016; Q142221300011; G142400002955; G142400002664; Q142221300008; G142400002652; G142500001677; G142400002661; G142400002670; G142400002665; Q142221300009; G142500001679; Q142221300012; Q142221300010; G142400002660; G142400002658; Q142221300013; G142400002669; G142200000425; G142200000444; G142200000479; G142200000450; G142200000467; G142200000457; G142200000489; G142200000493; G142200000462; G142200000463; G142200000464; G142200000452; G142200000447; G142200000451; G142200000460; G142200000466; G142200000409; G142200000407; G142200000484; G142200000495; G142500001964; G142200000456; G142500001961; G142200000424; G142200000413; G142500001962; G142200000446; G142200000426; G142200000485; G142200000483; G142200000422; G142200000492; G142200000405; G142200000465; G142200000402; G142200000414; G142200000410; G142200000416; G142200000459; G142200000458; G142200000491; G142200000430; G142200000455; G142200000415; G142200000418; G142200000411; G142200000461; G142200000442; G142200000419; G142200000445; G142200000454; G142200000470; G142200000412; G142200000448; G142200000443; G142200000453; G142200000408; G142200000406; G142200000441; G142200000488; G142500001965; G142200000494; G142200000417; G142200000427; G142200000487; G142200000478; G142200000420; G142200000486; G142200000423; G142200000468; G142200000480; G142400003512; G142200000428; G142200000477; G142200000449; G142500001963; G142200000429; G142200000401; G142200000476; G142200000404; G142200000490; G142200000403; G142200000481; G142200000421; G142200000482; G142200000469
Όμως ... δεν ξέρουμε πάλι ποιες τελικά είναι οι θερμοκρασίες στα "καλά" τους...
Αναμένουμε review ... ΔΕΝ αγοράζουμε... για να μην "καούμε"....
Re: Απάντηση: Intel NUC (Intel Next Unit of Computing)
Λοιπόν κάποιος που το αγόρασε ανέφερε 90oC όταν παίζει 1080p video...
Όλα τα νουκ έχουν το εξής "κακό". Είναι ρυθμισμένα απο τη μαμά ιντελ με thermal target το οποίο βεβαίως αλλάζει μέσω bios. Δηλαδή για να μην ανοίγει σχεδόν ποτέ το ανεμιστηράκι τους, το βάζουν στους 90° οπότε αν δεν ξεπεράσει αυτό δεν λέει να ανάψει και "ψήνεται". Εγώ ας πούμε το έχω ρίξει στους 60. Επιλογή σου είναι ;)
Λοιπόοοοον...
Θα αφαιρέσουν την ζελατίνα απ'την πάστα και θα τα ξαναπουλήσουν?:p
Αγόρασα τελικά ένα NUC 34010... αλλά δεν μου δουλεύει η κάτω θύρα της μνήμης... έστειλα μήνυμα στην Intel και μου απάντησαν:
Thank you for contacting Intel® Customer Support.
We have received your email and are happy to assist you.
Please we would like you to inform you that in most NUCs the lower slot does not work but you could test with a different memory.
The link below gives the list of supported memory configurations also the list of tested memory
http://www.intel.com/support/motherboards/desktop/sb/CS-034475.htm
Είμαστε σοβαροί..? δεν δουλεύει η κάτω θύρα μνήμης στα NUCS????!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Έχω δύο dimms και δουλεύουν κανονικά. Μήπως εννοεί ότι αν έχεις ένα dimm δεν μπορείς να το βάλεις στο κάτω slot;
- Εσύ πόσα dimm προσπάθησες να εγκαταστήσεις ;;;
- Πες μας και τον ακριβή τύπο του dimm που αγόρασες
- Από ποιο μαγαζί το αγόρασες το NUC 34010 ;; αγόρασες και από εκεί τις μνήμες ;;;; μήπως ... μήπως έχει κάποιο πρόβλημα (χαλασμένη/ασύμβατη) μία από τις μνήμες η και οι 2 ;;;;
δες αν οι μνήμες ειναι στον κατάλογο συμβατότητας που σου έστειλε η Intel.
- Αν το αγόραζες από MSystems (Αθήνα) θα δοκίμαζαν τις μνήμες άμεσα και θα σου έλεγαν τι εφταιγε (ειναι πολύ επαγγελματίες και πολύ εξυπηρετικοί
Μην ανχώνεσαι ΣΙΓΟΥΡΑ θα βρεθεί λύση άμεσα.
Αν μπορείς πες μας την ακριβή σύνθεση του NUC που σκέπτεσαι να φτιάξεις.
Α ..... και πριν το ξεχάσω ...... ΚΑΛΟΡΙΖΙΚΟ
- 2
- Kingston Part Number: HX321LS11IBK2/8
Πάρτε τώρα και τη 2η απάντηση από την Intel..
We are writing to confirm to you that it is normal that the memory does not work on the lower slot. This is standard; it should definitely work in the upper slot.
Please do not hesitate to contact us if you have any questions.
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ΟΛΕΕΕΕΕΕΕΕ !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! ΟΛΕΕΕΕΕΕΕΕΕΕΕΕΕΕΕΕΕ!!!!!!!!!!!!!!!!!!!!!!!!!
Αφου σου επιτρεπουν να τους ρωτας , τοτε στειλε το εξης μηνυμα
Since , i do not hesitate to contact you , then i am asking you, to take your product back.
- 2
- Δεν μας ειπες εάν οι 2 μνήμες ειναι στην λίστα της Intel .....
- Τι γίνεται εάν δοκιμάσεις μόνο 1 μνήμη ;;; πρώτα στην επάνω θέση και μετά στην κάτω θέση που δεν δουλέυει ;;; επανέλαβε και με την άλλη μνήμη το ίδιο σενάριο και πες μας το αποτέλεσμα.
- Από ποιο μαγαζύ το αγόαρασες ;;;; πήγες να τους πεις το πρόβλημά σου ;;;; τι σου απάντησαν ;;;;
Χωρίς παρεξήγηση αλλά μόνον για να προσπαθήσουμε να βοηθήσουμε την κατάσταση που σίγουρα σε νευριάζει αφάνταστα !!!!!!!
Πες μας τι ΑΚΡΙΒΩΣ εγραψες στην επικοινωνία στην Intel (λες οτι πήρες 2η απάντηση άρα μάλλον έστειλες 2 μηνύματα) όχι την δική σου μετάφραση αλλά ακριβώς το κείμενο (μάλλον στα Αγγλικά) που έστειλες στην Intel.
Πιές κανένα ουζάκι, πάνε σε καμιά παραλία, δες μερικούς φίλους + φίλες για να ξεσκάσεις ..... και μην ανησυχείς ΘΑ ΛΥΘΕΙ το πρόβλημα.
Παιδιά μην τον εξαγριώνετε τον NiKa άδικα, εχει αρκετά που τον νευριάζουν με αυτό που έπαθε και δεν ειναι ανάγκη να του βάζουμε ιδέες που και καμία λύση δεν θα του προσφέρουν και θα συνεχίσουν να τον νευριάζουν.
Δεν νομίζω να ειναι ανάγκη να αρχίσει τέτοιου είδους αλληλογραφία με την Intel ..... εκτός τούτου ειναι πολύ πολύ πολύ σοβαρή εταιρεία .... και το κυριότερο .... υπευθυνος για την λύση του προβλήματος ειναι το κατάστημα που εκανε την πώληση !!!!!! και να μην ξεχνάμε ότι υπάρχειο και το DOA (dead on Arrival) που σημαίνει ότι όταν καποιο προιόν δεν δουλευει όπως πρέπει τότε το επιστρέφουμε και μας δίνουν καινούργιο (χωρίς καμία συζήτηση). Οπότε υπάρχει και αυτή η λύση. Δεν υπάρχει περίπτωση η Intel να μην δεχθεί την αλλαγή του NUC, αλλά όπως ειπα και πριν η ΟΛΙΚΗ ΕΥΘΥΝΗ ειναι με το κατάστημα που πούλησε το NUC.
Η Ιντελ μαλλον δεν θα δεχθει επιστροφη , γιατι στην απαντηση της ηταν σαφης
Υ.Γ
Ουτε και εγω θελω να τον στεναχωρησω τον Νika , απλα η ιδια η Ιντελ δεν ξερει τι απαντα
Απάντηση: Re: Απάντηση: Intel NUC (Intel Next Unit of Computing)
Η 2η ερώτηση είναι πιο ουσιαστική:
Let me get this straight..
the lower memory slot that does not work is normal...?
και ήρθε η χλαπάτσα:
Thank you for contacting IntelΒοΏ½ Customer Support.
Οι μνήμες δεν φαίνονται στη λίστα της Intel... αλλά στη λίστα της Kingston (ότι είναι συμβατές με το 34010)... (τους οποίους τους έστειλα email)...
Μία μόνο μνήμη δουλεύει στο upper slot... (όποια και να βάλω)...
αν βάλω στο κάτω slot μνήμη είτε μόνη της είτε με άλλη κολλάει το nuc...
το αγόρασα από eshop... τους το έστειλα πίσω και αναμένω τη δική τους διάγνωση...
Τώρα η Intel έβγαλε προϊόν όπου δεν δουλεύει - επίσημα - το 1 memory slot ....τι να πω ... θα δείξει...
ΥΓ: στο κρανίο δεν τα παίρνω με εσάς τους συναδέλφους... αλλά με τις Μ@Λ@Κ@ Εταιρείες που βγάζουν beta προϊόντα...
(μία από τις συμβουλές τις ιντελ ήταν να δοκιμάσω και άλλο firmware μήπως και δουλέψει... ΟΛΕΕΕΕΕΕΕΕ :flipout:)
και κατηγορούσα την Popcorn για το Α400...... !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Έτσι όπως μας τα περιγράφεις, μου ακούγεται σαν ελαττωματικό προϊόν που χρήζει αντικατάσταση. Δεν μπορώ να σκεφτώ ότι έβγαλαν ένα προϊόν με δεύτερο slot το οποίο να μην δουλεύει!!! (εκτός και αν εγώ δεν έχω καταλάβει κάτι καλά από την όλη φάση)
Σε συνέχεια για το θέμα με τις μνήμες...
Έστειλα mail στην Kingston... και με πήραν τηλέφωνο .... (αριθμός Αγγλίας)..
μου είπαν να τους ενημερώσω για το αν τελικά ήταν ελαττωματικό το Nuc... αλλιώς να δούμε τις θα κάνουμε...
Εντυπωσιάστηκα...
Και είμαστε σε αναμονή ... :)
Επανερχομαι λιγο στο θέμα (ειχα αντιμετωπισει θεματακια με τον σκληρο), πηρα εναν καινουριο SSD και ολα καλα στο να τον βλέπει.
Όμως εχω εγκαταστησει τα win 8.1 5 φορες εως τώρα!!!. Καθε φορα, με το που τελειωσει η εγκατάσταση και ειναι ολα σετ μετα το πρώτο update, κολλάνε ολα στο boot. εχω δοκιμασει τα παντα απο εργαλεία
μεχρι και το recover κανει fail!!!!! Μου εχει φάει τα συκώτια το ρημάδι. τα επανεγκατάστησα σημερα, εχω χασει καθε υπομονη μου...
εγω 8.1 εχω βαλει εδω και 3 μηνες περιπου, δεν ειχα προβλημα με την εγκατασταση ουτε με το update. Τι bios εχεις?
